#43 | |
Boosted
Drives: Not a supra....yet
Oh yeah, but that car is a master piece Sent from my IBrick
#44 |
Masterpiece or not, for the ~$40k into the car now plus the purchase price you could have a much nicer car.
I love mine, but if $70k was my budget I would be driving something different.
#45 | |
Boosted
Thats why he has an LFA over 4 supras and a shitload or porches. The guy is an enthusiast with style, and also doesn't waste his money on useless super cars Sent from my IBrick
#46 | |
2 wheel member
Drives: JZA80, 997.1, Taco
http://www.jackstransmissions.com/pa...ebuild-process prices: http://www.jackstransmissions.com/co...ebuild-options
#47 | |
Boosted
Thanks for the heads up ! arent you the 2j brz owner ? Sent from my IBrick
#48 | |
Drives: 2005 Toyota Camry
CA allows engine swaps as long as engine going in is same emissions standard (or newer) than chassis it is going into. Oh, and engine has to be CA smog legal (i.e. no imported "new" engines from another country). -alex |
#49 | |
2 wheel member
#50 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I've already bought a lot for my build and now I'm running into a legal issue, whether or not it's legal to swap this older 2JZ into a brand new car. I've looked into Florida laws and it's looking like it's legal. I've contacted a lawyer to look into it from his standpoint and waiting to hear back before I decide what to do next (whether hold off a little while and make it a dedicated track car or not).
EDIT: I've been quoted $10k for a completely stock swap w/ V160 to $30-35k for minimal mods. I expected to be around $20-25k but it's still up in the air. Again, legal issues are the main concern now and will ultimately determine the direction of my swap now. I'm not keen on spending another $20k+ on this swap and can only track it when I can buy a Supra instead for the same price. It's either street & track or bust. |
#51 |
#52 |
Not sure about most of the US, but in Ontario (Canada) it's 100% illegal to swap in an older engine to any car. Now if you put a 2013 engine into a 2014 chassis of the same car I doubt anyone would notice, but if you tried to put a 94 Supra engine into a 2013 FRS/BRZ, it wouldn't be legal and unless the shop doing the e-test "overlooked" it by running a different car through the OBD test you'd never pass a test.
It's a big problem for a bunch of people that downgraded OBDII hondas to OBDI ECU's, it's impossible for them to pass an e-test now.
#53 |
Boosted
If there is a will there's a way
Sent from my IBrick
#54 |
First86 / boat thief
Drives: MKIV Supra
I have a APU supra parked next to my FRS and If you do this right you’re looking at some real money. If you do lots of the work I would say 20K just to get started with something that was going to be worth your time power wise.
But the bigger issue is turbo lag even the stock twins had lag you had to drive around on the track. If all you care about is drag you can disregard the rest of this. It very hard to get usable throttle response and more than about 700 out of a 2JZ. My supra is of the few built for RR not drag. There are not many who have more experience making a responsive 2jz. This is what I had to do to get lag less than or equivalent to the stock twins and big power. BC 3.4 stroker kit BC Lightened knife edge crank Fully built head with 5 angle 4 plate cc clutch Custom billet 67 turbo with a 58 and 96 hot side And about 1000 other supporting mods but long story short small turbo + big engine is the only way to make usable RR power. I used the 58 hot side at the AutoX (750 HP) usually turned the boost down to give about 600 when I wanted a decent time . The 96 hot side was used for RR DE days and made 850HP but more important made 750TQ very quickly. This is a very very fun and terrifying car, As a driving instructor and car guy I have driven more than my fair share of fast cars and nothing tries to actively kill you like a quick to power 800+ HP supra (maybe a 700hp 930 Porsche is about as bad). I would not put 800 HP in the FRS if you actually use it you best be a dam good driver. |
#55 |
Drives: GT86 2014
Well said SpeedR... And thanks for the info on your track Supra.
#56 | |
Valley 86 SoCal !
Drives: whiteout frs
| Build Happening soon.....2jz Swap | JK21 | Engine Swaps | 85 | 04-16-2019 07:21 PM |
| 3 Way Active without a Subwoofer | stea1thbear | Electronics | Audio | NAV | Infotainment | 42 | 10-14-2013 02:03 AM |
| Need advice...removing active sub | Fizz | Electronics | Audio | NAV | Infotainment | 5 | 10-07-2013 10:26 AM |
| Active Knock sensor | Fat Spider | Engine, Exhaust, Transmission | 13 | 07-14-2013 08:37 PM |
| A more active mid alantic | _F-R-S_ | Mid-Atlantic | 37 | 11-12-2012 07:19 AM |
