Old 01-31-2013, 07:14 PM   #43
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
More on TPMS here:
http://www.ft86club.com/forums/showp...3&postcount=94
Sensors don't have to rotate to communicate.
Computer only holds one set of codes.
smbrm is offline   Reply With Quote
Old 01-31-2013, 08:32 PM   #44
bpracer
Drives: Asphalt FR-S
I'm lazy. I put a small vinyl decal on the clear cover above the light. Not 100% coverage, a little light bleeds around it at night. It works OK.
My original wheel/tires are close enough to where I park, so the light rarely comes on.
The OE set hasn't moved in weeks, so I don't think they require movement to trigger the sensors.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 02-18-2013, 02:46 AM   #45
2013BRZ
2013BRZ's Avatar
Drives: 2013, Galaxy Blue Silica, Limited
Great tutorial, thanks a lot!
It took me about 20 minutes...I blocked the cavity rather than stuffing it. You can easily plug the cluster back in to make sure you haven't blocked the surrounding lights, one of which is the high beam indicator.
Everything fit back together snugly for me, there are no new rattles from the dash. If you are worried about that I recommend a small dot or thin smear of some low tack black silicone (not usually intended for bonding, more for use as a sealant) to ensure a tighter fit/seal that can easily be broken in the future if needed.
2013BRZ is offline   Reply With Quote
Old 04-04-2013, 10:51 AM   #46
Shanahan
Shanahan's Avatar
I went with a combination of cutting a foam earplug in 1/2 to shorten it and stuffing it in the hole. Then sealing the hole with a piece of duct tape cut to match the cavity, works great. No light leakage and total cost about $.05 and less than 10 min of my time including stopping to take the dogs out.
Shanahan is offline   Reply With Quote
Old 04-10-2013, 09:10 PM   #47
brzzz
Drives: White BRZ
I purchased a new set of tpms for my new wheels, had them installed but never programmed. My tpms light turned off after a day and has not come back on. Did it disable itself or did it learn the new tpms sensors on its own?
i dont want to go through the trouble of letting the air out to see if it comes back on.
brzzz is offline   Reply With Quote
Old 04-11-2013, 08:13 AM   #48
Shanahan
Shanahan's Avatar
Are you parked near your stock wheels? Mine would turn off whenever I parked in the side of the garage where the stock wheels are stored.
Old 04-11-2013, 11:46 AM   #49
brzzz
Drives: White BRZ
I drove from Chicago to indianapolis right after changing the wheels. The light was on the whole way there, and off the whole way back. It hasnt come back on and I drive 7 miles to and from work. They are near where i park at home, but it has not turned back on at all.
Old 11-28-2013, 06:35 PM   #50
FlushBrz
SlammedFR-S
FlushBrz's Avatar
Drives: 13 FR-S
I just did this and now I'm getting a code. U0423 invalid data recieved from instrument panel control module. I don't know how to fix this now.
FlushBrz is offline   Reply With Quote
Old 11-28-2013, 07:04 PM   #51
FlushBrz
SlammedFR-S
FlushBrz's Avatar
Drives: 13 FR-S
Scratch that. I fixed it. One of the needles wasn't pressed down all the way.
Old 02-04-2014, 11:30 AM   #52
Pat
Pat's Avatar
Drives: 2023 BRZ
After reading a lot on this, and knowing I'll have aftermarket summer and winter setups, this makes the most sense. Thanks to my outstanding mechanical skills, I am able to monitor and fill my tires with air without TPMS. It just adds cost, time, expense and headache. As long as this blocks the light 100% and I don't break anything pulling the dash apart, this is by far the best option. Great idea on the earplugs, too! Thanks for sharing that.
Old 02-04-2014, 11:37 AM   #53
1Cor10:23
1Cor10:23's Avatar
This. Mine reset every night and only come back on when I drive a consecutive ~30KM or so, which doesn't happen all that often in the city. And my stock wheels are stored about ~15+ feet away behind a cement wall
Old 07-15-2014, 12:52 PM   #54
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Reviving this thread.
Has there been any software routes? Namely, Toyota Techstream.
Bg8780 is offline   Reply With Quote
Old 08-10-2014, 01:23 AM   #55
Top-Secret
Drives: FRS monogram
http://www.ft86club.com/forums/showthread.php?t=58207
shows you how to pull apart the entire gauge cluster so you dont need to try and pry apart things. potentially breaking things
Top-Secret is offline   Reply With Quote
Old 06-03-2015, 12:52 PM   #56
adamg
Drives: brz
just bumping this thread up to say thanks, took 10min and didnt even have to do half the steps. I was able to pull it out without taking out the bottom trim piece. just the bolt for the cluster cover and 2 bolts for the cluster
adamg is offline   Reply With Quote
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
Subaru TPMS Nonsense Grimlock BRZ First-Gen (2012+) — General Topics 67 10-07-2013 03:15 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
