Old 04-28-2016, 04:58 PM   #575
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by benlaz88 View Post
Hey Zach,
What info do you need to get the new update? I don't remember what version i had because i had Ronnie from JDL updated for me last time. I also sent you a email along with this
Ben
Hey Ben,
Got back to you in email before I saw this post!
Sincerely,
Zach
Old 04-29-2016, 03:20 AM   #576
Crazypinoy9
Drives: FR-S TRD RS1#1488
Originally Posted by byun View Post
Thanks Zach! Spent the last few days driving around on the update and it's definitely smoothed things out on the low end and starting from a stop. Glad you guys figured it out!
Been driving on the updated version for about 2 days now and it's night and day difference. so much smoother. no more hesitation in the throttle. Could just be placebo but even everything above 3K feels smoother too.
Thanks for the quick update Zach!
Crazypinoy9 is offline   Reply With Quote
The Following 2 Users Say Thank You to Crazypinoy9 For This Useful Post:
clayrush (04-29-2016)
Old 04-30-2016, 12:17 PM   #577
FaDuck
Drives: 2014 UltraMarine FRS
Got the update from Zach yesterday. I could tell the difference the second I pulled out of the garage.
I was actually hoping to hit as many red lights as possible
Thanks Zach!
FaDuck is offline   Reply With Quote
The Following 3 Users Say Thank You to FaDuck For This Useful Post:
MAPerformance (05-02-2016), SkAsphalt (05-13-2016)
Old 05-12-2016, 02:14 PM   #578
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
How much is an updated tune? it looks like I am running version 16. is it the 65 USD ish?
Edit Found the answer a few pages back. Look forward to an email asking for an update Will be going for a 7PSI base map and a 10PSI map on 94 octane. I think that is as high as I will go with the AVO kit on my 2.5" exhaust and stock fuel setup.
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 05-12-2016, 02:23 PM   #579
DeliciousTuning
It'll be a huge jump from Version 16!
-Zach
Old 05-12-2016, 05:41 PM   #580
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Ran the new updated tune over the weekend to, at and from PittRace to home. Driveability is much improved at low speeds. Car had no issues at the track. E85 is the way to go. :-)
Sent from my SM-G930V using Tapatalk
cruizin01 is offline   Reply With Quote
The Following 2 Users Say Thank You to cruizin01 For This Useful Post:
Old 05-15-2016, 10:55 PM   #581
dp1
driving smoother faster
Drives: Sold
Delicious Flash & GO Tunes for ALL FORCED INDUCTION Applications - Q&A
Back from two days at the Pocono Raceway - updated tune worked great as expected - 41F-73F ambient range, engine pulls strong, AFRs and oil temps look good (oil cooler and hood vents helped too) - thx
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
DeliciousTuning (05-16-2016)
Old 06-03-2016, 11:06 PM   #582
DeliciousTuning
For those of you who want to add a little more safety to your forced induction package.
Flex Fuel Kit Mark 1+ Upgrade with built in safety features.
Quick video on how the system works.
[ame="https://www.youtube.com/watch?v=4vLtj3B2mZA"]Delicious Tuning Flex Fuel Kit Mark 1+ - YouTube[/ame]
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Hicklinc (06-17-2016)
Old 06-04-2016, 12:07 AM   #583
AMAY93
AMAY93's Avatar
Drives: Subaru BRZ limited MT
Hey guys im looking to get the c38 JRC kit and a jdl header installed on my brz. I already have a perrin over pipe, catless resonated invidia front pipe, and resonated catback exhaust by perrin, and light weight perrin crank pulley. Im looking to get the TIY kit of the JRC. Would I need a Tune from you guys before I install the new parts on my car? and once everything is installed with my current parts, The map yall send me should work fine with all my parts correct? the flash and go tune should be adjusted with all my parts and maybe with a few data logs and revisions to get it running right? I just dont wanna get the carb map since I have other parts. I already have a E-tune from speedfactory that works well with my NA set-up just making sure this is a safe option and a good one.
- 2013 silver limited brz 6mt -
AMAY93 is offline   Reply With Quote
The Following User Says Thank You to AMAY93 For This Useful Post:
86Tony (07-15-2016)
Old 06-13-2016, 02:58 PM   #584
DeliciousTuning
Our tune will work perfectly with your additional modifications, and should be installed prior to initial startup of the vehicle with the supercharger installed. Keep in mind, you will also need either Jackson Racing's 4 BAR map sensor, or our 11psi map sensor. Our tunes come with one free datalog review and revision, if necessary.
-Zach
86Tony (07-15-2016)
Old 06-13-2016, 06:31 PM   #585
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Just wrapped up another Turbo Install with Delicious F&G paired with their flex fuel kit. Car runs amazing as usual
JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
Hicklinc (06-17-2016), twag4 (06-16-2016)
Old 06-17-2016, 11:30 AM   #586
DeliciousTuning
Thanks for sharing! I'm loving the new cerakote option you guys are offering!
-Zach
Old 07-15-2016, 12:51 AM   #587
86Tony
Drives: 2015 AOZORA EDITION
what would be the wastegate spring pressure for JR c38 kit
86Tony is offline   Reply With Quote
Old 07-15-2016, 11:28 AM   #588
DeliciousTuning
9psi for the standard sized pulley that comes with the kit. For superchargers, "wastegate spring pressure" will be the boost that the pulley you're using produces on that kit.
-Zach
dj2020 (07-15-2016)
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
