Old 07-20-2015, 04:32 PM   #43
Tim Radley
Drives: GT86, SQ5, RS3
It has the header and port work also done.
I'm thinking I should try the ACE header as that is claiming more gain on it's on than I have seen with all my changes.
Originally Posted by uspspro View Post
@Tim Radley
Hey Tim,
This is some really amazing stuff, thanks for sharing your findings!
Question... So, just to clarify that nice dyno chart has the following mods, please correct me if I am wrong...
- Piper Cams
- Upgraded single valve springs
- Tuned ECU (Motec)
- Stock header
- Stock internals, other than cams/srpings, but blueprinted.
Does it have any of the port filling work done to it, or are the ports still stock?
Thanks!!
Tim Radley is offline   Reply With Quote
The Following 3 Users Say Thank You to Tim Radley For This Useful Post:
8686 (07-20-2015), abraxis (07-20-2015), RJasonKlein (07-21-2015)
Old 07-20-2015, 09:55 PM   #44
abraxis
Drives: many
+1 for someone getting these heads into the game.
+2 for for verifying the ACE header.
abraxis is offline   Reply With Quote
The Following 3 Users Say Thank You to abraxis For This Useful Post:
8686 (07-20-2015), civicdrivr (07-21-2015), RJasonKlein (07-21-2015)
Old 09-02-2015, 10:12 AM   #45
Traktor
Drives: Subaru BRZ Limited
Piper Camshafts
That dyno graph still has peak power at around 7000, similar to stock. It will be interesting to see if the more aggressive cam enables power above this.
Great to see cams finally coming to market.
Traktor is offline   Reply With Quote
Old 10-10-2015, 03:43 AM   #46
w0wbagger
Drives: GT86
The piper website says that with their stage 2 cams one would also need their valve springs.
Well since I am already running aftermarket double valve springs I was wondering if I could install the stage 2 cams (ultimate road) without changing my valve springs again. Anybody has some info/ opinion about that?
I am also running +1mm oversize valves.
w0wbagger is offline   Reply With Quote
The Following User Says Thank You to w0wbagger For This Useful Post:
sato (02-13-2017)
Old 10-10-2015, 01:38 PM   #47
sw20kosh
Drives: 2013 Black FR-S
Wow! Any data or dyno results from your current setup?
Old 10-11-2015, 02:40 AM   #48
w0wbagger
Drives: GT86
I am running the Vortech Kit and not n/a, if that was what you'd hoped for.
For my results check the vortech owner thread.
Since the oversize valves have been installed together with the engine builing i cannot say how much gains just by the valves could have been reached.
Old 10-12-2015, 06:16 AM   #49
w0wbagger
Drives: GT86
I've just received an E-Mail from piper, that their stage 2 and 3 cams can also be used with other aftermarked stronger valve springs! Just if any1 else was curious.
Old 10-14-2015, 03:50 AM   #50
wizzo
Drives: 2014 Toyota 86
Can they be used with stock pistons?
wizzo is offline   Reply With Quote
Old 10-14-2015, 10:12 PM   #51
w0wbagger
Drives: GT86
Don't know, didn't ask that.
Old 10-14-2015, 10:31 PM   #52
Hawk77FT
Drives: GTS 86
Still debating whether this will make a noticeable improvement on NA. This might be the last thing that will go on before going SC.
Any dyno graphs?
Hawk77FT is offline   Reply With Quote
Old 10-14-2015, 11:22 PM   #53
Naco
Naco's Avatar
Drives: 2015 Steel FR-S MT
Something to keep in mind guys:
The more aggressive the cam is in regards to valve overlap (cleaner combustion = more power), the worse it'll be for boosted applications. It'll also be worse for states with strict emissions.
In regards to the high flowing heads, I believe that might have something to do with the FA20DIT configuration of this motor. The torque that would have been gained from flow velocity when coupled with a twin scroll turbo would have likely caused some reliability issues with the transmission and transfer case.
This then also bring up: Are the cams different on the DIT motor versus ours?
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
Naco is offline   Reply With Quote
Old 01-04-2016, 08:28 PM   #54
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Are there actually any results from these?
hmong337 is offline   Reply With Quote
Old 01-04-2016, 10:44 PM   #55
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Tim Radley View Post
One thing i forgot to add. The camshafts out of my stock 2014 Toyota GT86 measured up differently to the ones Piper had from a 2012 Subaru BRZ. Lift, duration and pin location were all different. It appears there are variations in stock cams between models.
2013 the motors used different 2 intake valves and lifters. In 2014 they use matching intake valves and lifters. Cams are the same so are the rockers. You can verify on Subaru parts catalog.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 01-05-2016, 07:52 AM   #56
Tim Radley
They measured up the one they had from a JDM Subaru and mine from a UK Toyota. Both were different in the ways i mentioned above. Still confused why but its not the first time i've seen a manufacturer change a spec without issuing a new part number.
Just ordered new Camshafts Fonzi Forced Induction 21 02-11-2018 03:31 PM
Where are all the high lift/duration camshafts! stevo585 Engine, Exhaust, Transmission 35 02-23-2015 07:39 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 02:17 AM
does it make a difference at all in hp from an invida over piper compared to motiv Anthony7515 Engine, Exhaust, Transmission 3 04-07-2014 11:26 PM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 08:35 PM
