#547 |
Does 99% count?
My "cool" Procede map is at 99% at 49% throttle, at 6875 rpm. It's tough to use more boost at a lower rpm, since the timing, engine load, open loop fuel map, and other tables need to be changed to use it. I've tried it without modifying the tune for it, and all it does is make a wooshy noise and run slower. Disappointment is an understatement. You want to use that kind of boost that quick, you'll need a custom tune from someone who can put it on a dyno to tune it.
If I say yes, will that make you think I understand?
#548 |
Drives: White 2014 BRZ
I have good tuner im sure we can make it work with street tuning. Ecutek ftw.
Im talking mid range power at half throttle
JDL Turbo kit - Ecutek, HRI tuned.
#549 | |
Right now I'm using 2 Shuriken batteries for the ESC and One big crank for the car, but I made a trunk mount for the 2 big cranks and I plan on running the car from one of them, and using the other one to power the compressor for my air suspension, and my audio amp. I'd like to use 4 Shurikens up front to power the ESC with 2 series in parallel, but I think I would have to wire in an auxiliary charger to handle the second batteries. I'll post pics when I'm done.
#550 | |
#551 |
Drives: SWP BRZ
i drove around today and i notice that i got little boost power and shorter duration.
is it related to cold weather? i run with throttle switch |
#552 |
Probably. I'm sure its a lot colder in NJ than FL. But the other night at 45 F felt faster than at 75 F this afternoon. The colder air is denser, so more boost. Most superchargers do this. Turbos don't because they have waste gates to control boost.
#553 |
Drives: FR-S,GTI
I notice quite a bit of power increase on a cold morning. When it gets below 50 outside and the car is parked in the 70 degree garage all night the power difference is striking.
Your statement about turbo's however is not always the case. My GTI has a boost gauge and normally the peak pressure is around 14 psi. On a cold high pressure day I will get over 16psi. And you can really feel the difference. |
#554 | |
#555 |
Drives: FR-S,GTI
VW's don't have a BOV. They have a recirculating valve. What it does is when you let off the throttle rather than just release the boost pressure to the atmosphere it recirculates it keeping the pressure up for when you step on the throttle again. It greatly reduces the turbo lag. And the only tuner I know of for VAG products is APR.
Actually my car is a 2002 Mk IV. It was built before the advent of flashable CPU's. To get it tuned you had to remove the CPU and send it to APR. They would change the chip and send it back. |
#556 | |
Funny though a 2.5L awd @ 16psi WRX I had ran 13.7 @ 99. My brz with the ESC @ 4-5 psi runs 13.8 @ 101.
#557 |
Drives: FR-S,GTI
Is that 1/4 mile time on gas or alcohol? Either way it's pretty impressive. That's faster than a lot of 60's muscle cars. Here's a list.
1966 Shelby gt350h automatic 3.89 rear- 15.2@93 1966 Satellite hemi 4 speed 3.54- 13.8@104 1966 GTX 440 automatic 3.23- 14.4@98 1966 442 4 speed 3.55- 14.6@100 1966 SS396 Chevelle 4 speed 3.55- 14.66@99 1966 GTO tripower 4 speed 3.55- 14.0@105 1966 Buick GS automatic 3.36- 14.92@95 1966 Fairlane gt 390 automatic 3.89- 14.26@99 1966 Cyclone gt 390 4 speed 4.11- 13.87@103 1966 AC Cobra 289 4 speed 3.77- 13.73@101.58 1968 Charger hemi automatic 3.23- 13.5@105 1968 SS396 (375 hp)Nova 4 speed 3.55- 14.5@101 1969 SS396 Chevelle(325 hp) 4 speed 3.55- 14.4@97 1969 Super bee 383 4 speed 3.55- 14.0@99 1969 Fairlane Cobra 428 automatic 3.50- 14.0@100.6 1969 Cyclone 428 automatic 3.91- 13.94@100.89 1969 roadrunner hemi automatic 3.54- 13.54@105 1969 Boss 302 Mustang 4 speed 3.50- 14.57@97 1969 Corvette 427 435 hp 4 speed 3.70- 13.8@106.8 1970 Challenger hemi automatic 3.23- 14.1@103.2 1970 GTO 455 4 speed 3.31- 15.0@96.5 1970 Z28 automatic 4.10- 14.2@103.3 1970 LS6 Chevelle automatic 3.70- 13.81@103.8 1970 Duster 340 4 speed 3.91- 14.39@97.2 1970 Boss 302 mustang 4 speed 3.91-14.93@93.45 1971 Roadrunner 440 automatic 3.23- 14.9@95.4 1972 Barracuda 340 4 speed 3.55- 15.5@97.7 Read more: http://www.city-data.com/forum/autom...#ixzz40LaBXWP0 |
#558 |
Drives: 2013 Asphalt 6spd
I think it's a good time. and not to be a downer, but beating 50 year old benchmarks is not really the best measurement of performance. That would be like a new smartphone manufacturer saying "It isn't as fast as the new I-phone, but compare it to the top of the line supercomputer in 196X that sent us to the moon and that really shows what it can do!"
