Old 12-31-2014, 04:04 PM   #43
stugray
Drives: 2013 GBS BRZ Limited
As I stated above: IF the buyer KNOWS there is a tune that is FINE.
But if someone sold one and the buyer did not KNOW about the tune, then it is Fraud plain and simple.
You have purchased an altered item when you expected stock.
And if the dealer finds out you have been running a tune they can deny ALL engine and transmission warranty work for the future.
For all of you that think that is fine... interesting world you live in.
And I suppose you all think it is perfectly OK for the seller to NOT mention this OR provide the license info?
The Following User Says Thank You to stugray For This Useful Post:
phobos512 (12-31-2014)
Old 12-31-2014, 04:50 PM   #44
Ultramaroon
not playing cards
Ultramaroon's Avatar
Of course failure to disclose is bad but OP expressed nothing but delight for having discovered his tune. Then you came spreading Debbie Downer all over the place.
ImBatman (01-01-2015)
Old 12-31-2014, 06:05 PM   #45
QuickShift86
QuickShift86's Avatar
Drives: 2013 White FRS
+ This
QuickShift86 is offline   Reply With Quote
Old 12-31-2014, 06:17 PM   #46
QuickShift86
Yes you will need to buy ecutek cable
or some tuners rent them out
or just go to or talk to ecutek tuner and they should be able to help you get licience info you need, their may be fee to reissue licience/dongle.
toyota/subaru Dealer will not be able to reflash car with ecutek racerom installed they are locked out.
they will be able to run standard diagnostics though.
Should you need dealer reflash you will need to reflash a "stock" ecutek rom with appropriate ecutek cable and licience. or ecutek tuner can do this. This then allows dealer reflash, but it will wipe your ecutek licience from ecu, they can be reissued though.
try the ecutek vendors/tuners guys on this forum
delicious tuning , moto-mike ect sure they will help you out it was probably tuned by them anyway
See, this is what people need, someone giving guidance through experience and knowledge.
Now with the dealership still being able to run standard diagnostics, can they find out that its tuned?
Again thanks for the input.
Old 12-31-2014, 07:02 PM   #47
stugray
Definitely
Not only that, but they will know just by driving it.
Old 12-31-2014, 09:34 PM   #48
steve99
Can they work out its tuned well debatable and depends if they are looking.
If its going in for service and no engine related issues and it not a car flagged for a reflash then they are just going to kick the tyres and change the oil ect and plug in diagnostic analyser find no cel codes and its all sweet.
if you have mods such as headers or intakes that are visible they will oftem blame these mods for engine problems regardless of weather they are the cause.
if you have engine related issues return these to stock before dealer visit saves heaps of hassle.
A tune is not obvious to dealer unless they are looking for something.
dealers just do diagnostics and reflash ecu with a complete rom if their is a TSB issued for that vehicle vin or some other issue.
their sofware afaik just reflashes they dont have ability to read and then inspect the current rom, they just get a readout of the calibration id of the rom, most tuned roms will just be same calid as was stock.
If they attempt to reflash it will fail with ecutek racerom loaded, then two things might happen,
They assume ecu is borked and replace it under warantee
They look further especially if you have visible mods, if they call in the specialist guy or they have someone savvy that pulls the curise stalk and tweeks to map switching then your going to have problems
On a stock car the differences are not that great so just driving it may not flag its tuned.
If their is no issue with the car its unlikley they will find anthing or care
it when you have faults the problems start
The Following 3 Users Say Thank You to steve99 For This Useful Post:
FRSBRZGT86FAN (10-16-2015), QuickShift86 (01-01-2015), Ultramaroon (12-31-2014)
Old 12-31-2014, 10:09 PM   #49
Ultramaroon
not playing cards
If its going in for service and no engine related issues and it not a car lagged for a reflash then they are just going to kick the tyres and change the oil ect and plug in diagnostic analyser find no cel codes and its all sweet.
if you have engine related issues return these to stock before dealer visitsaves heaps of hassle.
tl:dr rekt
Old 12-31-2014, 10:17 PM   #50
Ultramaroon
not playing cards
BTW, Steve, I read with enthusiasm everything you post. I've had a Tactrix for months and am considering easing my way in from the deep end. Thanks for sharing and for your most thoughtful presentation. Bravo, sir.
steve99 (12-31-2014)
Old 12-31-2014, 10:52 PM   #51
steve99
Its not hard at all, just get your head arround what your doing, follow some simple precautions like any oher flashing tool and it will be fine , if you have any questions just ask.
just use your tactrix to read rom from your car at first, look at the rom you read out.
flashing is robust unless you do somethng crazy like turn off ignition mid flash.
all the issues are people using incrrect definitins to edit or flash a rom
Old 01-01-2015, 03:33 AM   #52
stugray
you can tell a tuned car by the idle behavior at startup alone.
But you have to be fairly familiar with these cars to know how they behave.
steve99 (01-01-2015)
Old 01-01-2015, 04:14 AM   #53
steve99
To most dealers it just another car and another job , most times the 1st or second year apprentice is doing the scheduled maintenance and unless theirs an issue the experienced guys dont generally look at it.
Old 01-01-2015, 01:33 PM   #54
QuickShift86
What is the tendency for a tune car during idle? Is your car tuned?
Old 01-01-2015, 02:30 PM   #55
stugray
One of the first things tuners fix is the idle warm up RPMs.
I noticed it the first time I started a car after a new tune.
Old 01-01-2015, 02:54 PM   #56
steve99
They would probably notice rev matching feature on manual car with ecutek tune if enabled.
Matching HID's and DRL's red_ZN6_4_you Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2014 03:09 PM
Openflash rev matching cjsporl1996 Software Tuning 6 12-19-2013 12:04 AM
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 02:03 PM
AT BRZ - stopped rev matching... ray7792 BRZ First-Gen (2012+) — General Topics 2 10-31-2013 08:24 PM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 06:48 PM
