Old 08-13-2014, 10:29 AM   #43
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I do agree with what Dipstik-sportech said. I've had this issue when shifting from 3rd-4th when my car was stock. With my turbo setup I have the issue between 2nd-3rd, 3rd-4th, & 4th-5th at a high RPM. I don't believe it is clutch related or shifter related (have a Kartboy Shifter). I believe it has to do with the amount of torque at the high RPM and the syncros. Possibly too much inertia for the syncros when applying the next gear. After all it is a new design with a triple cone syncro application.
Now the wait begins until the transmission gives out lol... oh well, the cost of performance, right? Or just bad (and new) design...
shiro is offline   Reply With Quote
Old 08-18-2014, 07:09 PM   #44
Churnobyl
Churnobyl's Avatar
Drives: 2014 Limited Subaru BRZ DGM
Just started having this issue within the last week. 6400 miles on the OD . 14 BRZ.
I get in 2-4 on shifts over 5500 and 34 just a little higher. Crunch is the best way to describe it. Street driving its fine. but if you get on it and shift, its noticeable and replicate-able.
I'm clearly not a shifter TSB candidate. So we wills see what the dealer has to say.
Churnobyl is offline   Reply With Quote
Old 08-18-2014, 10:59 PM   #45
twag4
Drives: frs
Redline mt90 trans oil, 75w90 fixed my third to fourth little scratchy shift. It is GL4 only, no GL5. Toyota pickup guys rave about it fixing manual transmission woes. It worked for me. It was better immediately, but I drove a 200 mile journey in one day about a week after changing it- and it is perfect now. Absolutely perfect shifts up and down (tear of joy streaming down cheek)
twag4 is offline   Reply With Quote
Old 08-19-2014, 03:16 AM   #46
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
3rd-4th gear grind...but only near redline
Mine was checked and found to have the issue everyone please get it done under warranty while you can
Edit: my issue was a 3-4 crunch when in the high RPM
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 08-21-2014, 08:06 PM   #47
fanaticalz
fanaticalz's Avatar
Drives: WRB BRZ
ugh, i have this problem. shifting above 7k rpm from 3rd to 4th, there's a crunch, and it happens almost every time. if i left the revs drop a little before i shift, it's fine. i guess i'll take it to the dealer.
questions for you guys who had the tranny replaced, how long did it sit at the dealer for?
fanaticalz is offline   Reply With Quote
Old 08-23-2014, 05:19 AM   #48
misooscar
misooscar's Avatar
Drives:
I've noticed the 3rd 4th gear grind is not apparent with the Vortech kit
Edit:
It came back at my 1st track day...I guess I wasn't driving as hard on the street with the Vortech...
Sent from my SM-N900T using Tapatalk
misooscar is offline   Reply With Quote
Old 09-19-2014, 11:54 PM   #49
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
I did a track day today and the 3-4 crunch is definitely related to high RPMs. I'd get it up shifting from 3-4 when powering out of turns.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 09-20-2014, 03:28 AM   #50
mtsui
Drives: 135i
mine grind when 3 going to 4 at high rpm, I tried 2 of my friends frs and their tranny didn't grind at all!
mtsui is offline   Reply With Quote
Old 09-23-2014, 04:53 PM   #51
xyborg
Drives: 14' firestorm
Has anyone noticed this in the higher gears? I don't have any problems 1-4 but if i shift into 5th at high rpm I'll get a crunch.
xyborg is offline   Reply With Quote
Old 09-23-2014, 06:12 PM   #52
number1Tango
Drives: Silver FRS
if I redline it in 4th and shift aggressive to 5th I get the grind occasionally, but it's not EVERY time or it will be difficult to shift it into 5th
number1Tango is offline   Reply With Quote
Old 09-23-2014, 08:04 PM   #53
xyborg
It happens to me almost a every time I shift into 5th at a high rpm, it could even be in a highway merging situation where 2-3 will be aggressive to get up to speed and once at traffic speed throwing it into 5th before the rpms drop it'll crunch.
Old 09-24-2014, 01:46 AM   #54
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
I had the same problems on the track, but I changed the solid engine mount and no more grinding again.
AceHeader-MT is offline   Reply With Quote
Old 09-25-2014, 05:36 AM   #55
calmtigers
Go to the dealer, in the recalls thread there is lots of documentation of others having similar issue. I did dealer swapped the tranny new one is butter
Old 05-12-2015, 04:16 PM   #56
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
Is it still good with redline my grinding started after the change never had it before that in any gear so you can be right
Albaro08 is offline   Reply With Quote
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 03:02 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 02:47 PM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 02:12 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 12:57 AM
