Old 05-27-2014, 08:54 PM   #5755
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Originally Posted by shif7i7down View Post
the software and the frs xml are on the openflashtablet website under download section
I honestly think that 3.91v is too low for 5psi boost -_-..
UPDATE: P0108 cel code is solved with a higher voltage limit.. i set it to 4.91 and no more cel. yeeaahh me. ^_^
You need to double check your tune. Maybe ask shiv to resend it?
Installed Mods:
Old 05-27-2014, 09:13 PM   #5756
shif7i7down
Erected Member
Drives: frs
idk why, but it was at 3.91 "could be an older tune", the same as the stage 1 tune for 93oct, so i figure since the map is able to go from 0 to 5v , setting it at 4.91 should still be safe
shif7i7down is offline   Reply With Quote
Old 05-27-2014, 09:31 PM   #5757
TM
TM's Avatar
Drives: DGM BRZ 6MT
can someone check their Phantom tune with Romraider and tell me what their Manifold Pressure Sensor is set at for High and Low input.
I don't want to install the software, but if you want, you can PM me your email address and I'll email you my tune so you can check for yourself.
I never had a CEL code thrown at me except for the display one, which was due to plugging in the OFT at times.
TM is offline   Reply With Quote
Old 05-27-2014, 10:25 PM   #5758
shif7i7down
Erected Member
Drives: frs
thanks for the offer, but the cel issue is already solved.
Old 05-27-2014, 10:57 PM   #5759
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Good find, mine's set at 5.00 directly from Shiv.
Must have been a revision somewhere along the line, like you said.
alexand3r is offline   Reply With Quote
Old 05-28-2014, 04:15 AM   #5760
gtfapollo
gtfapollo's Avatar
Drives: Velocity Orange
Just a quick query. I know that Rob must be very busy with his work and getting these kits sorted out, but how long should I wait until I get a response from him? I sent a PM to him one week ago regarding the purchase of one of his TQ-25024V's. I don't want to pester him by sending him more PM's if he is busy but I would like to get one ASAP.
gtfapollo is offline   Reply With Quote
Old 05-28-2014, 04:24 AM   #5761
DAEMANO
Time Traveller
Have you tried contacting him through the website?
http://www.phantomsuperchargers.com/contact.html
Old 05-28-2014, 06:25 AM   #5762
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
He might have missed it, you could try to send one again and ask to be added to the waiting list. I believe all the orders for the frs/brz have to come through this site via PM, not the phantom site. As long as he can find your first PM you will likely be added to the list in order of contact, so I don't think you need to rush. I don't know how long the waiting list is, or how often he will send out shipments, but I believe that even if you get on the next shipment, they will not ship out for at least another month, probably longer. Keep in mind, you will not be asked for payment till they are ready to ship.. I am on the list somewhere myself but don't know if I will be in the next shipment, or 3 shipments from now, so unfortunately ASAP might not be very soon.
Although if he does have time to stop by, maybe he could give up some sourcing info on the battery posts he uses for the negative extension cable for the starter battery, I am still putting my relocation kit together, and I need those posts with threads long enough to fit a ring terminal/sheet metal/ and lock nut. Will be posting a diy when I am done.
Old 05-28-2014, 06:37 AM   #5763
raven1231
I would try to contact through the phantom site as well. That's what I did to get mine. Good luck, you will be satisfied with the investment
Old 05-28-2014, 07:45 AM   #5764
shif7i7down
Erected Member
Drives: frs
It's it just me or is it a normal thing? I've noticed that if I drive normally without going wot my average mpg is 2~3mpg more then usual. unless I'm just going crazy.
Old 05-28-2014, 07:50 AM   #5765
TM
TM's Avatar
Drives: DGM BRZ 6MT
The Phantom ESC isn't ready for Australia yet. Last I heard, @Robftss wants @Gums to test it for a month before making it available. That was about a week ago.
Old 05-28-2014, 07:54 AM   #5766
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
The car is running more efficiently in the normal powerband. This is totally possible.
Luckrider is offline   Reply With Quote
Old 05-28-2014, 08:16 AM   #5767
WNDSRFR
Drives: FR-S,GTI
I installed the 1.5 dump pack yesterday. I have one thing to say.
Nice.
Very Nice.
As has been said many times before, it just pulls all the way to redline.
The whole setup looks very professional like it belongs there.
This really is the way the car should come from the factory. It's well worth every penny spent. Remember your car when it was stock? I was actually thinking about replacing the motor with the 1.8T out of my VW. I was that disappointed with the torque of the stock engine.
But now I can blow my VW away!
Old 05-28-2014, 08:47 AM   #5768
CBR600RR
Drives: Raven Black
Nice.
Very Nice.
and how exactly did you plan on putting a 1.8TVW engine in there???????????????????????????
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
