Old 01-06-2015, 04:22 PM   #43
Rosticles
Drives: 1966 Mustang, 2013 FR-S
I agree that is the definition of a PCVV or PCV valve. I am still not convinced that is what is installed on this motor. All non OEM forced induction motors should never see positive pressure heading towards the crankcase.
They are made to stop a backfire from blowing back into the crankcase. This is a safety concern. That is only an impulse of pressure, however, and not at the same level as fi.
Rosticles is offline   Reply With Quote
The Following User Says Thank You to Rosticles For This Useful Post:
kbogarto (01-07-2015)
Old 01-08-2015, 04:01 PM   #44
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
Can anyone tell me where to buy the appropriate pcv check valve? Also im running radium dual catch cans, where do Install it exactly? Thanks and sorry if this was already mentioned.
AZbrz89 is offline   Reply With Quote
Old 01-08-2015, 04:06 PM   #45
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Check valves should always be placed in the hose between the intake manifold and whatever is on the other end of the hose.
Old 01-08-2015, 04:10 PM   #46
AZbrz89
@King Tut does it matter where exactly it should be placed whether it be closer to the manifold or other end? Or somewhere in the middle? Sorry for the stupid question lol Thanks
Old 01-08-2015, 04:49 PM   #47
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It doesn't matter.
Old 01-08-2015, 09:56 PM   #48
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I bought 3 check valves from US Plastics when I ordered mine, because shipping was so high and the valves were only a couple of bucks each. Do you ever come up to Phoenix?
http://www.usplastic.com/catalog/item.aspx?itemid=36844
It's a 3/8", so I just took some 3/8" hose and drilled a little out of the ID at both ends to connect it to the catch can and manifold.
They also have these, which would probably work:
http://www.usplastic.com/catalog/item.aspx?sku=22252
alexand3r is offline   Reply With Quote
The Following User Says Thank You to alexand3r For This Useful Post:
AZbrz89 (01-08-2015)
Old 01-08-2015, 10:16 PM   #49
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
This is a pretty good picture right from the Vortech install...
9b is the check valve up close and then 9a and 9c show it installed in the hose.
Jman1759 is offline   Reply With Quote
The Following User Says Thank You to Jman1759 For This Useful Post:
Efferalgan (01-11-2015)
Old 01-08-2015, 10:58 PM   #50
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Does the radium catch can have 3/8 inner tube or 1/2 inner tube diameter.
Installed Mods:
Old 01-08-2015, 11:37 PM   #51
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I think that they may be interchangeable on the Radium cans (not sure what it comes with, though).
I have a Saikou Michi set, which has a 3/8" connection for the PCV line and a 1/2" that goes to the manifold (which is also takes 1/2" ID).
Old 01-08-2015, 11:45 PM   #52
AZbrz89
No I haven't been driving it much since I've owned it. Im going to start attending the tucson meets. Im in the process of buying all my performance parts first and have them installed before I install my supercharger and tune it. Getting all my facts straight lol
Old 01-08-2015, 11:58 PM   #53
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Good job, doing your homework can keep you from kicking yourself in the ass later.
If you want some kind of check valve baller status, you can use a Boomba:
http://www.boombaracing.com/check-valve-12-mm-1-2/
Maybe a little over the top, but they look nice and seem to get good reviews.
PM me your address if you don't mind the idea of thinning the inner wall of some 3/8" hose, I'll ship one of these down to you. Only things you'll need are 3/8" hose, some hose clamps and a way to drill the center of the hose a bit (I used a stepper bit).
EDIT: Sometimes a picture is worth a thousand words:
The Following 3 Users Say Thank You to alexand3r For This Useful Post:
DAN_BRZ (03-10-2015), Efferalgan (01-11-2015), WRB5titch (01-13-2015)
Old 01-09-2015, 12:13 AM   #54
AZbrz89
That boomba is dope. I think the hose is 3/8" so I would just need to lubricate with my spit and on each end and out her on. Thanks for the offer though!
Old 01-09-2015, 12:16 AM   #55
AZbrz89
It says on radium website 1/2" pcv hose boomba here I come lol
Old 01-09-2015, 12:16 AM   #56
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
No problem. I fought with it for a second and then went straight for the drill.
Yeah, the Boombas look nice and take half the pressure of mine to open (not that it really matters, but nice).
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 07:38 PM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 01:06 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
FS: Synchronic Diverter Valve Kit FReSh_86 Engine, Exhaust, Bolt-Ons 0 11-26-2013 03:21 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 10:42 PM
