Old 05-08-2016, 12:47 PM   #43
doctorman
Joying-USA
Drives: Highlander 08
Just wanted to drop in and let you guys know that I am the only authorized reseller and repair center in USA fro Joying android head units.
If you buy your head unit through me you will get USA warranty and you can avoid dealing with china.
I am based in New York and stock many models.
JoyingUSA gmail
doctorman is offline   Reply With Quote
Old 05-08-2016, 06:07 PM   #44
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
JoyingUSA gmail
Thanks for the heads up, chief.
B-R-Z is offline   Reply With Quote
Old 05-18-2016, 09:29 PM   #45
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
I really want a factory fitting unit that runs Android and can play music-videos. Also need something to deal with the 8" after market sub I plan on getting. This looks like it could be it.
I'm guessing there are no restriction on this unit in terms of when it can or can't play videos (like, it will play videos even if you are driving)
sittinSideways is offline   Reply With Quote
Old 05-18-2016, 10:00 PM   #46
B-R-Z
B-R-Z's Avatar
Correct, there are no restrictions. I'm still very happy with this unit.
Old 05-20-2016, 03:35 AM   #47
rsingh
Drives: gt 86
Originally Posted by B-R-Z View Post
Internet:
It was $20 to sign up which included 2 devices--one that provides internet wirelessly, and the other is a USB dongle. I am still working on getting the dongle to work through discussion with the developer of PPP Widget.
[/I]
where you able to get your dongle to work? it appears this dongle may be compatible
http://www.aliexpress.com/store/prod...365437350.html
rsingh is offline   Reply With Quote
Old 05-20-2016, 06:30 PM   #48
B-R-Z
B-R-Z's Avatar
No, I never got it to work and gave up on it once I was able to root my phone and begin tethering.
Old 05-20-2016, 11:18 PM   #49
rsingh
Drives: gt 86
also did you have to shave off any of the bezel on the head unit to make it fit or grind of the dimples on the factory brackets? or did it just fit right out of the box?
also what firmware are you using?
and is the mic on the unit like really bad? is it usable for the odd phone call? the mic is part of the head unit right?
Old 05-21-2016, 01:08 PM   #50
B-R-Z
B-R-Z's Avatar
It fit out of the box for me.
Using the latest by Malaysk
http://forum.xda-developers.com/show...8#post66437888
Yes, it's bad. Im not sure how bad as I am always on the talking end.
Yes, it's built-in, there is a little hole on the front of the unit. You can replace this but it requires some DIY\electronics skills and know-how.
Old 05-22-2016, 01:21 AM   #51
dchan
Drives: DGM BRZ
What's the easiest way to update firmware without wiping everything?
dchan is offline   Reply With Quote
Old 05-22-2016, 01:35 AM   #52
rsingh
Drives: gt 86
it looks like this unit has a plug at the back that allows you to plug in an external mic, have you tried that?
Old 05-22-2016, 10:34 AM   #53
B-R-Z
B-R-Z's Avatar
IIRC, this is not for bluetooth mic, this is something else. If you read through the XDA thread there is probably more info on it.
Based on what I've read, to use a new mic for bt calls, you must open the unit and solder a new mic/new mic leads onto the bluetooth circuit board. You can then mount the mic outside of the unit.
Old 05-22-2016, 08:06 PM   #54
doctorman
Joying-USA
The external mic is highly recomended to be used instead of the internal mic
for phone calls.
just plug the included ext mic in the back of the headunit.
Old 05-22-2016, 08:06 PM   #55
doctorman
Joying-USA
anyway you want , just do not chose wipe data
system>about machine>update
or Recovery
Old 05-23-2016, 08:16 AM   #56
rsingh
Drives: gt 86
and to install that firmware RK3066 800X480 or RK3188 800X480 i just copy the mcu.img and update.img to the root of the sd card and install? I assume that firmware is pre rooted and I should be good? also do you use google maps does that have a voice search feature?
Loading android phone contacts into radio Roadstercycle Electronics | Audio | NAV | Infotainment 8 05-21-2019 12:59 AM
Sony Head unit lets you use your Android phone as a car radio Mad1723 Electronics | Audio | NAV | Infotainment 4 01-09-2014 06:18 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 02:38 AM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 11:24 AM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 10:37 PM
