Old 12-03-2014, 02:35 AM   #43
bobka7914
Drives: ‘22 BRZ, ‘18 Crosstrek
Had the same problem on BOTH of our Subarus last January. Our garaged 2013 Outback went to the dealer for an oil change. A tech came out to me in the waiting room and said there is something that I had to see. He showed me the hood insulation- it was pock marked with 2-3" diameter holes, maybe 10 or so of them. Mice were hungry. They he pointed down to the firewall insulation- this time those nasty critters ate/took almost the whole left side of the firewall insulation off, basically completely stripped! He said that the insulation was soy based and they eating it and/or using it as nesting material. The car was traded for a '15 Outback a few months later with nothing said!!!
After that unpleasant experience, I figured I better check my BRZ that is left in the driveway when I got home. Yes, the mice started eating the hood insulation off of my baby too! Thankfully, not nearly as bad as the Outback. I check the fluid level every 2 weeks, so all of this damage must have taken place in a matter of a week or two last January. Yes, the Outback (my wife's) is garaged, not my BRZ. For those of you who are married know that a Happy wife = a Happy life!
I did some research and found that peppermint oil extract will keep the mice away. So I soaked a couple of my wife's make-up cotton balls with a little mint extract and placed them in the inside of the BRZs hood holes. Works like a charm. No mice. We also use this method in our garage and basement. Smells good, no mice there either!
bobka7914 is offline   Reply With Quote
The Following 2 Users Say Thank You to bobka7914 For This Useful Post:
Sisko's_Baseball (11-25-2025), Ultramaroon (12-03-2014)
Old 11-25-2025, 02:30 PM   #44
Sisko's_Baseball
Sisko's_Baseball's Avatar
Drives: 2016 HyperBlue
Willing to try this, because the little effers got into my trunk and my back seat. Not sure how, because I keep the car closed and locked (ditto for windows), but they pulled the Kleenex out of a tissue box I keep in the trunk and made a big fluffy nest out of it. Why these little guys go to the toilet where they sleep is beyond me. On my way to the dealer now for a closer inspection of where they’re getting in and whether anything else got chewed up.
Sisko's_Baseball is offline   Reply With Quote
Old 11-25-2025, 05:14 PM   #45
Ohio Enthusiast
Drives: 2018 BRZ
I'd check two places - in the spare wheel well there are a few holes to the ground covered with semi-reusable stickers (useful to drain the trunk if you got water in it); behind the trunk side carpeting (held on by several plastic clips) there are the air vent panels which lead to the area between the wheel well liner and rear bumper.
Also, Halloween was almost a month ago, but great necromancy on this thread.
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
DarkPira7e (11-25-2025)
Old 11-25-2025, 06:17 PM   #46
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I think where the transmission enters the car interior is also a convenient place for them to enter. And the firewall holes, cabin air filter.
The easier thing to do is leave the car where there are less likely to be mice, if that's possible
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 11-28-2025, 01:19 PM   #47
Lantanafrs2
Drives: 2013 frs red
I had one chew a hole in my rear seat. I also found knaw marks on my ac vents.
Hungry Mice In Engine Compartment bobka7914 BRZ First-Gen (2012+) — General Topics 9 07-16-2014 02:08 PM
i found mice poop on top of engine... Maruthas Engine, Exhaust, Transmission 18 12-27-2013 06:59 PM
mice in engine.... decoratordm DIY (Do-It-Yourself) Guides 21 03-23-2013 08:09 AM
rats or mice chewing under hood decoratordm CANADA 3 01-08-2013 04:36 PM
