CANADA Canada
Old 02-05-2015, 10:47 PM   #43
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
What proof do you have that the Toyota (Esso) synthetic causes engine wear at the recommended changing interval?
@Dezoris and others performed a Blackstone oil analysis and it came back healthy
drewbot is offline   Reply With Quote
Old 02-06-2015, 02:16 AM   #44
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
its 0w when the engine get hot it doesnt lubricate anymore its just to get efficiency rating as it gives less mechanical losses at the cost of having to never get any use of your motors full potential. i personal have seen what the wrong oil does to race engines ona dyno. not worth losing compression
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 02-06-2015, 03:10 PM   #45
Dezoris
Dezoris's Avatar
Yes that is correct even running supercharged, with oil cooler on Redline 0w20 for 45 minute session and several other 30 minutes sessions showed less than average wear materials.
(I would never do that again BTW because oil pressure is too low)
This is not a race engine and probably less than 3% of the owners would ever stress this car enough for it to matter.
Your comment would only apply to those on track doing extended lapping. For a non-eco versions of 0W20 like Redline, Motul etc. the oils are so advanced that they hold up extremely well to heat, beyond their optimal heat ranges. However 225F is the max you want to run the performance 0w20s and thats only because of oil pressure dropping. (Oil thinning) Not due to degradation.
Unless you are running on the track or have FI especially in cold climates a good 0w20 is perfect.
Running high quality synthetic/thinnest oil possible is good thing these days (Power and Efficiency) as long as you watch pressures and temps.
NAPA Full Synthetic Oil Sale White64Goat Other Vehicles & General Automotive Discussions 4 11-01-2015 10:22 AM
0W-20 full synthetic oil for $3.49 a quart terrypm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 04-08-2014 04:51 PM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 5 12-29-2012 04:25 PM
%100 Full Sythentic VS Fully Synthetic ProjectD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-05-2012 01:28 PM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 3 07-08-2012 01:04 PM
