#43 | |
So yes... engine braking in RWD will help you slow down faster. |
#44 |
Drives: Nevermorange FRS
Luis, tell me you were posting this 'tongue firmly planted in cheek'.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | Rampage (09-09-2014) |
#45 | |
Drives: 2013 GBS BRZ Limited
However, Assume the following (100% made up #s of course): if the brakes can apply say 1000 ft lbs of torque(at the wheel) the engine braking can apply say 200 ft lbs of torque (at the wheel) it takes 800 ft lbs of torque to lock the wheels Why would the car stop faster because using braking PLUS engine braking it can apply 1200 ft lbs torque to stop the wheel from turning? You can lock the wheels with brakes alone, how can applying more braking help that any? Same thing applies to too much HP: If you can spin the wheels in any gear with 400hp, how can 100 more hp make you any faster? And in racing the proper application of engine braking can give you extra skills in setting up the car on turn in AND relieve the brakes of a little extra abuse (less heat). |
#46 | |
Drives: Neptune GR86
This really just sounds like "old guy get off my lawn with your loud music" ranting more than anything.
#47 | |
#48 | |
Under hard braking, you need less and less rear braking force, so WHY would having even MORE braking to the rear allow you better braking - it DOESNT. Agian - the braking system has PLENTLY of force to apply to the rears to lock them up without engine braking. I CHOOSES not to because physics states it is of no use. No it does not (I have a computer that can render WOW at 1000 fps too - what was that monitor refresh rate again??? ) |
#49 | |
Drives: Toyota GT86 Coupe Red (UK)
Of course it's more fun driving aggressively and the more you have to do the more involved you feel. My point still stands that newbies should not be given this advice straight up. It also stands that driven sensibly there is no need to rev match or anything of the sort. Save that for when you are hooning it and raking the knackers out of the car. Just do that somewhere quiet and safe.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#50 |
#51 | |
Rode with a guy the other day that went down through every gear approaching the stoplight. I just about got out of his car at the stop light. ![]() Afterwords we asked what I thought about the car and I said: "You may have bitten off more than you can chew."
SCCA T4 - FRS
#52 | |
#53 | |
Try it sometime. See how smooth you can be without pedal dances, without rev matching etc. If you can't shift smoothly then you need to learn how to. Then see if you feel that rev matching is required. I occasionally do a full down the box rev match braking for fun. Then I wonder if I actually gained anything from it other than some mild amusement and the answer is usually... no. I didn't.
| The Following User Says Thank You to paulca For This Useful Post: | stugray (09-07-2014) |
#54 | |
#55 | |
I employ most of the techniques you're advising against and you probably wouldn't be able to pick me out of normal traffic since it's easily possible to drive normal and not like an asshat with these techniques.
| The Following 4 Users Say Thank You to Andrew025 For This Useful Post: |
#56 | |
| Trillium Club Sept Advanced Driving School | trackclub | CANADA | 0 | 07-23-2014 03:25 PM |
| Advanced driving course | tm86 | AFRICA | 43 | 01-03-2014 04:14 AM |
| Advanced car control clinic | Doborder | Northern California | 10 | 08-08-2013 06:17 PM |
| [GTA] CASC-OR Advanced Driving Clinic - April 27-28 2013 | engsr | CANADA | 0 | 03-20-2013 01:05 PM |
| Ontario Time Attack annual Advanced Driving School at Mosport DDT | 7thgear | CANADA | 10 | 04-20-2012 02:58 PM |