#559 | |
Time Traveller
If modern cars are a better measurement then, how about more modern "direct" competitors? I included everything I could find a 1/4 mi time on from one website: http://www.zeroto60times.com/browse-by-make/ I think by the time the end of the list is reached, it's safe to say, a Phantom ESC'd 86 matches up nicely to its' competitors at the dragstrip even though the car was never designed with that in mind. @Steveo585 's BRZ Phantom ESC 13.8 @ 101 @shif7i7down 's FRS Phantom ESC 14.01 @ 104 Guessing that the above's 0-60 times will be in the low 5's to 5 flat. I've boldfaced every car that is matched or bested. Scion 2013 Scion FR-S (Manual) 0-60 mph 6.2 | Quarter mile 14.5 2013 Scion FR-S (Auto) 0-60 mph 7.9 | Quarter mile 15.9 2012 Scion tC 0-60 mph 6.8 | Quarter mile 15.2 Subaru 2015 Subaru Impreza WRX 0-60 mph 5.2 | Quarter mile 13.8 2015 Subaru Impreza WRX STI 0-60 mph 4.6 | Quarter mile 13.2 Mazda 2016 Mazda MX-5 Miata 0-60 mph 5.8 | Quarter mile 14.5 2010 Mazdaspeed3 0-60 mph 5.4 | Quarter mile 14.0 1995 Mazda RX-7 R2 0-60 mph 5.2 | Quarter mile 13.9 2009 Mazda RX-8 R3 0-60 mph 6.5 | Quarter mile 14.8 Honda 2016 Honda Civic Type R 0-60 mph 5.6 | Quarter mile 13.8 2012 Honda Civic Si Sedan 0-60 mph 6.0 | Quarter mile 14.5 2012 Honda Civic Si Coupe 0-60 mph 6.4 | Quarter mile 14.7 2011 Honda CR-Z 0-60 mph 8.2 | Quarter mile 16.2 1995 Honda Prelude VTEC 0-60 mph 6.6 | Quarter mile 14.9 2008 Honda S2000 0-60 mph 5.6 | Quarter mile 14.2 2006 Honda S2000 0-60 mph 5.4 | Quarter mile 13.8 Nissan 2015 Nissan 370Z NISMO 0-60 mph 4.9 | Quarter mile 13.5 2011 Nissan 370Z 0-60 mph 4.6 | Quarter mile 13.0 2008 Nissan 350Z Enthusiast 0-60 mph 5.2 | Quarter mile 13.5 2004 Nissan 350Z Roadster 0-60 mph 5.6 | Quarter mile 14.1 Mitsubishi 2015 Mitsubishi Lancer Evolution MR 0-60 mph 5.0 | Quarter mile 13.7 2006 Mitsubishi Lancer Evolution IX MR 0-60 mph 4.4 | Quarter mile 13.1 2006 Mitsubishi Eclipse GT 0-60 mph 6.0 | Quarter mile 14.3 1997 Mitsubishi 3000GT VR-4 0-60 mph 4.7 | Quarter mile 13.4 1995 Mitsubishi Eclipse GSX 0-60 mph 6.3 | Quarter mile 14.7 1986 Mitsubishi Starion ES 0-60 mph 7.4 | Quarter mile 15.8 Hyundai 2013 Hyundai Genesis Coupe 3.8 R-Spec 0-60 mph 5.0 | Quarter mile 13.5 2013 Hyundai Genesis Coupe 2.0T R-Spec 0-60 mph 5.8 | Quarter mile 14.2 2013 Hyundai Genesis Coupe 2.0T Premium 0-60 mph 6.0 | Quarter mile 13.9 2004 Hyundai Tiburon GT 0-60 mph 7.0 | Quarter mile 15.4 2013 Hyundai Veloster Turbo 0-60 mph 6.8 | Quarter mile 15.0 BMW 2014 BMW 328i GT xDrive 0-60 mph 5.9 | Quarter mile 14.3 2014 BMW 335i Gran Turismo Hatchback 0-60 mph 5.0 | Quarter mile 13.7 2011 BMW 1-Series M Coupe 0-60 mph 4.4 | Quarter mile 12.8 2008 BMW 128i Coupe 0-60 mph 5.7 | Quarter