Old 11-20-2013, 06:31 PM   #43
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by cycleboy View Post
That's great if you live somewhere this is possible. For us Californians, there are 11 stations listed in the entire state with E0. The closest to me is 110 miles one way, so that's not happening.
There are loads of posts on using 2T to shut it up when E0 isn't available, until they get a fix.
sierra is offline   Reply With Quote
Old 11-20-2013, 06:43 PM   #44
arashishozen
Guest
Posts: n/a
2T?
Old 11-20-2013, 06:55 PM   #45
sierra
Originally Posted by arashishozen View Post
2T?
2 stroke oil. High quality low or zero ash 1:1000
Old 11-20-2013, 06:56 PM   #46
strat61caster
strat61caster's Avatar
2T?
He means two stroke oil which gets poured into the fuel tank before fill up.
Note that these aren't "fixes" per se, rather band aids so your car doesn't make noise, and they aren't guaranteed to work, members have reported both that the two stroke oil and E0 did not get rid of the chirps, they are the minority but take everything with a grain of salt.
The car was supposed to be designed to run on readily available fuel, changing the fuel you put into the take doesn't 'fix' anything. The design chirps, it wasn't enough to bother me (believe me, many would be complaining with the noise I "suffered" so I wasn't one of the lucky ones) so I left it alone, after 10k miles it went silent, just crossed 16k trouble free miles.
ineedyourdiddly
Old 11-20-2013, 06:59 PM   #47
arashishozen
Guest
Posts: n/a
Wouldn't that be hard on the cat? I know my 200 xcw ktm 2 stroke smokes allot. ( never heard it by 2T before)
Old 11-20-2013, 07:11 PM   #48
arashishozen
Guest
Posts: n/a
I got used to the noise and figured it wasn't causing anything as of right now. Though as a preference I prefer E0 but only get it if I have some extra moolah for it.
Old 11-20-2013, 07:17 PM   #49
sierra
Zero ash has nothing to to block the cat and it's 1:1000 not 1:25 Less than a teaspoonful in a gallon.
I had never heard of it called 2T before either but it seems common in the US.
Old 11-20-2013, 09:01 PM   #50
strat61caster
Most claim it will do no harm, I haven't seen any proof that leaves me satisfied so personally I wouldn't touch it even if my cricket chorus drowned out the radio (I'd probably take it in for warranty at that point). Odds are you'll be ok using it, but I'm in the minority saying don't touch it. Rotary owners have used it to prolong their engine life, to mixed results, you can search and see if they have any issues that would carry over.
Me neither, only on this forum and I've known some diehard 2 stroke dirtbike fans.
ineedyourdiddly
Old 11-20-2013, 09:04 PM   #51
arashishozen
Guest
Posts: n/a
Now you know one more.
I'm gonna stay away from oil in the gas. Too many fouled plugs in the past to thank for that. Lol
Old 11-21-2013, 09:13 AM   #52
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Oil in the gas can take out your cat. Don't do it.
Its nothing to do with the oil, diesels use a cat. It's the additives. Never use gas engine oil in a diesel. The other way around is ok. Neither belongs in the fuel tank.
Suberman is offline   Reply With Quote
Old 11-21-2013, 09:40 PM   #53
Trmx2
Trmx2's Avatar
Drives: 2014 Raven FR-S 6spd
Originally Posted by 86viper View Post
There is your problem right there. With 1000miles on the clock it should be seeing redline often. Thats the whole point.
The only issue of yours that i have had is the rev drop. Its a pretty common known issue but in the grand scheme of things isn't too annoying.
I've been driving more spirited as of late, things seem to be leveling out a bit, fuel pump chirp is really intermittent, I'll go two days without it (no fill ups) and then one day it'll do it for an hour, then stop. Kind of weird, I blast my music so the noises are irrelevant mostly but since I know they are there, my brain won't stop telling me "hey, these noises are there"
Originally Posted by tiz22 View Post
Untrue.
Mine dips to ~600RPMs all the time with absolutely no fan/AC/heat on whatsoever
I have recorded it in every possible setting and it has no affect. If you read up on the forums a lot of people have the issue regardless of AC setting
+1 I run w/o A/C at night all the time and it'll do it at stop lights.
Originally Posted by Mikem53 View Post
You need some more miles on your car.. Things do smooth out some over time. I get the idle dip under certain conditions, but it's normal. You are overly aware of these issues being a new car and all.
Everything you mentioned seems to be on par with what others experience.
Taking a list to Toyota and demanding they fix everything may not be the best plan. I would give the car and yourself some time to break in before you go getting yourself all aggravated by visiting the dealer..
Its human nature to focus on everything that seems wrong.. But the more time spent driving it and enjoying all that is good... Will let the other issues either work themselves out or give you time to realize what is normal for this car..
Noted and I am starting to see that.
Originally Posted by cooldandani View Post
hey there!!! ive had the same issues in my 2013 the way the rpm dip was fixed in mine was by buying a drop in filter, got the k&n drop in filter and car runs smoother and no more rpm dip. hope this helps!!
Looks like my problem is solved! Was gonna purchase the Perrin drop in this week
Trmx2 is offline   Reply With Quote
Old 11-21-2013, 09:44 PM   #54
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Trmx2 View Post
Any known fixes or TSB's that they will fix and honor without complaint?
You need to discuss this with your dealer, or any competent dealer. No amount of internet advice will help you document this with your dealer.
But to answer your question: YES all those can be fixed at the dealer under warranty with TSBs. Some aren't a proper fix, just FYI.
-alex
Old 11-21-2013, 11:39 PM   #55
czy
wait! my 2013 FR-S idles at 700 RPM all time. how come 800 is a dip?
czy is offline   Reply With Quote
Old 11-22-2013, 12:59 AM   #56
Trmx2
Trmx2's Avatar
-alex
Went to my dealer earlier this week for an oil change, I WANTED the oil change at 1200 miles, I had about 3/4 of the members on this forum recommend it after break-in. Guy told me he never heard of anyone wanting to change the oil after break-in so soon. He actually tried to get me to not do it.
I then told him about all the TSB's, guy seemed like he had no clue what I was talking about, I don't even think he knew anything to be honest. Some Jamaican dude.
This was at Autonation in Weston, Florida if anyone lives close to there.
In my years of owning cars, at least down here, I feel that nearly all of the dealerships know NOTHING about what they are doing. I think it's a Florida thing.
I tried discussing most of these issues with him and he seemed like he had no clue what I was talking about.......then they couldn't reproduce the fuel chirp, so they didn't fix anything. Told them to change all my fluids, he said they wouldn't do that, he didn't even know what kind of LSD fluid the car took.....I was not happy. I got my oil change and that's it.
2 weeks from getting a brz tr1x5tuh Southern California 16 10-31-2013 09:27 PM
Not even three weeks gr8scott Scion FR-S / Toyota 86 GT86 General Forum 19 05-21-2013 10:01 AM
Another 8 weeks!! Wesley Scion FR-S / Toyota 86 GT86 General Forum 28 09-21-2012 06:25 PM
had my frs for two weeks..this is what happens bcmakesiteasy Scion FR-S / Toyota 86 GT86 General Forum 98 08-07-2012 10:20 AM
