Old 02-18-2013, 06:41 AM   #43
jstans84
Drives: Scion FR-S
Originally Posted by DarrenDriven View Post
Resurrecting this old topic because I just found the image of this spoiler through Google Images and I WANT! There never really was a positive ID and link posted, so let's give it another go. Can anyone identify the solution for us to buy this?
I want as well, I would probably chop off at least a toe for that wing.
jstans84 is offline   Reply With Quote
Old 05-06-2013, 04:13 AM   #44
Frs x3
Likes it in the rear
Frs x3's Avatar
Drives: RS 1.0
Anyone ever get the best reference for getting this bad boy fit on the frs? I really want this wing.
Frs x3 is offline   Reply With Quote
Old 05-06-2013, 04:26 AM   #45
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Anybody want to take a 300$ gamble lol
http://www.ebay.com/itm/Wing-NISSAN-...item2c6eade198
I'd love to know because I saw the tommy Kari spoiler that looks awfully close.. And love it..
Gixxersixxerman is offline   Reply With Quote
Old 09-01-2013, 09:38 AM   #46
Ahmeda
Drives: Honda civic, soon to be FRS
Which one of them is a direct fit? I love the look of this spoiler and I want it, but I'm not really willing to risk $400 just to test it out so anybody know if its a direct placement or not?
Sent from my iPhone using Tapatalk - now Free
Ahmeda is offline   Reply With Quote
Old 01-11-2014, 06:52 PM   #47
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Alright to revive and put the already known to rest...
They should make this spoiler utilizing the factory bolt hole locations.
This spoiler is very expensive to make in terms of spoilers. People already complaining about the Nur spec or spoiler being 1k+... this spoiler from Nissan is already higher without buying the led brake light.
The factory BRZ limited and GT86 spoiler bolt holes wouldn't be usable anyways as you would still have the 5 holes across the back for the push pins. If you wanted it to utilize the outside bolt holes you'd also have to make the GT-R spoiler wider. Regarding the 5 other holes, you can see them in Alan's pictures of his car as he just stuck squares or Red vinyl over them...
Carbon Fiber spoiler anyone?
Careful buying a CF GT-R spoiler. Anything below $1000 will be either junk or a one piece spoiler without the brake light. Keep in mind the spoiler will not fit on the 86's trunk without modifications so you would need to be very good a CF work and re-wrap the spoiler after extending the bottom of it if you wanted it unpainted...
The GT-R spoiler is actually 2 halves...
This spoiler is 8 parts from the factory all the plastic being made of ABS or optional Dry Carbon on a few versions (Track Pack and maybe Black Edition.)
-top boomerang half
-left support
-center support pillar
-right support
-led brake light
-brake light cover
-left bolt hole cover
-right bolt hole cover
The center pillar is removable. The bottom part of the pillar on the GT-R uses an alignment pin and 2-sided tape. You can easily remove the push pin and just use 2-sided tape for installing it on the 86. The top part of the center pillar is held on with 2 screws. You must remove the 3rd brake light cover to remove the center part. There is a 1"X1.75" hole in the bottom side of the spoiler when it is removed though... On the perfect day on polished paint you will see it in the trunk lid's reflection. Anyone with stock orange peel need not worry.
The side supports are held on with 3 nuts on studs. Without the center support there is a noticeable tension on the seam where the parts meet and the spoiler "droops" a bit.
There are 2 kinds of GT-R spoilers...
Correct and incorrect in you post. There are 2 kinds available from the factory. The first style was produced mostly on preproduction vehicles from 2005-2007. The style we are talking about is the production version and produced from 2007-2014. Out of the 2nd style spoiler there is also a difference. 2009-2014 had an LED light.
Here is a picture of the first style spoiler. Kinda similar to our Trust/Greddy spoiler...
2 different kinds of bottom supports...
Nope all GT-R have had a flat decklid. Alan has modified his or had it done himself. The molding work is good but, noticeable in a couple of the first pictures. (The 2nd one down)
Finsihed* with third support...
So the guy who own's the red car with the GT-R spoiler goes by 4-sama. I'll save you the hours of clicking links and scrounging through useless shit for the pictures you want to see.
Here is his blog (google trans link to english) http://translate.googleusercontent.c...S7CDybE_BQIU2w
He is apparently still working on the spoiler. The last update I can find is in the form of a video in which he has motorized the top half of the spoiler to raise us like some supercars have... looks kinda weird but, provided me with the information to confirm it was made from an OEM spoiler as well as a better look at the molded-in bottom parts.
[ame="http://www.youtube.com/watch?v=inN9hjpiDek"]86ˆ可‰‚‚ƒ‚‰ - YouTube[/ame]
And lastly the pictures from his blog...
Here are a couple pics of my GT-R spoiler sitting on my decklid. It will be rather annoying to make this spoiler work since this car ATM is my DD might halve to wait a bit until summer so my other ride can become my DD.
