Old 07-07-2014, 11:26 PM   #43
kodyo
Drives: Scion FR-S
I've read these snorkel mods mess with the AFR, any truth to that?
kodyo is offline   Reply With Quote
Old 07-08-2014, 04:44 AM   #44
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I think Shiv runs the modified snorkel on their shop car, and I don't think he had to rescale the MAF voltage.
Old 07-08-2014, 08:18 AM   #45
kodyo
Drives: Scion FR-S
I thought Shivs snorkel was an expanded stock snorkel and not a trimmed one, but I could be wrong. That's probably the direction I would go if I do the mod.
I'm sure changes are minimal anyways.
Old 07-08-2014, 08:41 AM   #46
Trettiosjuan
Drives: GT86
What is the net gain on an NA? 5whp?
Trettiosjuan is offline   Reply With Quote
Old 07-08-2014, 08:58 AM   #47
raven1231
2 maybe 3
Old 07-08-2014, 12:22 PM   #48
Dephective
Drives: '13 Whiteout FRS
The real gain would be less heat soak and more response, especially at lower speeds. Most of what people "feel" as power is just better response that they attribute to power. You really aren't going to feel 1-5hp. Tq, on the other hand, is a different story.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 07-08-2014, 12:28 PM   #49
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
We've got some real answers!
We saw repeatable gains in top end with modified snorkel:
2-3whp, 1-2wftlbs, nearly no change in AFRs (except a small one down low)
Here's where we cut ours:
I believe Shiv's is similar to this, but then heated up and expanded with a pop (soda) bottle.
TONS more info in our post about stock airbox testing: http://www.ft86club.com/forums/showthread.php?t=56341
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 07-08-2014, 12:41 PM   #50
DC2R
Drives: 2014 Scion FR-S
Chase
Engineering
Any concerns with heavy rain? Been driving in some pretty heavy downpour lately. Interested in this mod but would hate for any water to get in engine for 2 HP
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 07-08-2014, 02:42 PM   #51
Target70
Target70's Avatar
I haven't taken off my bumper cover, but from the pictures, It looks like If water can get in the modified tube, it will have gotten into the stock tube. In both cases the tube is above the crash bar, and above the radiator ducting.
Old 07-08-2014, 03:36 PM   #52
zooki
Drives: waiting on a 2021...
How does a modified snorkel increase throttle response at lower speeds?
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 07-08-2014, 04:29 PM   #53
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Measured gains for a "free" mod is always cool
I wonder how the snorkel mod effects other intakes.
Kostamojen is offline   Reply With Quote
Old 07-08-2014, 04:42 PM   #54
charged86
charged86's Avatar
Originally Posted by Kostamojen View Post
So I did my own modification today, taking the ideas from this thread and expanding on it a bit...
I have a TRD intake so this might have even MORE benefit for me.
First thing I did was swiss cheese the plastic blocker plate thingy a bit more.
Then I used an exacto knife and scissors to modify my snorkel. I also used a spread clamp and heat gun to spread the intake out a bit more for a more rounded shape.
I decided to keep both mounting points installed and turned half of the "tube" into a bit of an airflow blocker/director so it should send air to the intake even better
The TRD is a LOT louder now, but its the kind of loud that only gets loud when you step on it which is what I wanted Haven't done any high speed testing yet to see if it helps.
favorite idea so far
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-08-2014, 04:54 PM   #55
steve99
good point on heat soak.
Stock tables Intake Air Temps above 86F starts to pull timing from map, above 120F its pulling maybe 1.5 to 2 degrees, this will effect performance.
If you can keep your IAT lower its better , however is generally only a problem in traffic or low speed, or maybe for boosted guys with a turbo near intake tract. Once your around 60kMH IAT recover to close to ambient on stock car.
Old 07-09-2014, 01:13 AM   #56
EZx2
Drives:
So what, so far, is the best DIY mod (which gives better response, but not cause negative effect on other params).
Lets try build something simple and BEST.
Sent from my SM-N9005 using Tapatalk 4
EZx2 is offline   Reply With Quote
FR-S Premium head unit startup/run screen can you modify it? OICU812 Electronics | Audio | NAV | Infotainment 0 05-13-2013 02:07 AM
Do you modify your car just to be different? #87 Off-Topic Lounge [WARNING: NO POLITICS] 31 02-08-2013 10:14 PM
modify when locking car. DriftEightSix AUSTRALIA 2 09-30-2012 08:30 PM
How are you going to modify your FRS? Asterisked Accolade Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2012 12:00 PM
Does anyone intend to NOT modify their BRZ? R8 BRZ First-Gen (2012+) — General Topics 40 06-08-2012 12:24 AM
