Old 06-19-2014, 01:29 PM   #43
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
@fst86frs I still want to dyno on your guy's Mustang Dyno
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
The Following User Says Thank You to evo4g63 For This Useful Post:
fst86frs (06-19-2014)
Old 06-19-2014, 01:30 PM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by fst86frs View Post
The manifold is similar to a twin scroll but instead run to two single scroll housings on the two turbos. Still base numbers but for now at about 245wtq on these small compressor wheels
Just realized it seems I sold you my stock injectors.. nice!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 06-19-2014, 01:41 PM   #45
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Very nice, saw it on FB as well. Looking forward to see how it progresses.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 06-19-2014, 01:57 PM   #46
sw20kosh
Drives: 2013 Black FR-S
315 whp on ACN91? nice! Is that dynojet? Can't wait to see the dyno graph.
Old 06-19-2014, 02:24 PM   #47
fst86frs
fst86frs's Avatar
Drives: FAT H8R Hot Lava FRS
Thanks and will be running the moto-east flex fuel kit!
That was weather corrected on the most aggressive pull the final pull was at 308whp corrected will do more testing and print dyno graphs soon
fst86frs is offline   Reply With Quote
The Following User Says Thank You to fst86frs For This Useful Post:
Xero-Limit (06-20-2014)
Old 06-19-2014, 02:48 PM   #48
evan
Drives: fr-s
Originally Posted by Sportsguy83 View Post
I can only wonder why so much hate.... ...
Almost every post has to point out a negative thing about it...
I am really happy someone is trying it and can't wait for results...
Most people are closed minded and conformists. Nothing wrong with that really since the majority of society needs to function that way to sustain. There has only been a small group willing to tinker, expand and think outside the box. Those are the ones that get blasted by the 99%. Think N. Tesla.
I feel troll-ish still..
evan is offline   Reply With Quote
The Following 5 Users Say Thank You to evan For This Useful Post:
Creole (12-06-2014), fst86frs (06-19-2014), hmong337 (06-20-2014), Lonewolf (06-20-2014), Sportsguy83 (06-19-2014)
Old 06-19-2014, 05:36 PM   #49
D K
Stig's dark passenger
What sort of header configuration were you running?
Are you pairing left head on one turbo, or both fronts on one and rears on the other?
D K is offline   Reply With Quote
Old 06-19-2014, 06:45 PM   #50
fst86frs
fst86frs's Avatar
Header configuration is set up by firing order from both heads and even has a slight unequal sound! Responds very well too
Old 06-19-2014, 07:04 PM   #51
s2d4
s2d4's Avatar
I like this a lot, very interesting.
Maybe take it up another notch of having 1 turbo per inlet manifold?
1 bank on the left and the other on the right?
Twin throttle with trumpets inside or inlet manifold to twin throttle body on both sides per each intake valve?
What about Motec N1?
Old 06-20-2014, 01:50 AM   #52
nelsmar
On the technical side of the fence I can chime in a bit. FAT has probably the smallest fan I have used out of any local dyno blowing down on the car. This car had fairly consistent IAT's rising no more than 10-12C during a pull. This is pretty average from a number of setups I have tested. I didn't keep too much of an eye on heat soak with the hood open as we all know that wont represent much. The only time the pipes got truly warm was with the engine off with no air flowing through. The air flowing through the upper charge pipe(s) were keeping the pipe sufficiently cooled while idle. The fan temp triggers were set very low on this setup to keep the IAT at a constant cool temperature. This is a show piece that is quite functional. I am sure that with the track abuse that @fst86frs typically does (he doesn't just hard park his cars, hence why I dialed his tune back a bit but kept the higher powered one on a second map) he will heat soak a bit more. But they are planning on furthering things by ceramic coating and wrapping as much as possible to keep things cool.
The turbos spooled extremely linear. Very smooth pull in not a surge like most setups do. There was no boost controller so I wasn't able to hold a solid flat boost target all the way to redline. Even with this it did hold a very linear and smooth HP graph. The turbos were kicking in quite nicely at roughly 3,800-4,000RPM with a 2.5" catback.
The car was originally tuned on MAF and was one of the easiest maf's I have tuned. Once we passed ~5-7PSI though the AFR became less consistent as the air flow started to change more than I would like when trying to push for power. I am pretty sure I could have done 100% MAF tune but I would have had to been much more conservative on timing as the AFR wasn't 100% perfect which is normal on forced induction setups with a blow through maf. Even at 10-11PSI their maf was still only picking up 4.7-4.8V.
Compared to other setups I have done the car needed more timing to make similar power. However the car was able to take a fair bit of timing considering. And in the end the power was actually fairly smooth all around. These turbos basically instantly made 2-3 PSI at almost any PSI and load and then "slowly" crept up to 10 psi. I am sure on the street it felt fairly close to a centrifugal setup. I only drove the car on the dyno with a fixed load value to get a feel for how it ran (and to test abusive driving habits) and it was actually quite responsive (and it sounded pretty damn cool too!)
As much as people are hating, the fabricator at FAT really knows what is up and really does understand now to work with a MAF. When I first saw the car in person I told them that it is never going to idle and they just need to accept that and that it will likely be SD only and I was as far off from accurate as I could be when I made that statement. lol
It really is a cool unique setup. Its not so much my cup of tea but I love seeing unique setups! Also mind you the owner of this car literally had a 3071R sitting on his desk to install on his car but at the last minute they decided to just do something completely outrageous which is pretty normal over at FAT. Hell hanging from the celling there is a good 3-4 twin turbo subaru setups just on display in their bay.
My flickr - Canibeat
Local magazine scout
The Following 4 Users Say Thank You to nelsmar For This Useful Post:
Ammonia (06-20-2014), fst86frs (06-20-2014), Simon99 (06-20-2014), Slysdexia (11-08-2014)
Old 06-20-2014, 01:51 AM   #53
nelsmar
I kept egging the shop owner to let me pour E85 in it too as the gas light came on literally as I was just tidying up the tune for daily use. You guys really ought to keep a damn barrel of E85 there! You had damn near every other fuel sitting there!!!
The Following User Says Thank You to nelsmar For This Useful Post:
Old 06-20-2014, 02:10 AM   #54
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
04 Subaru 2.0 twin turbo B4 in japan, 280 hp feels pretty damn good if you ask me, yes it has a lower compression ratio, but for all those who say, why a twin turbo? Not needed? If you ask me, it makes a pretty damn daily driver.
http://en.m.wikipedia.org/wiki/Subar...ird_generation)
RD1428 is offline   Reply With Quote
The Following User Says Thank You to RD1428 For This Useful Post:
Old 06-20-2014, 02:31 AM   #55
D K
Any possibility of getting a pic of the exh manifold?
Old 06-20-2014, 11:28 AM   #56
fst86frs
fst86frs's Avatar
Huge thanks for the base tune @nelsmar great work car feels awesome on the street! And no worries next phase is installing the flex fuel setup, trying the larger re-profiled billet compressor wheels, coating, and built motor!
nelsmar (06-20-2014)
Twin Turbo Kit ? SalM Forced Induction 77 07-03-2016 02:16 PM
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 01:22 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
Super plus Turbo PLEASE MOVE TO FORCED INDUCTION Captain Snooze Forced Induction 2 01-24-2014 07:21 PM
Twin Turbo BRZ xn7485 BRZ Photos, Videos, Wallpapers, Gallery Forum 10 08-23-2013 07:13 PM
