Old 06-04-2016, 09:57 PM   #43
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
looks ok
Is there any power to gain if I lean out a bit ? How would I go about it safely
el-92 is offline   Reply With Quote
Old 06-05-2016, 12:50 AM   #44
steve99
nope its running mid to low 12 upper rpm which is where is supposed to be
Old 06-05-2016, 12:49 PM   #45
el-92
el-92's Avatar
Alright good to know one more thing does the maf look good I haven't touched it
Old 06-05-2016, 07:20 PM   #46
steve99
maf scaling looks ok, ots generally fine unless you change intakes. You can always get it better with custom scaling but unless your having bogging or hesitation issues or afr is way off, but you look ok so probably not worth the hassle
Old 06-07-2016, 02:45 AM   #47
el-92
el-92's Avatar
Forsure thanks and I'm not having either of those Issues so I'm going to leave it alone and enjoy it
Old 10-30-2016, 05:06 AM   #48
slofy
Drives: gt86, mx83, lx80
Hi, this may be dumb, but I'm confused a little about the definitions. I have the 700G ecu but in the xml folder there is only an RR file for the 700G (not OFT) and only a OFT file for the D00G. Do I tune from the new D00G definitions and use the OTS D00G .bin file?
slofy is offline   Reply With Quote
Old 10-30-2016, 07:29 AM   #49
steve99
If your using tactrix just use A01G roms and defs (you will need ecuflash a01G def to flash)
if your using oft and your original rom was 700G then use the oft 700G rom and the oft 700G tune rom ( these are actually a01G internally) but the oft will only let you use 700g roms same as original.
Old 10-30-2016, 07:33 AM   #50
steve99
AFAIK romraider guys never defined a genuine 700G rom so no romraider or ecuflash 700G defs exist, only tje calod hacked 700G oft rom and def which are actually A01G
If your using oft use the roms and defs from oft website only and from same tune revision dont mix defs and tunes from deferent revisions
Old 10-31-2016, 03:58 AM   #51
slofy
Makes sense now, thank you sir!
Old 04-14-2020, 08:08 PM   #52
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Hi Steve. I have successfully flashed OFT A01G to my car. Main reason was to raise idle RPMs, aside from the obvious performance gains.
I am trying to make the fans come on sooner. In this Florida heat, the AC struggles to get cold unless the fans are basically full blasting as soon as I turn it on.
I have made these changes on Ecutek and Motec, but they seemed easier to understand then on Rom raider.
Can you guide me on what tables and what recommended values should I input on the tables? Any examples? Today it was scorching hot and I opened the hood to check fan speed because the AC was struggling on red lights and the fans seemed to be running at a low speed. Once I got the car running, the natural circulation got the AC super cold. After I let the car idle for a while to get it to a hot temperature then the fans finally ran at full speed and were able to help the AC cool down on stop lights.
Thanks in advanced!
Old 04-15-2020, 05:17 AM   #53
steve99
Thanks in advanced!
Use the tables that start with 190.4, just make both fan tables same
Just change fan modes tables A and B
Old 04-15-2020, 08:46 AM   #54
Sportsguy83
Drives: Limited BRZ
Thanks a lot!I appreciate it very much!
Old 11-18-2020, 01:13 PM   #55
Compelica
Compelica's Avatar
Drives: 86 GT
Does anyone have the OFT K01I definition? OFT's website doesn't provide them.
Compelica is offline   Reply With Quote
Old 11-18-2020, 03:29 PM   #56
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's going to sound weird, but download the K00D definition.
The K00D are actual K01I, so the definition works for a 'real' K01I.
But you have to edit the definition file to make it work with the K01I rom.
Open it with a text-editor (Notepad++) and change the 2 lines that states ZA1JK00D to ZA1JK01I.
Save and open in RomRaider.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
need some help with romraider logger toyotaAlex Software Tuning 2 07-06-2014 07:07 PM
New ZA1J#02# base files 86drift Software Tuning 1 05-22-2014 03:43 AM
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 11:24 AM
Simple way to open .iso files notout86 Off-Topic Lounge [WARNING: NO POLITICS] 19 05-11-2013 07:12 PM
