#43 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
loctite like it says in the instructions
#44 |
USMC
Drives: 2013 FR-S 6-MT Raven
I did. Maybe the loctite isn't doing its job. I used the blue one.
Sent from my SAMSUNG-SM-N920A using Tapatalk |
#45 | |
Space for Rent
i used Permatex Medium Strength Threadlocker BLUE from auto zone so far so good
#46 | |
USMC
#47 | |
Space for Rent
Applied like 6 months ago Nothing rubs
#48 | |
Also, if you use red Loctite, you won't be able to remove the fastener if you need to, unless you can get heat on it. |
#49 |
not playing cards
Guys with this loosening issue, does the inside shoulder of the adapter sit flush against the right shoulder of the bore, or does the upper collar force it to rest at an angle?
#50 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Put some permatex red threadlocker on the bolt today. Hopefully this time it won't come undone.
#51 |
Drives: Whiteout frs
#52 |
not playing cards
Bingo. I struggled like hell with one just like it. Finally gave up customizing the customization. It's an atrocious design relying on completely unrealistic goals for tolerance. Throw that POS in the trash or demand a refund. If you must have a short shifter, get the JDM actual lever.
...or the kartboy. Sorry. The entire line of people allowing that thing to go to market should be fired.
#53 | |
I love messing with this POS...so i'll keep having fun!!!! Thanks once again!!!! |
#54 |
not playing cards
Good luck! Let me know how it works out.
#55 |
If it comes undone after the threadlocker, I may just invest in the actual JDM shortshifter.
#56 |
Drives: Toyota GT86
Does anybody know if the TRD quick shifter kit will fit a RHD GT86
Thanks |
| trd quick shifter ? vibration noise | Pcharliep04 | Issues | Warranty | Recalls / TSB | 5 | 08-01-2014 02:42 PM |
| TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 01:24 AM |
| TRD quick shifter (sold) | lovebeingbleu98 | Transmission and Driveline | 13 | 04-09-2014 06:25 PM |
| trd quick shifter? | tjohnson104 | Engine, Exhaust, Transmission | 6 | 01-26-2014 02:37 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
