View Poll Results: Should the Toyota H4 Support Flex-Fuel (E85)
Yes, It should be E85 Compliant. 12 48.00%
No, It should run on regular Fuel (91) 13 52.00%
Voters: 25. You may not vote on this poll
Old 02-05-2010, 07:51 PM   #43
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Drives: '08 xB '07 Yaris '06 EVO9 '89 240SX
Originally Posted by MatadorRacing_F1 View Post
Do I really have to explain that to you?
sure...
Biggie™ is offline   Reply With Quote
Old 02-05-2010, 08:27 PM   #44
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
Originally Posted by Biggie™ View Post
Assuming you are getting 10% or more drive train loss, your injectors should be close to being maxed out at over 264 hp.
Since we are in theory dealing with a 2.0 liter Subie flat 4. Let's look at the last 2.0 liter Subie flat 4 that made it to the USofA, the 2002 WRX. It came with 420cc injectors, ones similar in size to yours. Stock power on 93 octane was 169whp and 174 lb/ft. Well those injectors got maxed out at Stage 2(tune and down pipe), about 225 whp and 223 lb/ft.
So without help from a bigger fuel system from the factory me might get stuck with relatively little room to improve engine performance.
Direct injectors and their ultra high pressure fuel pumps are very proprietary.
come to think of it, i think you're a bit closer to the mark. i have seen cars (MR2s, what i'm most familiar with ) with the 440s putting out a reliable 260whp, but that's pretty much the limit. any more than that and they drop in 540s or 550s.
Originally Posted by Dixie Normous View Post
ATS 2.3L Stroker!!!!!!!!
ha i almost forgot the ft will have direct injection.
ATS is exactly the reason why I need to open my engine up again. I am extremely displeased with them.
You will soon
probably not this year. *maybe* 2011...
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 02-08-2010, 11:13 PM   #45
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
How come there's not a poll option for 93 octane for those who don't live in CA?
OldSkoolToys is offline   Reply With Quote
Old 02-09-2010, 12:38 AM   #46
NESW20
2.1L 3SGTE
i'm sure you already know this (hence the bellyroll), but they'll design it to run on the pee-water that CA gets, and the car will work just fine in the rest of the country.
can't do it the other way around though... cars run fine on higher octane than they require, but not lower octane than they require. or at least not for very long on lower octane, ha. that's why i tuned my car on 91 instead of 92 or 93 that was available here.
-Mike
2008 Civic Si Sedan
Old 02-09-2010, 12:41 AM   #47
cbishop11
Drives: 91 MR2
Just tuning into this thread, but I thought I'd make a few comments.
The things that Biggie are saying are true about forced induction applications. But to clarify some things and also to answer a few questions I see that have gone unanswered:
1. Yes - using E85 requires about 25-30% more fuel. Imagine if you were running E85 with 1000cc injectors. It would be as if you were running 800cc injectors with 94 pump gas WITH the same amount of air. That would make your tune lean, so you have to add fuel to get the air-fuel ratio back to where it needs to be (which by the way is about 9:1 stoichiometric for E85, very rich compared to pump gas which is 14.7:1)
2. Once you do this, you must also increase cylinder pressure, either by turning up the boost or increasing compression ratio, or your car will run like a dog. The properties of E85 allow you to increase boost as well as advance timing much more than you could if you were to just add the same amount of fuel that you did in #1 above, such that you end up making more power with an E85 system (over pump gas). This is where the advantage of E85 comes into play for forced induction.
Although this thread has focused on a turbo'd FT-86, I was not aware that this has been announced?
So with that in mind, I would like to make a few more comments:
3. Flex-fuel cars as they are today are not forced induction. Yes they can run on both E85 and normal pump gas, but the adjustments that the ECU can make are not enough to make E85 economical. Flex-fuel cars get less mpg (because the ECU has to add more fuel to get the a/f ratio correct), but the thing it cannot do is increase cylinder pressure. They are N/A cars, and of course cannot increase compression ratio on the fly. So, horsepower also decreases.
4. Manufacturers cannot simply increase compression ratio on these Flex-fuel cars, because as soon as you try to use normal pump gas, it will Knock all the way from the gas station to the dealer (if it even makes it that far). The ECU simply cannot make the extreme adjustments required and still keep the engine running.
So I hope ya'll are paying attention to Biggie, but also realize that you may not be able to take advantage of E85 in a N/A FT-86, at least not until you add some form of forced induction, more fuel (somehow), and tune it with some aftermarket solution.
As far as the poll is concerned, you should vote:
Yes - if you plan to upgrade to a turbo (or you believe the car will come with a turbo) and you understand that you can make more power with E85.
No - if you do not plan to go Forced Induction, or believe the car will only come N/A and never plan to build a high compression engine for it, and realize that using E85 will only get you terrible gas mileage and less hp.
Now, I'm off to find out whether they announced that the FT will be available the first year with a Turbo!
cbishop11 is offline   Reply With Quote
Old 02-09-2010, 02:20 AM   #48
OldSkoolToys
Is a Monster
Drives: AE86, MA70
In the long run it doesn't really matter.
E85 is a stepping-stone energy source (well, not entirely, since its not meant to do anything but lower emissions), its not petrol's replacement.
Whenever the miracle energy source that comes around to replace gasoline, I bet E85 will get shoved aside because its primary use (lowering emissions) will be completely trumped by whatever that new energy source is.
Speculation of course, but I don't see Gasoline going away before E85.
Old 02-09-2010, 07:33 PM   #49
Matador
hashiryu
Drives: Mk4 Supra
Making fuel from a food source has to be in the top 10 dumbest ideas that man has ever come up with.
Matador is offline   Reply With Quote
Old 02-10-2010, 08:00 PM   #50
Lexicon101
Inexperienced
Lexicon101's Avatar
Drives: Crappy old '90 civic. Frankie.
man didn't come up with the idea. It's been happening in nature for billions of years, hasn't it?
Lexicon101 is offline   Reply With Quote
Old 02-11-2010, 03:27 AM   #51
Matador
hashiryu
Drives: Mk4 Supra
Old 02-11-2010, 04:01 AM   #52
Lexicon101
Inexperienced
Lexicon101's Avatar
Old 02-11-2010, 12:16 PM   #53
Biggie™
Stassenkämpfer
Biggie™'s Avatar
A 2 liter Subaru motor will require a turbo to make 200 hp... They can't even get their 2.5 liter to make over 170!.
Old 02-11-2010, 12:19 PM   #54
S2KtoFT86
Resident Post Whore
S2KtoFT86's Avatar
Drives: 2022 WR BRZ
Ok, this was too easy for me and I know I shouldn't but oh well. A Honda motor doesn't need a turbo to make 200hp. *ducks and runs away*
Gavin
S2KtoFT86 is offline   Reply With Quote
Old 02-11-2010, 01:02 PM   #55
Biggie™
Stassenkämpfer
Biggie™'s Avatar
Neither does a TOYOTA!
By the way, let me know when a Honda engine makes TORQUE!
Old 02-11-2010, 01:40 PM   #56
S2KtoFT86
Resident Post Whore
S2KtoFT86's Avatar
Drives: 2022 WR BRZ
Oh lord, we can go all day with this. Honda engines aren't made for torque. They're made to rev high. I like shifting at 9k. It's fun.
Gavin
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
