Old 07-17-2014, 03:09 PM   #43
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
looking good!
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 07-17-2014, 03:22 PM   #44
KDad2
KDad2's Avatar
Drives: 2013 Raven
There is also ELO Remover. I've used it before to remove decals without damaging plastic models. They have limited quantity on Amazon. I don't think it is manufactured any more.
[ame="http://www.amazon.com/Floquil-Testor-Corp-ELO-Remover/dp/B000BQSKQE/ref=sr_1_4?ie=UTF8&qid=1405624470&sr=8-4&keywords=elo+remover"]Amazon.com: ELO Remover, 8oz: Toys & Games[/ame]
I would still test it on something first.
KDad2 is offline   Reply With Quote
Old 07-21-2014, 01:59 PM   #45
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Originally Posted by brokedrifter View Post
Yeah my acetone definitely ate my plastic and not fading but for some reason burned the o into the plastic, it's really weird.
Originally Posted by fooddude View Post
Anyone have more pics of success(perfect or close to perfect, no haze) and failures (haze, eaten plastic, etc.)?
My dash logo disappearing act is looking pretty good. I will post pictures later today. I used a non-acetone nail polish remover. I could still lightly see the logo and I kept going and now it sort of looks like the S is burned in. How long did you guys work on it for? Hope I didn't mess up my HU...LOL
Chad86 is offline   Reply With Quote
Old 07-22-2014, 12:02 PM   #46
Chad86
Chad86's Avatar
Drives: Toyota GT86
You don't really notice it unless you're looking for it. I might try to lightly use some more today to smooth it out.
There must be a replacement bezel for these without the Scion logo, if worst comes to worst.
Old 07-25-2014, 10:42 AM   #47
Luke
Luke's Avatar
Drives: 2014 Whiteout FRS
I did this today, worked very well, had no issues and took less than one minute to remove the logo.
This is the exact nail polish remover/acetone I used (what my wife had in the bathroom cabinet, came from Walmart):
Put some on a cotton ball, rubbed it a bit until the logo started fading, turned to a fresh spot on the cotton ball and removed some more, turned the cotton ball again and removed the last bit. Then cleaned it off with some alcohol. No haze or damage to the plastic.
Just thought I would post the exact product I used, I'm sure the nourishing part of it was not needed, but it's just what I had on hand.
Luke is offline   Reply With Quote
Old 07-25-2014, 01:02 PM   #48
Chad86
Chad86's Avatar
Drives: Toyota GT86
So is my trim piece officially screwed?!?
Old 07-25-2014, 04:04 PM   #49
Luke
Luke's Avatar
There's no going back with it now. Before replacing the bezel, I'd try to find some sort of small badge to cover that area, might be tough though given the size. If all else fails, get a small piece of black vinyl cut and cover it with that. Like this:
Old 07-25-2014, 09:18 PM   #50
Chad86
Chad86's Avatar
Drives: Toyota GT86
I will attempt to further smooth it out. If all out fails I will contact Pioneer to get a replacement bezel.
This sucks, but I would rather buy a new bezel without Scion than be stuck with an ugly sticker on a brand new car.
Old 07-26-2014, 12:00 AM   #51
kodyo
Drives: Scion FR-S
If you can take the bezel off, sand the whole thing to get an even finish and call it a day.
kodyo is offline   Reply With Quote
Old 07-26-2014, 03:45 AM   #52
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
I used some thrift store brand nail polish remover and a Q-tip. Very light rubbing while switching out q-tips. After that, took some Meguiars UC & an mf cloth and gently polished the area.
Then I used some Armor-all interior detailing wipes (not sure because I removed the label a while ago) to clean off any remaining polish and give it a bit of a shine.
Will take pics tomorrow when there's daylight but it came out flawlessly IMO.
Manic is offline   Reply With Quote
Old 07-28-2014, 01:38 PM   #53
Manic
Is not fast.
Manic's Avatar
Not the best shot, but I ended up taking a photo at night anyway. During the daylight, looks like there was never a logo printed there.
Old 07-30-2014, 05:02 PM   #54
NIN69
Izzy Gure (Senior Member)
NIN69's Avatar
Drives: FR-S TRD Release Series 1.0 / #1459
Used the recommended nail polish remover and my Scion HU logo is history! Took my time and used cotton balls instead of Q-tips. Always used the clean side of the cotton ball and dried the area in between applications. Did not scuff the HU plastic and looks flawless.
NIN69 is offline   Reply With Quote
Old 01-19-2015, 02:40 PM   #55
M23
Drives: 86
- Does paint thinner/mineral spirits work? Probably not, since it's weak.
- Lacquer thinner is stronger than paint thinner/mineral spirits tho; so this may work.
- Acetone def works (as already known); but is stronger than both of the aforesaid (stronger than both paint thinner and lacquer thinner).
M23 is offline   Reply With Quote
Old 01-19-2015, 03:22 PM   #56
Chad86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
I finally fixed my head unit using the finest # of steel whool, then finishing it off with detailer and quick wax to get back the shine. I would recommend to everyone to just using steel whool and forget about using any acid compounds. I wish I had done this to start, but there would have been no difference to the end result. Looks flawless now!
I will post a pic later.
head unit, logo, rebadge, scion, stereo
headunit splash screen. encity5 Electronics | Audio | NAV | Infotainment 21 08-11-2017 03:00 PM
Remove logo from FR-S OEM all-weather floormats? nalc Cosmetic Modification (Interior/Exterior/Lighting) 4 11-11-2013 05:11 PM
GT86 logo centered (replaced Scion logo) jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 7 06-10-2013 10:13 PM
How to remove sync'd phones from headunit? ShoNUFF Electronics | Audio | NAV | Infotainment 3 01-09-2013 05:54 AM
