Old 09-07-2014, 02:13 PM   #43
Luis_GT
I did not say that engine braking is in any way more dangerous than brakes alone.
You did not use one single fact in the statement above, only sarcasm.
I would just like for you to explain how "Braking + engine braking is faster than braking alone."
Just exactly the same as how the car squats down when applying the brakes.
Engine braking applies a torque to the rear wheels.
Brake braking applies a torque to the rear wheels.
Please explain how the road knows the difference between engine braking and brake braking.
Or are you trying to say that engine braking PLUS brake braking can apply more braking force than brakes alone? (that hurts my brain to proofread :-)
Brakes are front biased, using engine braking increases rear braking performance on RWD cars and helps stop the car faster. This is the reason that you only lock up the FRONT tires when you brake hard.
So yes... engine braking in RWD will help you slow down faster.
Old 09-07-2014, 02:17 PM   #44
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Doubt that
Luis, tell me you were posting this 'tongue firmly planted in cheek'.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Rampage (09-09-2014)
Old 09-07-2014, 02:17 PM   #45
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Propaganda View Post
One torque plus another torque is greater than one torque alone, leaving out any negative or negating torques (not applicable in this case). .
That statement is true.
However, Assume the following (100% made up #s of course):
if the brakes can apply say 1000 ft lbs of torque(at the wheel)
the engine braking can apply say 200 ft lbs of torque (at the wheel)
it takes 800 ft lbs of torque to lock the wheels
Why would the car stop faster because using braking PLUS engine braking it can apply 1200 ft lbs torque to stop the wheel from turning?
You can lock the wheels with brakes alone, how can applying more braking help that any?
Same thing applies to too much HP:
If you can spin the wheels in any gear with 400hp, how can 100 more hp make you any faster?
And in racing the proper application of engine braking can give you extra skills in setting up the car on turn in AND relieve the brakes of a little extra abuse (less heat).
Old 09-07-2014, 02:18 PM   #46
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by paulca View Post
Also to those who think I am refering to granny style slow driving should watch a police car cut through London traffic or on hot pursuit down a country road and watch closely how and when they change gear.
I personally love leaving boy racers behind in traffic. They can blip and rev match and brake harshly all they want, but I usually just glide past them because I am instead watching the road, identifying not only hazards, but opportunities and taking advantage. They then have to speed to catch up.
It's more about "Roadcraft" which is completely different to "track craft".
You should focus even more brain cells on the road instead of trying to impress these boy racers you're so fond of.
This really just sounds like "old guy get off my lawn with your loud music" ranting more than anything.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
litemup (09-07-2014), sklimo (09-07-2014)
Old 09-07-2014, 02:20 PM   #47
Luis_GT
You can blip and rev match and not use brakes harshly, this shows how little you know about driving a manual. I pride myself in being as smooth as possible and I blip and rev match to have near zero G force changes while braking, changing lanes, and I have gotten driving down to the point I can speed through traffic and barely use the brake pedal as I use the engine to slow the car down to traffic speed simply by letting go of the gas pedal and rev matching to a lower gear.
Old 09-07-2014, 02:22 PM   #48
stugray
Brakes are front biased because as you brake you offload weight from the rear wheels and you now have less braking ability in the rear.
Under hard braking, you need less and less rear braking force, so WHY would having even MORE braking to the rear allow you better braking - it DOESNT.
Agian - the braking system has PLENTLY of force to apply to the rears to lock them up without engine braking. I CHOOSES not to because physics states it is of no use.
No it does not
(I have a computer that can render WOW at 1000 fps too - what was that monitor refresh rate again??? )
Old 09-07-2014, 02:23 PM   #49
paulca
Drives: Toyota GT86 Coupe Red (UK)
I'm not trying to impress them. I just find it amusing that with all their aggressive punchy driving they don't actually get anywhere faster.
Of course it's more fun driving aggressively and the more you have to do the more involved you feel. My point still stands that newbies should not be given this advice straight up. It also stands that driven sensibly there is no need to rev match or anything of the sort. Save that for when you are hooning it and raking the knackers out of the car. Just do that somewhere quiet and safe.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 09-07-2014, 02:24 PM   #50
Luis_GT
That vid is old as fuck, I just felt like sharing it... Mad skillz I has!
Old 09-07-2014, 02:26 PM   #51
rice_classic
That's what I figured.
Rode with a guy the other day that went down through every gear approaching the stoplight. I just about got out of his car at the stop light.
Afterwords we asked what I thought about the car and I said: "You may have bitten off more than you can chew."
PRO86 | WTCC | STL
Old 09-07-2014, 02:28 PM   #52
Luis_GT
No it does not
Even with the weight transfer to the front, the rear tires have enough contact patch and grip that the stock brake pads can't completely use, this is where engine braking helps.
Old 09-07-2014, 02:28 PM   #53
paulca
Whoopy for you. "You can", so what. So can I. My point is, it's pointless at normal road pace. You are creating a load of work for yourself for little or no gain.
Try it sometime. See how smooth you can be without pedal dances, without rev matching etc. If you can't shift smoothly then you need to learn how to. Then see if you feel that rev matching is required.
I occasionally do a full down the box rev match braking for fun. Then I wonder if I actually gained anything from it other than some mild amusement and the answer is usually... no. I didn't.
The Following User Says Thank You to paulca For This Useful Post:
stugray (09-07-2014)
Old 09-07-2014, 02:30 PM   #54
Luis_GT
lol... no one notices when I downshift, I do it to keep the car as smooth as possible, something that can't be done unless you throw the car in neutral and only rely on the brakes to stop. even with downshifting 1 gear ant near idle, I can feel a slight change in g force that bother me.
Old 09-07-2014, 02:31 PM   #55
Andrew025
Andrew025's Avatar
"Normal" people drive like that all the time (aggressive, mashing the accelerator and brakes). It's not exclusive to the boy racers.
I employ most of the techniques you're advising against and you probably wouldn't be able to pick me out of normal traffic since it's easily possible to drive normal and not like an asshat with these techniques.
The Following 4 Users Say Thank You to Andrew025 For This Useful Post:
daiheadjai (09-08-2014), kavanagh (09-09-2014), litemup (09-07-2014), Luis_GT (09-07-2014)
Old 09-07-2014, 02:32 PM   #56
Luis_GT
Again, I don't think or work for it, my body does it automatically while I'm off in la la land thinking of other stuff or singing along to the radio, or sometimes I'm analising which lane is going faster or what car is going faster to anticipate a lane change
Trillium Club Sept Advanced Driving School trackclub CANADA 0 07-23-2014 02:25 PM
Advanced driving course tm86 AFRICA 43 01-03-2014 03:14 AM
Advanced car control clinic Doborder Northern California 10 08-08-2013 05:17 PM
[GTA] CASC-OR Advanced Driving Clinic - April 27-28 2013 engsr CANADA 0 03-20-2013 12:05 PM
Ontario Time Attack annual Advanced Driving School at Mosport DDT 7thgear CANADA 10 04-20-2012 01:58 PM
