Old 09-03-2014, 04:56 PM   #43
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Originally Posted by C4RBON View Post
I have experienced the exact same sound. It happened 3 times, and I just bought the car on Saturday. I've got about 500 miles on it. I am in Colorado at the moment. I live in Iowa, so I will see if it still happens at lower altitudes and on 93 octane gas. I have read a few threads describing similar sounds, and all of the posters mention being at high altitude.
Interesting to hear. I lived in St. Louis and just moved to Colorado a few months ago. And that's when the noise started. You might be right in it only happens at high altitudes.
You should definitely keep me/us posted
Kronos is offline   Reply With Quote
Old 09-07-2014, 01:06 PM   #44
J-Money
J-Money's Avatar
Drives: GT-86
im at 800ft and heard the sound yesterday in third gear. switched to fourth and immediately went away. lasted about 3 seconds haven't heard it since
J-Money is offline   Reply With Quote
Old 09-07-2014, 11:26 PM   #45
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
Update: I've got 2300 miles on the car now. The first time I heard the noise is still the worst its been. Following my last post, I started the car and heard it slightly while the car was still cold. That was at ~8000 ft. After the following fill-up, I have yet to hear it. While I was still at high altitude, I could hear the faintest clatter noise between 3-4000 rpm.
I haven't heard a thing since getting on the interstate and heading home.
My instincts tell me that the noise is caused by a combination of fuel, altitude, and temperature interacting with the high pressure fuel pump.
I'll post back if I ever hear the noise again. I'm in Iowa at 1000 ft and will be using 93 octane.
C4RBON is offline   Reply With Quote
Old 09-07-2014, 11:28 PM   #46
C4RBON
C4RBON's Avatar
Was it between 3000-4000 rpm?
Old 09-08-2014, 03:14 AM   #47
Karnzklutch
Drives: '14 FRS, '98 JDM Forester, '95 s14
I'm having an issue with a noise similar to that, but it seems to be coming from after 2500rpm for me and I have only hit 5500 RPM once, but the power was much greater after 5000rpm.
Its been happening for about 1 week now and is always there after 2500rpm.
I only have 600KM on my frs and don't exactly drive it hard yet.
Karnzklutch is offline   Reply With Quote
Old 09-08-2014, 03:45 PM   #48
C4RBON
C4RBON's Avatar
So I just talked with our resident performance car expert/racer (I'm an engineer at a diesel engine manufacturer) and he is 100% confident that this noise is spark knock.
The charge is detonating in this engine speed range when the spark fires. His solution is to run at a higher engine speed when under load at this engine speed. This does two things: reduces peak cylinder pressure for the same power, and mixes the charge better.
The ECU is responding to the knock by retarding timing and injecting more fuel. This explains why mine got quieter each time and has since gone away. The ECU is learning where the knock is occurring and compensate.
The Following User Says Thank You to C4RBON For This Useful Post:
Kronos (09-12-2014)
Old 09-08-2014, 03:56 PM   #49
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I thought this was from a loose heat shield, or is this another noise. I also have somewhat similar vibration noises at higher RPMS
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-09-2014, 02:09 AM   #50
Karnzklutch
I've had a heatshield rattle in my old wrx and it sounds way different than this. Well atleast my rattle did.
Old 09-11-2014, 12:44 PM   #51
jflogerzi
jflogerzi's Avatar
I have heard this noise a few times. Few questions… Was it hot out and have you been driving some? Were your windows up and A/C on? This is when I seem to notice this noise the most.
Old 09-12-2014, 10:44 AM   #52
Karnzklutch
For me it happens more when its warm. Windows up. Ac off (haven't even tried ac yet)
I have noticed it happens more at around 50%+ throttle pressure.
The Following User Says Thank You to Karnzklutch For This Useful Post:
Kronos (09-12-2014)
Old 09-12-2014, 11:26 AM   #53
Kronos
Kronos's Avatar
Unknown Engine Rattling (Video)
I'll second that. I was in the same driving scenario as you. About 74 out. Ac off. My driving was mixed, but I think it's when in driving more aggressively that it seems to happen. in boulder Colorado so about 8000ft above sea level.
It hasn't happened in a whole for me. I'll update if it does. Last time It happened I got a better video. I'll upload later today
Old 12-09-2014, 01:54 AM   #54
Kronos
Kronos's Avatar
Not sure who is still subscribed to this thread. But I thought Id share. I'm still getting that sound about every other time I take my car out. It's been happening for about five months now. The engine still feels strong despite the noise.
Got a decent video of it.
I'm stock besides OFT stage 1 tune.
[ame]http://youtu.be/nvHnLm-EtkA[/ame]
Old 12-09-2014, 02:36 PM   #55
Koa
not trying to dog ya, but that video is pretty hard to distinguish on Dell stocker 2-way speakers. The first ones were better able to give a sound through the engine noise. I'll listen with headphones after work and see then.
Old 12-09-2014, 03:47 PM   #56
Kronos
Kronos's Avatar
No worries. Glad you're being honest.
I just gotta a pair of binaural microphones for 3d audio recording. I'll see if I can capture it with that. It will be much better
Engine rattling/vibration happening between 3k - 3.3k Boofneenee Issues | Warranty | Recalls / TSB 4 05-18-2014 02:34 PM
Rattling from front of car when you shut the engine off djdrugga24 Issues | Warranty | Recalls / TSB 8 04-01-2014 12:03 AM
Rattling Engine Noise (Video with sound) mystic Southern California 21 12-28-2013 04:11 AM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
BRZ Rattling w/ video lavisxice Issues | Warranty | Recalls / TSB 11 11-06-2012 10:07 AM
