Northwest AK, ID, OR, WA
Old 08-22-2015, 05:44 PM   #43
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think Subie E2 signal is just ECM chassis ground and not earth ground. There can be many different ground points.
edit: Honda SG3 indicates a chassis ground.
Old 08-22-2015, 05:52 PM   #44
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Well I know on the Scion TC, VC is a 12V and E2 was 5V and they seperately power the TPS and Throttle plate, but if there is a ground in the harness it's definitely E2 which would mean
Subaru pin 3 to Honda pin 4 with no need to leave anything disconnected or run a chassis ground separately, ensure Subaru pin 3 isn't hot first though.
Decay107 is offline   Reply With Quote
Old 08-22-2015, 05:56 PM   #45
Ultramaroon
not playing cards
Originally Posted by johan View Post
Can't repin the TB, it'd be the plug.
Pull pin 1.
6>1
2>6
5>2
1>5
swap 3 and 4
Old 08-22-2015, 05:58 PM   #46
Ultramaroon
not playing cards
I agree with this. Worth a physical check.
Old 08-22-2015, 06:02 PM   #47
Decay107
Decay107's Avatar
Pull pin 1.
6>1
2>6
5>2
1>5
swap 3 and 4
working copy. proof reading it.
I think we are saying the exact same thing just looking at at 180degrees from the opposite direction lol
Old 08-22-2015, 06:09 PM   #48
Ultramaroon
not playing cards
I agree we agree.
Decay107 (08-22-2015)
Old 08-22-2015, 06:56 PM   #49
johan
Drives: '14 981CS, '99 NB1
So... if I've followed you guys correctly, this is what you are proposing?
johan is offline   Reply With Quote
Old 08-22-2015, 07:11 PM   #50
Ultramaroon
not playing cards
yes. Doublecheck the black-with-yellow-striped wire. make sure there is no DC anything on it with the ignition turned on.
Old 08-22-2015, 07:25 PM   #51
Decay107
Decay107's Avatar
Yes, that's correct. Might want to buy some OEM connectors and make a conversion harness, far more reversible than re-pinning, also check stock pins 5 and 3 for voltage (black wires), if there is any danger of a short it's there. If our assumptions are correct black blue should be a voltage source and black yellow should be a ground.
The Following User Says Thank You to Decay107 For This Useful Post:
Ultramaroon (08-22-2015)
Old 08-22-2015, 07:28 PM   #52
johan
Confirmed that it is indeed a ground. Now the fun part....
Old 08-22-2015, 07:32 PM   #53
Ultramaroon
not playing cards
You might have some whacky strain due to the mismatched wire lengths after repin. You may already know that so apologies in advance. Just giving cheap advice. I like @Decay107's idea about making a converter but we know this is just an experiment.
Old 08-22-2015, 07:33 PM   #54
johan
Eh, re-pinning is trivial. Lets see if it works first.
I also just all but confirmed that the K20 TB actually bolts onto our IM if you rotate it 90*. Can't quite fit it in there to actually try to bolt it up due to not wanting to disconnect the coolant lines on the stock one to remove it completely.
One annoying thing - Subaru spec'd M6 bolts for the TB where the Honda uses M8. I guess it's a good thing it isn't the other way around...
The Following 2 Users Say Thank You to johan For This Useful Post:
Decay107 (08-22-2015), Ultramaroon (08-22-2015)
Old 08-22-2015, 07:36 PM   #55
johan
You guys are correct that a harness would be better, if only to get additional slack on the wires. Subaru didn't spare -any- length on the connector, and with rotating the TB to make it fit, it'd be sketchy. Although since this experiment is really for SC kits that likely move the position of the TB anyways, it may be a moot point.
Old 08-22-2015, 07:42 PM   #56
Decay107
Decay107's Avatar
Ultramaroon (08-23-2015)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 02:59 PM
Tour of Edelbrock and their new Supercharger! August 28th The Racers Line Northern California 62 09-04-2015 03:59 PM
Edelbrock's Custom BRZ with SC Lonewolf Southern California 9 08-02-2015 06:17 PM
Thoughts on Kraftwerks C-Type Rotrex Supercharger Piper606 Scion FR-S / Toyota 86 GT86 General Forum 5 07-31-2015 10:59 AM