mile 14.3 2013 BMW 135is 0-60 mph 4.5 | Quarter mile 13.2 2008 BMW 135i Coupe 0-60 mph 5.0 | Quarter mile 13.6 2013 BMW 335i M-Sport Sedan 0-60 mph 4.5 | Quarter mile 13.1 2014 BMW 428i Coupe 0-60 mph 5.2 | Quarter mile 13.8 2012 BMW Z4 sDrive28i 0-60 mph 5.6 | Quarter mile 14.3 2007 BMW Z4 3.0si Roadster 0-60 mph 5.2 | Quarter mile 13.8 2007 BMW Z4 M Roadster 0-60 mph 4.7 | Quarter mile 13.2 Mini 2015 Mini Cooper Hardtop John Cooper Works 0-60 mph 5.8 | Quarter mile 14.3 2015 Mini Cooper S Four-Door Hardtop 0-60 mph 6.3 | Quarter mile 14.9 Volkswagen 2015 Volkswagen GTI (Manual) 0-60 mph 5.9 | Quarter mile 14.4 2015 Volkswagen Golf R 0-60 mph 4.5 | Quarter mile 13.0 2015 Volkswagen Golf 1.8T (Manual) 0-60 mph 6.7 | Quarter mile 15.3 2014 Volkswagen Beetle GSR 0-60 mph 6.2 | Quarter mile 14.7 1993 Volkswagen Corrado SLC 0-60 mph 6.8 | Quarter mile 15.3 Porsche 2014 Porsche Cayman S 0-60 mph 4.0 | Quarter mile 12.3 2011 Porsche Cayman R 0-60 mph 4.1 | Quarter mile 12.6 2009 Porsche Cayman 0-60 mph 5.0 | Quarter mile 13.5 2016 Porsche Boxster GTS 0-60 mph 4.1 | Quarter mile 12.7 2013 Porsche Boxster S 0-60 mph 4.2 | Quarter mile 12.7 2012 Porsche Boxster 0-60 mph 5.5 | Quarter mile 14.1 (calculated) Fiat 2012 Fiat 500 Abarth 0-60 mph 6.7 | Quarter mile 15.0 Lotus 2009 Lotus Exige S 260 0-60 mph 4.2 | Quarter mile 12.8 2008 Lotus Elise SC 0-60 mph 4.4 | Quarter mile 13.3 2005 Lotus Elise 0-60 mph 4.3 | Quarter mile 13.0 2011 Lotus Evora S 0-60 mph 4.7 | Quarter mile 12.9 Chevrolet 2016 Chevrolet Camaro LT (V6) 0-60 mph 5.4 | Quarter mile 14.0 2010 Chevrolet Camaro (V6) 0-60 mph 6.0 | Quarter mile 14.3 2009 Chevrolet Cobalt SS 0-60 mph 5.7 | Quarter mile 13.8 Dodge 2015 Dodge Challenger SXT (V6) 0-60 mph 6.1 | Quarter mile 14.5 2011 Dodge Challenger SE (V6) 0-60 mph 6.3 | Quarter mile 14.7 2013 Dodge Dart Rallye 0-60 mph 7.8 | Quarter mile 15.8 2004 Dodge Neon SRT-4 0-60 mph 5.2 | Quarter mile 13.7 1992 Dodge Stealth R/T Turbo 0-60 mph 5.6 | Quarter mile 14.0 Ford 2016 Ford Focus ST 0-60 mph 6.2 | Quarter mile 14.8 2014 Ford Fiesta ST 0-60 mph 6.7 | Quarter mile 15.0 2015 Ford Mustang EcoBoost Premium 0-60 mph 5.3 | Quarter mile 13.9 2013 Ford Mustang V-6 Premium 0-60 mph 5.1 | Quarter mile 13.7 1994 Ford Probe GT 0-60 mph 7.4 | Quarter mile 15.6 Pontiac (BEWARE!) 2005 Pontiac GTO 0-60 mph 4.5 | Quarter mile 12.8 2009 Pontiac Solstice GXP Coupe 0-60 mph 5.1 | Quarter mile 13.5 2007 Pontiac Solstice GXP 0-60 mph 5.5 | Quarter mile 14.0 2006 Pontiac Solstice 0-60 mph 6.9 | Quarter mile 14.8 Last edited by DAEMANO; 02-16-2016 at 04:00 PM. |
#560 |
Drives: BRZ Limited; GR86
Hey guys, what's the max boost you are able to hit on the v3 phantom?
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
