Old 01-04-2014, 05:25 PM   #43
stugray
Drives: 2013 GBS BRZ Limited
Good to hear you got it working.
I am still trying to figure out my tactrix and I am wary of using it until the precedure is well documented. I dont want to brick my DD.
Here is the link about fixing a bricked ECU for future ref:
http://www.romraider.com/forum/viewt...hp?f=33&t=7384
Old 02-11-2014, 08:49 PM   #44
Cross
It's the Mad Cow
Cross's Avatar
This sounds very similar to the problem I am having... only I am sitting in the car at work when I should have left to go home... I feel your pain everything went fine but now nothing.
http://www.ft86club.com/forums/showthread.php?t=58020
Do you remember anything they did to gain access to this recovery mode?
Old 02-12-2014, 02:34 AM   #45
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Had to get on the phone with ECUtek early in the morning, they remoted into my computer, installed custom recovery software, then flash my ecu back to a previous map. The problem seemed to have been caused by a corrupt/bad map.
gdrider77 is offline   Reply With Quote
Old 07-02-2014, 03:16 AM   #46
DC2R
Drives: 2014 Scion FR-S
Originally Posted by xjohnx View Post
My money is on a bad pin in the harness. Seems to be a somewhat common occurrence. Wish someone would write a DIY on fixing it.
It's there anything anywhere showing what a good port looks like? Mine flashes with OFT just fine but no dongles can connect to ecu. Maybe different devices use different pins?
Pic of port
https://www.dropbox.com/sc/yunstdfah...cF3j675b4FBcha
DC2R is offline   Reply With Quote
Old 07-02-2014, 05:56 AM   #47
steve99
Pic of port
I think it more the thickness/length of the pins on cables, the OFT cable I never have problems with always provides a good connection.
however my tactrix is flakey when plugged directly into obd port on car. solved it by buying 1 metre obd extension cable, leave that plugged in permanently and its tucked in near seatbelt, just plug my devices in the other end and no further problems
DC2R (07-02-2014)
Old 07-02-2014, 08:09 AM   #48
DC2R
Hmm reason I returned extension was that oft would fail when flashing. I bought a flat cable from Amazon.....
Sent from my SM-N900T using Tapatalk
Old 07-04-2014, 12:25 AM   #49
steve99
bought one of these or similar 90 degree plug keeps it out of way
use it for OFT and tactrix flashes ok and logs with tactrix at 10 cycles per second with 20 parameters ok.
http://www.ebay.com.au/itm/OBDII-OBD...item3a92bc2548
lovethe@mentions
Ecutek flash & warranty 3000HP Software Tuning 40 04-06-2015 10:33 AM
FA20CLUB ecutek flash mach330 Software Tuning 19 08-09-2013 10:35 AM
When do you reset the Avg MPG? WRXcellent BRZ First-Gen (2012+) — General Topics 50 01-16-2013 10:30 PM
DynoComp EcuTek Flash JRollar Engine, Exhaust, Transmission 8 01-16-2013 06:16 PM
FA20 Stg 2 Ecutek flash or no? DC-FRS Engine, Exhaust, Transmission 25 12-25-2012 07:13 AM
