Old 02-01-2014, 10:43 PM   #43
DriftHappens
Drives: '14 FRS White
Hey shiv, did you get the new xdfs posted (specifically the b01c)? Need to tweak a couple things
DriftHappens is offline   Reply With Quote
Old 02-02-2014, 12:37 AM   #44
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Were there any changes to the E85 roms from the 1.42b? Just loaded the 1.55 E85 EL rom and fuel trims are +10% which is a bit less than what I saw while on the unmodified 1.42b tune @ up to +16% LTFT.
Old 02-02-2014, 01:07 AM   #45
1086
1086's Avatar
Drives: UM86 - 6MT
Datalog 2/1/204 :: OFT OTS v1.55b :: Stage 2 EL E85
http://datazap.me/u/1086/21204-oft-o...g2-el-e85-a01c
vs.
Datalog 1/21/204 :: OFT OTS v1.42 :: Stage 2 EL E85
http://datazap.me/u/1086/oft-e85-dat...-backroads-run
1086 is offline   Reply With Quote
Old 02-02-2014, 01:17 AM   #46
solidONE
solidONE's Avatar
vs.
Pretty much in line with what mine looked like. 6% difference between the 2. Question is, why are my LTFT 10% higher than yours? You are using Propel E85?
Old 02-02-2014, 01:23 AM   #47
1086
1086's Avatar
Drives: UM86 - 6MT
I wish I could answer your first question. The details I do have are that I have driven about 36 miles total today on the 1.55b tune. And yes I am using Propel E85 @ this station: http://www.sanjosegasprices.com/76_G...849/index.aspx
*bonus - E85 was going for $2.98 today if I remember correctly. BOOM!
Love the 1.55b tune too - much more smooth
Old 02-02-2014, 01:45 AM   #48
solidONE
solidONE's Avatar
I think the smoothness might be a result of the fuel trims staying close to 0% I felt similar result from a modified 1.42b to run plus minus 5% LTFT. I'm new to all this stuff as well, so I'm just assuming from the results I've seen and felt.
Edit: On second look I seem to have gotten your logs mixed up. On 1.55b you have 6% LTFT at WOT and -0.78 with 1.42b. Now I'm really confused.
I also found a propel station not so far from me with E85 below $3. http://propelfuels.com/locations#station_locator_map
Old 02-02-2014, 06:09 AM   #49
solidONE
solidONE's Avatar
1.42b E85 'Mod D'
1.55b E85 EL
I do not feel or see much of a difference between the 2 while WOT. Cruising speeds the LTFT was sweeping from -5% to +5% with the modified 1.42b I labeled 'Mod D'. Will keep running the 1.55b and see what happens after it's had some time learning.
Old 02-02-2014, 01:07 PM   #50
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
So if we upload the 1.55 files to the device do we then need to go to ModFiles DataBase and remove the 1.54 database file? If I try to do that I get "Error during delete" - next time I try to write from the device, which files would be written? The 1.54 ones from the database file or the 1.55 ones that I just uploaded?
EDIT - I closed OpenFlash manager, disconnected device, relaunched OpenFlash manager and plugged the device back in. The database file was no longer present. Bingo bango.
VR46 is offline   Reply With Quote
Old 02-02-2014, 02:27 PM   #51
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
1.55b Stage 2 EL Header Gas
2300-7300 rpm 3rd gear automatic transmission
http://datazap.me/u/tonystewart/first-log-155
Modifications in signature
Is the maf voltage good/correct?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-02-2014, 03:18 PM   #52
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Your MAF voltage and Engine Load is higher than normal. I'd wager a guess that is caused by your FA20 intake causing the misreading. This is why you are running so rich. Definitely put your stock intake back on or else you will need to recalibration your MAF table.
Old 02-02-2014, 04:18 PM   #53
tonystewart
Shiv
I just bought the custom e-tuning from OFT
Old 02-02-2014, 04:58 PM   #54
tonystewart
Shiv
You offer the Perrin CAI on the OFT website.
Have your customers who've bought the Perrin CAI, indicated similar rich conditions?
Old 02-02-2014, 05:08 PM   #55
solidONE
solidONE's Avatar
@shiv@vishnu , was the cold cranking enrichment changed on the 1.55b from the 1.42b E85 roms?
Old 02-02-2014, 05:11 PM   #56
Shiv@Openflash
Drives: 2013 FRS
Shiv
We always tell customers who are purchasing intakes that they might require MAF table calibration to work as well as the stock airbox. So far no one has asked for it so I have no data points to work on. Intakes really aren't a big sell for this platform from the feedback I get from our sales team. 99% of all FA20 related orders are either OFTs or OFHs.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
