Old 07-10-2015, 04:31 PM   #43
Vmax911
Drives: WRB BRZ
So if we can now monitor tire pressure, and chance we can disable the darn "low pressure" light all together?
Vmax911 is offline   Reply With Quote
Old 07-10-2015, 08:42 PM   #44
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Pressure cannot be monitored yet. Just individual tire air temp. Can't make promises to eliminate safety warnings due to liability concerns.
Old 07-10-2015, 08:45 PM   #45
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by churchx View Post
How about individual higher sampling rates per each monitored setting where it's needed, and slower ones (or dropping redundant subintervals data) where it's not?
Or .. in future OFT models wifi NAS mount or usb external storage for saving big loads of detailed full logs at less space-limited elsewhere?
There is a lot of things that can be done with regards to the datalogging code. But it's a tradeoff between time constraints more than anything else. We have an ever-growing To Do list which means that we need to prioritize updates carefully. As for storage capacity, there is plenty of it on the OFT. It is in the viewing/plotting domain where huge files become more a problem due to wait times.
Old 07-10-2015, 08:45 PM   #46
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Could the psi be adjusted for when the light turns on or is that a mechanical problem? I like to run my tires at 30psi but on a cooler day it's enough to set the light off.
Jrdad is offline   Reply With Quote
Old 07-10-2015, 08:46 PM   #47
Shiv@Openflash
Drives: 2013 FRS
Wink
Originally Posted by bee_are_zee View Post
@Shiv@Openflash
Just a thought; how difficult would it be to make logging rate user selectable for times when you are logging engine parameters for tuning vs logging an autocross run?
That will take some time. I don't see it happening in the foreseeable future.
Old 07-10-2015, 09:51 PM   #48
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Fantastic update Shiv!! Now I just need more info on that OFT350
And if I already have the OFT/OFH, is there a greater discount?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 07-10-2015, 10:35 PM   #49
Increasing the logging rate is easy. But it's a trade off between logging rate and datalog file size. People tend to get caught up with logging rates when there is little or no benifit of logging engine channels once you go beyond a certain rate. It's not like we are datalogging formula one cars here. But to be fair, once you start logging things like G sensors, faster rates may be useful. And if that turns out to be the case, we will adjust the logging rate accordingly.
10hz is not really useable for track duty; 100hz is.
I don't mind having datalogs in the hundreds of megabytes.
Old 07-10-2015, 10:44 PM   #50
Shiv@Openflash
Drives: 2013 FRS
Please explain how 10hz is not useable but 100hz is.
Old 07-10-2015, 11:24 PM   #51
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Yeah bro, anything less than 100hz and your coolant temp log just isn't accurate enough.
So, what you're saying is... a 10hz Gforce reading is useless for track duty? Uhh.... Really? Now of course there are certain parameters where 100hz would be really useful (wheel speed), but saying 10hz "is not really useable" generally is, well... silly.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 07-10-2015, 11:42 PM   #52
My driving corrections happen in less than 0.2s. Seeing one "spike" of steering angle, with momentary wheelspin that only occurs for 0.35s doesn't help me figure out what's going on, when the data comes at a rate of 0.1s.
with 100hz vs 10hz, you're comparing maybe 5 data points during the incident, vs 50.
Old 07-10-2015, 11:43 PM   #53
Yes, I am.
How long do you think the impulse of hitting a berm, or a dip lasts for?
I'm not saying that all channels need to be polled at 100hz. I poll voltage at 1hz unless I'm doing diagnostics. I'd just like the option to be able to bump the poll rate up.
Old 07-10-2015, 11:55 PM   #54
steve99
True however its also going to depend on traffic on the CAN buss and if the BCM/VSC updates at 100hz .
No use interrogating the BCM/VSC for data at 100hz if the BCM only updates at 20hz. or the CAN buss wont respond to that level of interrogation.
Old 07-11-2015, 01:04 AM   #55
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Is there going to be more CAL files to be unlocked in the near future?
efactor84 is offline   Reply With Quote
Old 07-11-2015, 02:43 AM   #56
churchx
churchx's Avatar
Drives: 2014 GT86
If main issue is OFT speed to work with/display data, not storage space, then another easy way would be split big log file in smaller. Be it in eg. 5 or 1 min increments, or by user configurable time count. So then feature to be added: "auto-splitting/rotating" logfile output with adding timestamp (of log end/cut) to filename + UI for selection which logfile to display.
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
FS: New OpenFlash Tablet, OpenFlash Header, Perrin Filter, Perrin Antenna FT86POWER Engine, Exhaust, Bolt-Ons 12 05-01-2015 10:39 PM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
Expert Review: Plug-and-Play performance for the FRS/BRZ with Vishnu Openflash Tablet ModBargains.com Software Tuning 82 07-25-2014 07:06 AM
