Old 03-08-2015, 11:09 AM   #43
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Koa View Post
True peace of mind is running a flex fuel setup just no way around it
Do you get more than two maps when you get set up for flex fuel?
Old 03-08-2015, 11:13 AM   #44
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The whole point of flex fuel is to do away with the hassle of multiple maps.
Old 03-08-2015, 11:21 AM   #45
cjd
cjd's Avatar
Drives: 2017 BRZ
Bah, I said that wrong I think - or I misunderstood completely how it works. It swaps tables, right? How many table variations do you get? (I won't be running e85 since I AutoX, just curious.) Though we're probably in the wrong thread now.
Old 03-08-2015, 11:54 AM   #46
s2d4
s2d4's Avatar
Originally Posted by Phantobe View Post
ut I had very high fuel trims (18% ish) due to the high ethanol content so I know the tune doesn't adjust to the ethanol content. \
Umm, that is exactly what it's doing.
I know a decent amount about tuning but I don't know what would have to be adjusted to make these changes, I wouldn't go as far as to say it's impossible.
Yeah, not impossible but if you know a decent amount about tuning, you'll probably know that it is a waste of time unless using flex fuel setup.
Also, higher e is hardly as detrimental as no e and excess timing, to a certain degree of course but it can run leaner and less det prone whilst doing so.
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
Phantobe (03-08-2015), Turdinator (03-09-2015)
Old 03-08-2015, 11:30 PM   #47
Koa
Flexfuel setups dynamically adjust to the exact octane in your tank. No multiple maps- sensor analyzes fuel mixture and alters timing/fuel accordingly.. of course many different approaches but the point is, that kind of dynamism is not offered in non-flex sensor setups
Opens up a whole new world of possibilities on how to approach running multiple fuels on your rig. $1000-1600+ depending on the exact setup, but it's the only thing I would consider for serious builds or those who switch fuels often (more than a couple times a month)
The higher the HP/loads the engine sees, the more important it is to have a tune and sensor setup capable of accounting for significant variances in anticipated fuel composition
The Following User Says Thank You to Koa For This Useful Post:
cjd (03-09-2015)
Old 03-09-2015, 04:22 PM   #48
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Flex fuel is really just a pump gas tune and an e85 tune put together. The flex fuel sensor determines where the current fuel mix will fall between the two tunes of the individual maps in the tune. The custom maps in ECUTEK fill in the gaps between the two tunes and use a blend of the two to get the correct settings for the fuel mix you are using. You could make your own tunes by figuring out where your mix of fuel falls between the two tunes (pump and e85). It will require you to do some math and an extra flash between but it could be done so you don't have high fuel trims.
Toyota John is offline   Reply With Quote
Old 05-03-2015, 10:45 PM   #49
dar3d3vil
dar3d3vil's Avatar
Drives: 2015 BRZ Limited
Originally Posted by Shiv@Openflash View Post
To be honest, it's not something that we have ever looked to do. I've driven OEM cars with perhaps the best implemented example of auto-blip and they are still infuriating. Plus, I don't feel comfortable with implementing code that effectively takes control of the throttle under any circumstance.
That is definitely on the short-term To Do list
Any word on an ETA? I know this was posted back at the beginning of March, so just wondering where things stand as we enter May?
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS
dar3d3vil is offline   Reply With Quote
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
OpenFlash Tablet Update (Template and Tuning Alerts) Shiv@Openflash Software Tuning 60 04-13-2016 05:59 PM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
WTB OpenFlash Tablet TONY_BRZ Want-To-Buy Requests 0 08-01-2014 05:28 PM
