Old 04-17-2015, 02:49 PM   #43
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by aagun View Post
Where are u from .. Worm weather ?
Di u have poping . While idle
Go rich cozed by air leakage after maf . Up to afr sensor. . . Or injectors failure by leaking fuel or reduce fuel rate .
Not sure what you mean by popping by I don't hear any popping.
It's been 60-80 degrees here in the past few weeks.
The Following User Says Thank You to Synack For This Useful Post:
King Tut (04-20-2015)
Old 04-17-2015, 02:50 PM   #44
Synack
Boosted
Synack's Avatar
Drives: Sideways
Fuel rail should 450psi to 650psi at idles and up to 2000psi or 2800psi at wot
Those idle numbers are exactly what I'm seeing, I will check WOT to see if it's 2000-2800.
Old 04-17-2015, 03:33 PM   #45
aagun
Drives: 86
Originally Posted by Koa View Post
not true, STFT and even LTFTs will vary above and below 0% if the system is operating as normal to account for variances in fuel quality and atmospheric conditions above what the car was tuned for
all your other advice is sound
we have to know what is hes ltft . should ecu try correction fueling maps
it happens to me , one of my DI failure by reduce inject fuel from the DI.
so that will insurance fuel trim.
ok for example.
if the car @ 3000 RPM with 14.7 AFR and 0% LTFT and 20% inj duty each . THAT means 14.7/4 inj = 3.675 AFR each .
if one of inj failure and have 3.0 AFR with same duty and RPM (engine load).
so then the total of AFR is 3.675*3 inj + 3.0*1 inj =14.025
the ECU try correct the fuel by adding fuel to all 4 inj until it stop at 14.7 AFR TOTAL .
SO ECU ADD FUEL BY THIS (14.7 AFR - 14.025 AFR) / 4 inj = 0.16875 AFR insurance each inj
it will be ( 3.675 AFR + 0.16875 AFR ) * 3 + (3.0 + 0.16875 AFR) = 11.53125 + 3.16875 = 14.7 AFR (ecu happy )
but the LTFT will be (0.16875 AFR /3.675 AFR) * 100 = 4.591%
so the LTFT will be +4.591%
aagun is offline   Reply With Quote
Old 04-17-2015, 04:14 PM   #46
aagun
Drives: 86
poping is misfire
Old 04-17-2015, 08:43 PM   #47
Synack
Boosted
Synack's Avatar
Drives: Sideways
poping is misfire
Haven't had any of that yet. Just crazy AFR's. I also just checked fuel rail pressure at WOT and it was upper 2000's, even hit 3000 once.
aagun (04-18-2015)
Old 04-18-2015, 02:58 AM   #48
aagun
Drives: 86
what is your ltft at idle . better post here log data
Old 04-20-2015, 11:32 AM   #49
Synack
Boosted
Synack's Avatar
Drives: Sideways
We've determined (Doug Wilks) that the tune is super old (>2 years) and over time the engine will run richer the more things start to settle and break in. So it's running super rich and needs a fresh tune. We did run logs with Ecutek and it didn't seem that the car had any issues, but we are still unsure of the erratic idle AFR's.
@Reaper and I installed the Moto East flex fuel kit yesterday and the Full Blown 485LPH fuel pump. I'm going to get the car fresh tuned for E85/93 any week now. Hopefully the new turbo and tune will fix everything.
aagun (04-20-2015)
Old 07-07-2018, 11:15 AM   #50
Dru670
Drives: 2016 Scion FR-S
Did you solve this issue?
Dru670 is offline   Reply With Quote
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 01:55 AM
So what would you say is too Lean? Too Rich ? Opinions Pls. BC-Boy Software Tuning 27 05-29-2014 10:05 PM
POST YOUR 1/4 MILE TIMES Quarter mile times NYCsubaruBRZ Tracking / Autocross / HPDE / Drifting 1 02-04-2014 06:59 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-25-2013 11:42 PM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 11:36 AM
