#43 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
I got video up at this link http://www.ft86club.com/forums/showp...&postcount=270 I plan to sign up for TWS for September when that opens up.
#44 | |
Photo Specialist
@AdamVR4 asked a great question in my journal
Some have told me my temps are still too high. Still have to factor in that we are reading the temperature through a custom PID in torque and the fact the sensor calibration is unknown, I personally just have to have faith that my engine will be okay. I believe I saw the max temperature for the Amsoil Signature oil I use is 300F. Hopefully I'm no where close to that. I have no idea about oil pressure so I cannot quantify. I kept the lines as short as possible to minimize this logical reduction.
#45 |
I really need to get on this but so many things to finish with my supercharger.
Oil staying so hot, hot, hot:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | F1point4 (07-02-2013) |
#46 | |
Photo Specialist
Thanks @swift996 for the data
#47 | |
#48 |
Photo Specialist
Working too well?
I noticed this in the morning when I was driving to work...My oil temp seemed to say very low (<180F) even though I drove a reasonable amount and a fair distance. The setup I decided to log my trip home. It was 94F outside according to the in car thermometer. When I start the car, I always let my car's idle drop to 800 before moving it to let the Cam Angles set in. My car is parked in a parking garage all day. Today it sat still for 8 hours while I worked. Torque logging was started a little bit after I turned on the car so that data is missing. The commute in all was 18 minutes. Each vertical line on the chart represents one minute. The question It looks like it takes nearly 10 minutes for the oil temperature to reach 180. The coolant stabilizes after 6 minutes. I didn't totally baby the car, just reasonable driving on the street. These may be some dumb questions > Is it normal for oil temps to take this long to settle? > What about driving it hard? Maybe we should wait 10 minutes before taking it above 5k RPM. I normally stop babying the car after 4-5 minutes. > I was making the assumption that the thermostat was working. Maybe its stuck open? Too bad I wasn't smart enough to do these kinds of graphs when I was NA and when I was boosted pre oil cooler. Hopefully this graph can help people what our cars may be doing during normal driving ![]() 20130701-OilTemp-CommuteHome-001 by VictorN07, on Flickr
#49 |
Photo Specialist
If you were 265F while N/A and 80 degrees outside, I probably would have hit 300 if I wasn't oil cooled down here in Texas. Sheesh!
#50 |
Drives: 2013 Firestorm FR-S
I figured the thermostatic plate would allow the car to warm up normally, 18 minutes seems a little long to me. Ill have to time my warm up tomorrow morning on the way to work
2013 Firestorm FR-S, MTX, build date 1/13.
#51 |
Photo Specialist
Installation Pictures
Car is apart ![]() 20130628-HomebrewOilCoolerInstall-002 by VictorN07, on Flickr Front ![]() 20130628-HomebrewOilCoolerInstall-010 by VictorN07, on Flickr Since I didn't buy a kit, I had to create my own mounting solution. I needed to remove the black tray to effectively measure placement. I stuck the tray into the bumper so I know how far forward I can put the core. ![]() 20130628-HomebrewOilCoolerInstall-043 by VictorN07, on Flickr My chosen placement. The two light grey hashes are where my Vortech intercooler stops. note I took out the two air scoops that screw into each side of the space invaders grille. ![]() 20130628-HomebrewOilCoolerInstall-051 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-051 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-058 by VictorN07, on Flickr How close to the front ![]() 20130628-HomebrewOilCoolerInstall-062 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-070 by VictorN07, on Flickr Still has clearance ![]() 20130628-HomebrewOilCoolerInstall-074 by VictorN07, on Flickr I used a unibit to drill my holes for my 1/4"-20 bolts ![]() 20130628-HomebrewOilCoolerInstall-086 by VictorN07, on Flickr I had to be mindful of the supports ![]() 20130628-HomebrewOilCoolerInstall-094 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-096 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-113 by VictorN07, on Flickr I bought a polyurethane tube to use as my mounting point. I didn't have the correct tools to cut the polyurethane tube; I ended up using a boxcutter. It wasn't clean but when you clamp it down, it is tight. I chose polyurethane because it provides some vibration dampening. I added some on each side of the core tabs. ![]() 20130628-HomebrewOilCoolerInstall-119 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-132 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-139 by VictorN07, on Flickr Final placement ![]() 20130628-HomebrewOilCoolerInstall-153 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-159 by VictorN07, on Flickr Inside the core ![]() 20130628-HomebrewOilCoolerInstall-168 by VictorN07, on Flickr ![]() 20130628-HomebrewOilCoolerInstall-180 by VictorN07, on Flickr Clearance to the intercooler ![]() 20130628-HomebrewOilCoolerInstall-206 by VictorN07, on Flickr Through the grille ![]() 20130628-HomebrewOilCoolerInstall-211 by VictorN07, on Flickr Enjoy! I'll take some pictures of the sandwich area soon. Exhausted by all the action
#52 |
Drives: 2013 SWP BRZ
Like usual, its always a pleasure reading your DIY's and viewing your photos. I'm going to take this route myself. Thanks for the parts list! Luckily I have a shop near my house with everything I need minus the sandwich plate/adapter, they even list setrab oil coolers on their site so I'm pretty sure they have them in store
| The Following User Says Thank You to xxscaxx For This Useful Post: | F1point4 (07-02-2013) |
#53 |
My car (no oil cooler) took ~7 minutes to warm the oil to 181 degrees. This was relaxed city/hwy driving, mid 70s morning temps keeping the revs under 4K. My car is also N/A for the record.
| The Following User Says Thank You to brillo For This Useful Post: | F1point4 (07-02-2013) |
#54 |
Photo Specialist
Another one from this morning when it was cooler.
![]() 20130702-OilTemp-CommuteWork-001 by VictorN07, on Flickr
#55 |
I will be curious how you get your aeroquip lines run down past the airbox and piping without rubbing on the vortech airbox/bracket and abs module Mine are horribly tight. I am considering switching to stainless because of it.
#56 |
Photo Specialist
It is tight. I'll get some pictures during the holiday break.
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| Apexi Oil Temp Meter, and Setrab Oil Cooler | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-09-2013 02:58 PM |
| Mocal Oil Cooler | swift996 | Engine, Exhaust, Transmission | 11 | 07-01-2013 05:00 PM |
| Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-22-2013 12:36 AM |
