#43 |
Joying-USA
Drives: Highlander 08
Just wanted to drop in and let you guys know that I am the only authorized reseller and repair center in USA fro Joying android head units.
If you buy your head unit through me you will get USA warranty and you can avoid dealing with china. I am based in New York and stock many models. JoyingUSA gmail |
#44 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#45 |
Drives: '13 Firestorm FRS
I really want a factory fitting unit that runs Android and can play music-videos. Also need something to deal with the 8" after market sub I plan on getting. This looks like it could be it.
I'm guessing there are no restriction on this unit in terms of when it can or can't play videos (like, it will play videos even if you are driving) |
#46 |
Correct, there are no restrictions. I'm still very happy with this unit.
#47 | |
Drives: gt 86
http://www.aliexpress.com/store/prod...365437350.html |
#48 |
No, I never got it to work and gave up on it once I was able to root my phone and begin tethering.
#49 |
Drives: gt 86
also did you have to shave off any of the bezel on the head unit to make it fit or grind of the dimples on the factory brackets? or did it just fit right out of the box?
also what firmware are you using? and is the mic on the unit like really bad? is it usable for the odd phone call? the mic is part of the head unit right? |
#50 | ||
Using the latest by Malaysk http://forum.xda-developers.com/show...8#post66437888 Quote:
Yes, it's built-in, there is a little hole on the front of the unit. You can replace this but it requires some DIY\electronics skills and know-how. |
#51 |
Drives: DGM BRZ
What's the easiest way to update firmware without wiping everything?
#52 |
Drives: gt 86
thanks for your help, also you said
it looks like this unit has a plug at the back that allows you to plug in an external mic, have you tried that? |
#53 | |
Based on what I've read, to use a new mic for bt calls, you must open the unit and solder a new mic/new mic leads onto the bluetooth circuit board. You can then mount the mic outside of the unit. |
#54 | |
Joying-USA
The external mic is highly recomended to be used instead of the internal mic for phone calls. just plug the included ext mic in the back of the headunit. |
#55 |
Joying-USA
#56 | |
Drives: gt 86
| Loading android phone contacts into radio | Roadstercycle | Electronics | Audio | NAV | Infotainment | 8 | 05-21-2019 12:59 AM |
| Sony Head unit lets you use your Android phone as a car radio | Mad1723 | Electronics | Audio | NAV | Infotainment | 4 | 01-09-2014 06:18 PM |
| Noticeably low and sharp volume with AM radio stations with stock BRZ radio | tracerit | Electronics | Audio | NAV | Infotainment | 0 | 07-24-2013 02:38 AM |
| Radio, Iphone?? Radio cuts out when surfing the web | Fugazi | Electronics | Audio | NAV | Infotainment | 5 | 07-30-2012 11:24 AM |
| Android vs iOS vs BB os...which is best? | Raiden | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 02-02-2011 10:37 PM |
