Old 03-07-2015, 06:25 PM   #43
xwd
What would the adapter look like? The wheel needs to sit flush against the hub face, the only way for it to really work is to machine out the center of the rim. Now 2mm isn't a huge amount and shops can do it, but I'd probably just find some different wheels.
Most of this thread is garbage though. I've been running non-hubcentric wheels on my car for 2.5 years now without rings, taking them on and off quite a bit for autocross, and have the original studs. Rings make sure things are centered, but if you torque wheels the right way they don't really do anything for you.
Old 03-08-2015, 11:54 AM   #44
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
I support hubrings. They prevent vibration issues, they help support the wheel, safety is debatable but hey they cost practically nothing, I'd be more than willing to fork it out for them.
As for 1mm hubrings, they are typically aluminium if they are that thin and in replacement of them I've used tape, sandpaper, really anything i can get my hands on. prefer to not have the 1mm difference even though its so small. thats just me though
Sweet48 is offline   Reply With Quote
Old 03-09-2015, 03:56 PM   #45
MikeR
MikeR's Avatar
Drives: 2014 FR-S
I found some hub centric rings that I am going to try. Dimension are 56.1mm to 54.1mm. The wheels I am trying to use are the 5 spoke TRD. http://trdsparks.com/displayparts.ph...6&parts_id=978
Rings wont' be in until next week - hopefully they do the trick.
MikeR is offline   Reply With Quote
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Bore of FR-S rims versus TC1? stocktc1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-05-2015 11:28 AM
Hub Bore Correction Wesley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-02-2013 08:00 PM
FS/FT: OEM FRS Center Caps (Trade for Subaru Center Caps) Meeners Wheels and Tires 4 11-20-2012 04:47 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
