Old 12-24-2015, 03:13 PM   #43
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Originally Posted by texasbound972 View Post
Glad I'm not the only one with this issue. Does anyone know if Toyota has a fix? I did notice that when moving the shifter, the bolt rubs on the bottom input shaft causing the bolt to turn.
Sent from my SAMSUNG-SM-N920A using Tapatalk
loctite like it says in the instructions
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 12-26-2015, 11:19 PM   #44
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I did. Maybe the loctite isn't doing its job. I used the blue one.
texasbound972 is offline   Reply With Quote
Old 12-27-2015, 12:23 AM   #45
1GiantTurtle
Space for Rent
first time i didn't use loctite learned my lesson the hard way,
i used Permatex Medium Strength Threadlocker BLUE from auto zone so far so good
Instagram: 86turtle
Instagram: 86turtle
Old 12-27-2015, 12:39 AM   #46
texasbound972
USMC
How long has that been applied? And does your bolt rubs onto the bottom input shaft?
Old 12-27-2015, 03:47 AM   #47
1GiantTurtle
Space for Rent
I have the shifter for over a year
Applied like 6 months ago
Nothing rubs
Instagram: 86turtle
Instagram: 86turtle
Old 12-27-2015, 06:29 PM   #48
joe strummer
Originally Posted by axelo View Post
Mine came loose also....did blue locktite and is holding better, but it will come loose if i use it the way i want to use it....so will take it easy until have time to use red or 272.
Two things- when using Loctite, the threads have to be very clean. Alcohol works pretty good. One way is to put the alcohol on a thin rag, and push the rag into the thread valleys with your thumbnail as you turn the fastener. The female threads can't be cleaned that well, but at least use a q-tip with alcohol.
Also, if you use red Loctite, you won't be able to remove the fastener if you need to, unless you can get heat on it.
joe strummer is offline   Reply With Quote
Old 12-27-2015, 07:06 PM   #49
Guys with this loosening issue, does the inside shoulder of the adapter sit flush against the right shoulder of the bore, or does the upper collar force it to rest at an angle?
Old 12-30-2015, 02:36 PM   #50
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Put some permatex red threadlocker on the bolt today. Hopefully this time it won't come undone.
MS, CSCS, TSAC-F, CPT
Old 01-02-2016, 08:31 PM   #51
axelo
Drives: Whiteout frs
Upper collar forces at an angle...
Thanks
axelo is offline   Reply With Quote
Old 01-02-2016, 08:41 PM   #52
Thanks
Bingo. I struggled like hell with one just like it. Finally gave up customizing the customization. It's an atrocious design relying on completely unrealistic goals for tolerance. Throw that POS in the trash or demand a refund. If you must have a short shifter, get the JDM actual lever.
...or the kartboy.
Sorry. The entire line of people allowing that thing to go to market should be fired.
Old 01-02-2016, 09:00 PM   #53
axelo
...or the kartboy.
thanks!!!
I love messing with this POS...so i'll keep having fun!!!!
Thanks once again!!!!
Old 01-02-2016, 11:21 PM   #54
thanks!!!
Good luck! Let me know how it works out.
Old 01-03-2016, 12:25 AM   #55
weederr33
weederr33's Avatar
If it comes undone after the threadlocker, I may just invest in the actual JDM shortshifter.
Old 03-03-2016, 09:29 AM   #56
KevinA
Drives: Toyota GT86
Does anybody know if the TRD quick shifter kit will fit a RHD GT86
Thanks
KevinA is offline   Reply With Quote
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 02:42 PM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
TRD quick shifter (sold) lovebeingbleu98 Transmission and Driveline 13 04-09-2014 06:25 PM
trd quick shifter? tjohnson104 Engine, Exhaust, Transmission 6 01-26-2014 02:37 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
