go_a_way1
Old 03-19-2013, 06:28 PM   #561
Originally Posted by GTM_Challenge View Post
I love my FR-S the more I drive it. And I'm an s2000 guy...
TRAITOR
You may now credit me with convincing you to buy your FRS in your sig. tyty.
Old 03-19-2013, 06:31 PM   #562
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
TRAITOR
<3
"CSG MIKE told me the FR-S/BRZ Was easier to drive fast than an S2000...So I bought one and now I can drive Flat Out, the way I couldn't drive my S2000"
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
CounterSpace Garage (03-19-2013)
Old 03-19-2013, 07:01 PM   #563
<3
Immortalized. LOL
Old 03-19-2013, 07:04 PM   #564
GTM_Challenge
Drives: On track
Immortalized. LOL
roffles
Old 03-19-2013, 07:23 PM   #565
Ryeong86
Ryeong86's Avatar
Drives: 2015 Sti Launch Edition
It's not super hard to change rims...
Most people aren't going to be buying hoosiers and running stock class autox.
It's not hard but for scca you can't get wider rims than what the factory provides for the car. The wider the tires, the more you will grip. That extra surface to grip will make a big difference.
Ryeong86 is offline   Reply With Quote
Old 03-19-2013, 07:39 PM   #566
I did not know that. I guess the 225 tires I run need to be wider for more grip.
Old 03-20-2013, 03:54 PM   #567
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
The S2000 is a great car but look at the specs. 240 HP with 152lb ft of torque. The S2k weighs in at 2800 lbs. Now the FR-S has 200hp and 151lb ft of torque and weighs in at 2750. 200 hp is achieved at 7000 rpm in the FR-S and 240 hp is achieved at 8300 rpms. These cars are very similar.
The advantage I see with the s2k over the fr-s is this:
When doing SCCA stock events, the s2000 has wider rims that are provided by the factory. You can throw on 275's on the rear tires and grip like a beast. The measly 7 inch width on the FR-S hinders how wide your tires can be before upgrading to a new wider rim which takes you out of stock class. If that is important to you, then go with the S2000, if not go with the FR-S.
That's my opinion.
That's an overly simplistic and flawed comparison. First you're just comparing the AP1 model, not the AP2 as well. Second you're leaving gearing entirely out of the equation. And third, if you're on a race track it doesn't matter if the car makes peak power at 7000 or 8300 rpm if the gearing is done properly and you can keep the engine in the power band (hint, the S2000's gearing is set up that way).
I love my BRZ but still miss my S2000 b/c it was more fun to drive as a stock vehicle.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 03-21-2013, 05:07 PM   #568
Ryeong86
Ryeong86's Avatar
I figured I simplify it.. but I love both cars so it would be a tough choice either way.
Old 03-21-2013, 08:46 PM   #569
redcelica
redcelica's Avatar
Drives: S2000
While I own and have always loved the S2000, my bud Heath (sn: Nothing) just picked up a turbo FRS off the forums yesterday. At 300whp+, the car is simply a joy to experience. We both test drove a stock FRS and I have high compliments in regards to the brakes and the steering in the FRS. Power is lacking, but it's lacking in the S2000 too. I have an 07, which has the drive by wire, nanny-VSA system, and is prone to understeer. It takes the right alignment, the right tires, and most importantly the right DRIVER to get the most out of the car in stock form. I was not impressed with the clutch in the FRS, as it felt very numb with little to no feedback, and the tires are absolute shit. The lack of power, clutch, and tires are simple, yet costly fixes. Add a turbo and a better clutch and a set of wider star specs, and the FRS is an even more impressive machine. The handling capabilities out of the box is what impressed me the most though. The car, even on crap tires, still felt settled and inspiring.
Now that my friend has a turbo, it only inspires me to continue my progress in supercharging my S. I track my S as well and I will say, it's nice not having a rollbar requirement!
I look forward to seeing the progression of the FRS/BRZ as more tuning options come online.
jm2c
-Brett
redcelica is offline   Reply With Quote
Old 03-22-2013, 03:49 AM   #570
Brzetto
Drives: 4 wheels
^interesting that you think that. The position of that tachometer, and the way the increments spread out further above 6000 rpm, was intentionally done. Makes it FAR EASIER to glance at engine speed when you're flying from to turn to turn on a race track.
For that purpose it's one of the best designed tachometers in a production car.
You could put analog gauges on the car and they would still be easy to read at a glance. I find the illuminated needle and digital speedometer on the BRZ very easy to read at a glance.
Brzetto is offline   Reply With Quote
Old 03-22-2013, 10:01 AM   #571
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Anxiously awaiting an STi version. Hopefully it will stay NA.
iLuveKetchup is offline   Reply With Quote
Old 03-26-2013, 03:20 PM   #572
Hordur
Drives: Peugeot 106 Rallye, Integra Type-R
The S2000 is a convertible. I am not a hairdresser, so to me it is pointless.
Hordur is offline   Reply With Quote
The Following User Says Thank You to Hordur For This Useful Post:
Kido1986 (04-01-2013)
Old 03-26-2013, 03:27 PM   #573
GTM_Challenge
Drives: On track
Old 03-27-2013, 09:58 AM   #574
manonastick
Drives: WRB ZC6
as owner of a s2000 was jizzing myself about the 86 until i drove my friends s2k. The 86 was designed to be a car to be easy and fun to drive. The s2000 is no doubt a fun car but its much more challanging to drive it fast. Remember also its not fair comparing a roadster to coupe when the coupe obivously has more chasis rigidity. Also the deiciding factor for me to get a s2000 is its potential (in terms of modding) i know as time goes the 86 is going to get more parts and all but i just can't get over the fact the ASM s2000 being n/a was able to out run cars with much more power.
Well thats just me i love both cars though
manonastick is offline   Reply With Quote
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 04:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 10:46 PM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 02:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 09:05 PM
