| DIY (Do-It-Yourself) Guides For all DIYs. |
#43 |
Drives: Scion FRS Ht Lva(AT)
More on TPMS here:
http://www.ft86club.com/forums/showp...3&postcount=94 Sensors don't have to rotate to communicate. Computer only holds one set of codes. |
#44 |
Drives: Asphalt FR-S
I'm lazy. I put a small vinyl decal on the clear cover above the light. Not 100% coverage, a little light bleeds around it at night. It works OK.
My original wheel/tires are close enough to where I park, so the light rarely comes on. The OE set hasn't moved in weeks, so I don't think they require movement to trigger the sensors.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
#45 |
Drives: 2013, Galaxy Blue Silica, Limited
Great tutorial, thanks a lot!
It took me about 20 minutes...I blocked the cavity rather than stuffing it. You can easily plug the cluster back in to make sure you haven't blocked the surrounding lights, one of which is the high beam indicator. Everything fit back together snugly for me, there are no new rattles from the dash. If you are worried about that I recommend a small dot or thin smear of some low tack black silicone (not usually intended for bonding, more for use as a sealant) to ensure a tighter fit/seal that can easily be broken in the future if needed. |
#46 |
I went with a combination of cutting a foam earplug in 1/2 to shorten it and stuffing it in the hole. Then sealing the hole with a piece of duct tape cut to match the cavity, works great. No light leakage and total cost about $.05 and less than 10 min of my time including stopping to take the dogs out.
#47 |
Drives: White BRZ
I purchased a new set of tpms for my new wheels, had them installed but never programmed. My tpms light turned off after a day and has not come back on. Did it disable itself or did it learn the new tpms sensors on its own?
i dont want to go through the trouble of letting the air out to see if it comes back on. |
#48 | |
#49 |
Drives: White BRZ
I drove from Chicago to indianapolis right after changing the wheels. The light was on the whole way there, and off the whole way back. It hasnt come back on and I drive 7 miles to and from work. They are near where i park at home, but it has not turned back on at all.
#50 |
SlammedFR-S
Drives: 13 FR-S
I just did this and now I'm getting a code. U0423 invalid data recieved from instrument panel control module. I don't know how to fix this now.
#51 |
SlammedFR-S
Drives: 13 FR-S
Scratch that. I fixed it. One of the needles wasn't pressed down all the way.
#52 | |
Drives: 2023 BRZ
#53 | |
Drives: '13 Whiteout FR-S (M/T)
#54 |
Drives: '13 Black Subaru BRZ Limited
Reviving this thread.
Has there been any software routes? Namely, Toyota Techstream. |
#55 |
Drives: FRS monogram
http://www.ft86club.com/forums/showthread.php?t=58207
shows you how to pull apart the entire gauge cluster so you dont need to try and pry apart things. potentially breaking things |
#56 |
Drives: brz
just bumping this thread up to say thanks, took 10min and didnt even have to do half the steps. I was able to pull it out without taking out the bottom trim piece. just the bolt for the cluster cover and 2 bolts for the cluster
| TPMS Sensors | kanundrum | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 249 | 06-21-2019 04:22 AM |
| TPMS Sensors.. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 04-08-2014 01:22 PM |
| Subaru TPMS Nonsense | Grimlock | BRZ First-Gen (2012+) — General Topics | 67 | 10-07-2013 03:15 PM |
| TPMS Sensors | ashtray | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 78 | 05-24-2013 04:24 PM |
| TPMS Sensor Part Number or Compatibility | civicdrivr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 11-07-2012 01:06 PM |
