#43 |
@KoolBRZ kodename47 and vgi have added a vvt optimisation tool to the maf scaling tool if you download the new version you will get new tool works using map
maf sensors and woirks out volumetric efficiency @thambul9 may also be interestedhttp://www.romraider.com/forum/viewt...p?f=32&t=10481 |
| The Following User Says Thank You to steve99 For This Useful Post: | thambu19 (11-26-2015) |
#44 | |
Got it
If I say yes, will that make you think I understand?
#45 | ||
Drives: Scion FRS
Sent from my HTC One_M8 using Tapatalk |
#46 | |
Drives: Scion FRS
#47 |
When i did some testing with kodename47 he got me to log my current timing then log with intake +10 then intake -10 (some ignition timing pulled for safety) then load all three logs into tool and it compares, then repeat for exhaust cam
#48 | |
Drives: Scion FRS
So I believe the tool looks to see which of the settings gives max Airflow. Which is okay except when running any kind of boost combined with lots of valve overlap. I would recommend going in steps of 3deg since it is easy to miss a tuning peak with +-10deg. Those running boost should start with OTS/OFT intake cams and retard the cams depending on how much boost one is running. In the case of Phantom SC like @KoolBRZ is running the boost is strongest at lowest engine speeds and dies off at higher engine speeds. So in that case the lower engine speeds would have more intake cam retard and as we approach peak power speeds the cams can be similar to OTS/OFT maps. For those running a SC that scales with engine speed this tapering off of Intake will not apply. As a general thumb rule with higher boost levels the trapping efficiency is not lost by closing the intake at a later angle because the blower can out power the piston to some extent. |
#49 | |
Drives: Scion FRS
@KoolBRZ for your 3bar boost
1. OTS/OFT Exhaust table - 4 2. OTS/OFT Intake table - 4 Basically take the table that @Shiv@Openflash came up with for NA engines and subtract 4 deg on intake and exhaust surfs. This will open the exhaust valve 4degrees earlier and close the intake valve 4degrees later. |
#50 |
Not sure if you guys saw, but there are new OFT maps coming out.
Supposed to be better optimized for the OFH. Curious what the changes are. |
#52 | |
What are intake and exhaust surfs?
#53 | |
#54 | |
Drives: Scion FRS
#55 |
Let me show you
Here are pics of the OFT NA intake and exhaust maps, as well as the OFT ESC maps for comparison. When I first got my Phantom ESC, this is what I ran. It very little low-end torque and it was like waiting for turbo lag. I was on the throttle switch and learned never to stab the throttle below 3000 rpms. It just made a wooshy noise with no appreciable gain in power. I have the Procede controller now and I'll also include a pic of the map I'm running.
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-11-2016 12:25 AM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 04:01 PM |
| Stock Rom: Timing + Learn Value | sw20kosh | Software Tuning | 7 | 12-11-2013 08:09 PM |
| E85, Boost and Ignition Timing | jamesm | Software Tuning | 23 | 12-11-2013 03:19 PM |
| Timing belt shredded..?! | drei | CANADA | 5 | 12-06-2013 06:54 PM |
