Old 08-30-2015, 04:13 PM   #43
Streetthrowback
Drives: 2015 brz
Can't wait for the pkg!
Streetthrowback is offline   Reply With Quote
Old 09-01-2015, 12:09 PM   #44
Mishimoto
Drives: 2013 Subaru BRZ
Thanks! Excited to see your feedback.
-John
Mishimoto is offline   Reply With Quote
Old 09-02-2015, 10:20 AM   #45
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
So just to confirm, this kit is purely for looks or weight, with no notable performance gains?
Do you have any numbers you can share proving slight variances?
Thanks
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Aztec (09-02-2015)
Old 09-03-2015, 01:39 PM   #46
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
I was wondering the same.
Do these fans have higher flow over OEM ?
Is the overall fan shroud lighter or thinner ?
irax is offline   Reply With Quote
Old 09-10-2015, 04:23 PM   #47
Mishimoto
Thanks
Thanks for the comments guys! The primary benefit of this kit is in terms of space savings and aesthetics. Our fans do not outperform the factory units in terms of flow, however they provide extremely similar cooling characteristics in terms of how quickly fluid temperatures can be dropped in long duration idle conditions. Cooling performance will be identical to that of the stock shroud. I do not have any information in regards to the factory shroud weight, however I would have to assume our setup cuts a pound or two from the factory piece (not substantial).
Our fan shroud assembly is thinner than the factory setup, with a lot of the difference being shown around the cage area of the stock fans. Here we were able to free up some additional space, which should help with clearance on vehicles equipped with a turbocharger in the factory airbox area.
Thanks
-John
Old 09-15-2015, 02:42 PM   #48
Mishimoto
Thanks for all of the orders thus far guys! Check out some images of our final product!
Our pre-sale is set to expire at the end of the month!
Thanks
-John
The Following User Says Thank You to Mishimoto For This Useful Post:
FyeaFRS (10-15-2015)
Old 09-23-2015, 10:07 AM   #49
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
What happened to the group buy thread?
axelthrasher is offline   Reply With Quote
Old 09-24-2015, 12:35 PM   #50
Mishimoto
Whoops! Looks like our forum sponsorship lapsed and our threads were removed. We should have our vendor status renewed (and threads restored) by tomorrow.
Just sent you a PM with our pre-sale link!
Thanks
-John
Old 11-13-2015, 02:25 PM   #51
Mishimoto
Thanks again for all of the orders guys. We look forward to any feedback for those who joined our discounted pre-sale. At this time, our pre-sale has expired. For those who would like to pick up a kit, be sure to check with our vendors. Full product information can be found at the link below!
Feel free to follow-up with any questions!
-John
Old 11-16-2015, 04:28 PM   #52
bspec
A man
Drives: 14 BRZed
Confirmed shroud does not fit with Perrin Big MAF 3" Intake. Nice piece though; I'll keep it for when it comes time to do F/I.
bspec is offline   Reply With Quote
Old 11-19-2015, 03:38 PM   #53
Mishimoto
Thanks for letting us know. Sorry the shroud did not work with that particular intake system.
Let us know how it works out for you when FI is added!
-John
Old 11-19-2015, 07:45 PM   #54
Naco
Naco's Avatar
Drives: 2015 Steel FR-S MT
This is looks to be a great product for front mount turbo guys to keep radiant exhaust/turbo heat away from the coolant as well as provide an area for which all airflow will leave the radiator (like they said, pulling from the corners) during fan opperation.
The only downside I see to this setup is that now when moving and air is naturally being forced through the radiator, the covered area now acts as a block since the fan is not running to suck it through the two openings.
I don't know how much it would add to cost, but if you added some flaps in open areas of the shroud it would allow air to bypass the fan opening at speed but flap shut when slow/stationary to focus on fan cooling.
Not much surface area to play with though.
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
Naco is offline   Reply With Quote
Old 11-23-2015, 02:13 PM   #55
Mishimoto
Thanks for the input Naco! Airflow at speed should be very similar to the factory shroud, although the point regarding additional flaps is a great recommendation. We've used these on a few of our recent prototypes and had generally positive results with at-speed flow.
In addition, we've designed a few setups that are more of fan mounts. These are essentially points to secure the fan to the radiator. For these setups, significant airflow is possible during at-speed driving, although it will reduce the efficiency of the fan at idle.
Fan shroud design is give-and-take. Some customers prefer a full shroud, others do not. We can always consider one of these alternate methods as a future design, but we are pretty pleased with our BRZ/FR-S unit.
Thanks again!
-John
Old 11-24-2015, 11:13 AM   #56
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Would it be relatively easy to also wires the fans to a manual on/off switch to run them manually to help maintain lower temps for when say in traffic or other long periods of idling?
I've been using the Mishimoto radiator with my supercharger and will be adding the thermostat as well.
FyeaFRS is offline   Reply With Quote
Can I plug and play this amp? 7thgear Electronics | Audio | NAV | Infotainment 4 04-11-2015 04:26 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
