Old 02-11-2014, 01:46 PM   #43
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
Originally Posted by Black_Pearl View Post
Hi guys, first post here
I've had my FR-S for almost a year now and now its time for the big first mod. Which in this case would be an almost complete overhaul of the audio system. Im changing the stock speakers with Alpine's SPR-60c (with crossovers), JL Audio's JX360 2-channel amp, and a Sound Ordinance B-8PTD powered sub. And finally a Clarion EQS746 equalizer. All of this will be used with the stock HU since it pretty much has every feature that I would want in a HU. Plus I'm wrapping the whole car in Stinger sound dampening.
If any of any of you has had any experience with this products I'd like to hear about your experiences. Plus, since I'm new at this whole car audio thing, any advice would be much appreciated.
first and for most dynamat the doors,roof and trunk before u buy audio equipment
dunnr is offline   Reply With Quote
Old 03-17-2016, 09:15 AM   #44
MattHoffman
Drives: BRZ Limited
So i went the extra mile and cut the brackets in the rear and mounted 6x9s. But they seem to only receive mid and high frequency. Any help here??
MattHoffman is offline   Reply With Quote
Old 03-17-2016, 11:32 PM   #45
unplugged
Master Member
Drives: Subaru BRZ
I didn't read through the entire thread. Are you connecting these with an amp?
I see you aren't too far from KC. If you ever need help and want to make the trip, I can always lend a hand in person.
unplugged is offline   Reply With Quote
The Following User Says Thank You to unplugged For This Useful Post:
MattHoffman (03-18-2016)
Old 03-18-2016, 05:20 AM   #46
MattHoffman
Drives: BRZ Limited
There are still wired to the oem head unit.Just wondering of there is something inline on the speaker wire filtering out the bass
Old 04-11-2016, 10:07 PM   #47
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Stock amp only powers the doors. Rear and dash are mids. Dash has a tweeter.
YamahaR86 is offline   Reply With Quote
Old 04-13-2016, 01:07 AM   #48
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
The factory head unit is really a 4 channel device even though it is supplying 6 speakers. The front channels are full range. These supply the mids in the dash, the tweeters and the amp that feeds the front door speakers. The rear channel goes to the back speakers only and has a factory crossover installed. The crossover is in the head unit itself and as of yet, no one I know has any way to defeat it. If you want good speakers or a sub in the back, you will have to feed them a signal from the front channels on the head unit or else you will have limited bass.
It's not the prettiest solution but I would rewire the door speakers to be powered off the rear channel of the head unit. This will limit bass to the door speakers which may not be a bad thing since some people have complained about their doors rattling. Then I would wire the rear speakers up to the front channel where the door speakers were.
Doing it this way you would supply full range to the 4 dash speakers and the rear speakers. The rear channels would power the door and limit the bass to them. Your fader wouldn't fade from front to rear anymore but you could still balance the system by attenuating the amp to the rear until the speakers blend.
Page 322 has a wiring diagram for the front channels and page 320 shows how the rear speakers are wired: http://www.ft86club.com/files/BRZwiringi.pdf
sly is offline   Reply With Quote
The Following User Says Thank You to sly For This Useful Post:
MattHoffman (04-15-2016)
All Possible Car Upgrades? pwnisher Scion FR-S / Toyota 86 GT86 General Forum 31 07-23-2013 01:27 PM
Will spending only $200-250 on speaker upgrades be worth it? tracerit Electronics | Audio | NAV | Infotainment 30 04-29-2013 06:44 PM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 05:18 PM
Speaker upgrades Thongpocket Electronics | Audio | NAV | Infotainment 15 03-01-2013 07:33 PM
Interior upgrades stalon320 Cosmetic Modification (Interior/Exterior/Lighting) 14 06-17-2012 11:45 AM