@chanomatik
The Following 9 Users Say Thank You to Kiske For This Useful Post:
chanomatik (01-13-2014), denkigrve (01-21-2014), dori. (02-09-2014), Gixxersixxerman (01-21-2014), JonAvalon (01-12-2014), mezdup (02-08-2014), soundman98 (05-15-2016), tr1x5tuh (01-21-2014), Vracer111 (01-12-2014)
Old 01-12-2014, 12:57 AM   #48
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Super props to someone who revives an old topic and actually makes it usefull! Thanks!
The Following User Says Thank You to DarrenDriven For This Useful Post:
Old 01-13-2014, 11:36 AM   #49
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Loving it! I like these custom one-off jobs. So unique. Not crazy about that spoiler with the CF half rising, but to each their own. Sounds like getting a new trunk would make things easier concerning the extra holes left by the Limited's spoiler.
Thanks for the write-up! Very, very informative.
Old 01-14-2014, 11:07 PM   #50
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Here is where I am at, with making my spoiler fit.
Basic Rundown is.
1. Made a FG mold of the trunk.
2. Sat spoiler on car, marked and drilled holes.
3. Only one or the 3 studs (on each side) is long enough to go through the sheet metal due to the shape. The 2 outter-most on each side got nice long jamming nuts added to the studs. which were cut to size I will then use a 10mm bolt for them.
4. Pop FG mold off trunk. Sit back in place and align spoiler on it.
5. Make a couple alignment marks for repositioning.
6. Grind top off fiberglass and bottom so spoiler with 24 grit roloc discs.
7. Used 2pt SEM's Panel Bond Adhesive to bind the spoiler to the fiberglass.
8. Bolt the spoiler onto the decklid to clamp the 2 halves together. Wait 24hours.
9. Unbolt spoiler. And using tin snips I trimmed the fiberglass mold of the trunk down to size.
10. Using the left over hardened fiberglass I made some wedges to use as the sides of my mold. I then glassed them into place with fresh FG mat.
11. Let cure and then grind with 24grit disc to rough the surface and spoiler sides up. Applied 3M's 2pt ABS Repair structural plastic to the outside embedding the FG sides roughly shaping it to the final contour.
12. sand a repeat step 11.
13. sand.
14. CURRENTLY AT THIS STEP
I will do a bit more sanding then hit is with a 2pt epoxy finishing cream, sand and a very light coat of bodyfiller (to fill any pinholes.) After wards prime, sand, prime, sand and finally paint. (Some where in there I need to finish welding up the holes leftover from the Limited spoiler...)
Total time so far is around 9 hours. Not including waiting for fiberglass and epoxies to dry. This also doesn't include the 2 hours trying to get a nut out after dropping it inside the decklid...
Fiberglass cloth followed by a layer of mat and sealed with cloth. The cloth on the bottom gives it a very smooth finish which will be very nice on the bottom side of our spoiler.
still more sanding
The Following 2 Users Say Thank You to Kiske For This Useful Post:
chanomatik (02-26-2014), soundman98 (02-29-2020)
Old 01-17-2014, 04:15 PM   #51
8R6
8R6's Avatar
Drives: FRS
damn u got skills
8R6 is offline   Reply With Quote
Old 01-18-2014, 12:18 AM   #52
Verbal21
Verbal21's Avatar
Drives: 370Z
Originally Posted by Mari0 View Post
We've actually seen this EXACT car before in the 'modified' thread. The guy just found an alternative to the fugly OEM spoiler he had on... (I still wouldn't choose a GTR wing though)
What lip/grill is that?
Verbal21 is offline   Reply With Quote
Old 01-20-2014, 11:09 PM   #53
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Done*
*Pending wiring of brake light and repositioning of the spoiler about 1/8" forward...
The Following 8 Users Say Thank You to Kiske For This Useful Post:
4Running Daily (01-21-2014), chanomatik (02-26-2014), denkigrve (01-21-2014), dori. (02-09-2014), ichitaka05 (02-19-2014), soundman98 (05-15-2016), tr1x5tuh (01-21-2014), Vracer111 (01-21-2014)
Old 01-20-2014, 11:14 PM   #54
sc0urge
sc0urge's Avatar
Drives: 2013 BRZ CBS
Looks really good! Any chance we can get some more pictures in the coming days?
sc0urge is offline   Reply With Quote
Old 01-21-2014, 12:18 AM   #55
4Running Daily
Drives: 1996 Toyota 4Runner
http://reactiongifs.com/?p=13567
4Running Daily is offline   Reply With Quote
Old 01-21-2014, 12:52 AM   #56
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
Moar pictures!!!!!
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
gt-r spoiler, skyline spoiler
Show off your FR-S/BRZ/86 Spoiler! Mari0 Cosmetic Modification (Interior/Exterior/Lighting) 176 09-21-2017 05:23 AM
BRZ Spoiler Attachment SkullWorks BRZ First-Gen (2012+) General Topics 40 06-21-2012 05:46 AM
Limited spoiler: better IRL than photos? Sport-Tech BRZ First-Gen (2012+) General Topics 27 05-15-2012 01:31 AM
FRS With Lip Spoiler ryansb FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 42 04-21-2012 11:19 AM
Ugly Rear Spoiler - Spoiler Delete? iLuveKetchup BRZ First-Gen (2012+) General Topics 31 02-01-2012 10:57 AM
