Old 01-06-2012, 08:18 PM   #43
brewksy
Drives: 2011 Subaru STI
Because there's no such thing as a 2012 FR-S. There is a 2013 FR-S though.
That's the big announcement on the 9th, I bet. Scion has been selling the 2012 FR-S for a year already! I bought my FR-S last April. Where have you been Dave???
brewksy is offline   Reply With Quote
Old 01-07-2012, 12:47 AM   #44
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Hey guys they updated the Scion website!
Lol but all in all, I think it looks better than before. But, it feels like it's missing some info. Even the interior pics of the FR-S are missing.
Snoopyalien24 is offline   Reply With Quote
Old 01-07-2012, 01:25 AM   #45
cRazy604
too nuts
cRazy604's Avatar
Drives: Scion FR-S
the Canadian website is better
cRazy604 is offline   Reply With Quote
Old 01-07-2012, 01:30 AM   #46
ayau
Drives: Some rust bucket
It at least has the correct tire specs.
Length 4240 mm (166.9 in.)
Width 1775 mm (69.9 in.)
Height 1285 mm (50.6 in.) (not including antenna base)
Wheelbase 2570 mm (101.2 in.)
Tread Front1520 mm (59.8 in.)Rear1540 mm (60.6 in.)
Seating capacity 4
Engine 1,998 ccTypeHorizontally opposed four-cylinder, D-4S injection, DOHCBore × stroke86 × 86 mm.Maximum output200hp @ 7,000 rpmMaximum torque151 lb.-ft. @ 6,600 rpm
Transmission 6-speed manual or 6-speed automatic with paddle shifters
Driveline Rear-wheel drive
Suspension Front MacPherson struts - Rear Double wishbone
Brakes Front Ventilated Disc - Rear Ventilated Disc
Tires Front215/45R17Rear215/45R17
Fuel tank 50 L (13.2 gallons)
Fuel Premium Unleaded
http://www.scion.ca/scion/about/news...75255473567329
Old 01-07-2012, 01:41 AM   #47
ayau
Originally Posted by bestwheelbase View Post
I don't think so Tim.
It's correct on the site. The format was messed up during the copy/paste.
Old 01-07-2012, 01:41 AM   #48
Snoopyalien24
Mr. Sarcasm
Yeah height is 51.2 in. and not 49 in. like I would of liked, but whatever. The suspension height looks like its set up for off-road, so I guess there is the (almost) 49 in.?
Old 01-07-2012, 01:47 AM   #49
bestwheelbase
Drives: 1985 P-Type
I just figured it was appropriate to reply given my username. :happy0180:
Old 01-07-2012, 01:49 AM   #50
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Originally Posted by WingsofWar View Post
you say its a matter of fact..what testing? what looseness? what sources? im trying to find where you got this via search..
the cars suspension geometry from previous articles says the car provides good performance without needing additional traction from sport tires.
If they wanted more traction, they should have opted for better rubber, IE not Prius tires. Increasing the contact patch in the back will probably slow the car down, rather than help any. And based on test drive reports, it sounds like it doesn't have enough power to really need a 225 rears.
If by going to an aspect ratio of 40mm vs the original 45mm, are they looking for MORE turning response..eg looseness?
Staggard setup from the factory looks like a typo or misinformation...like the rest of the information on that site.
Unless the standards of tire sizes has recently changed, the 40/45 ina 215/45R17 does not stand for 45mm, the aspect ratio is a percentage of the tire width. Meaning, a 45 series 215 has 96.75mm of sidewall, 45% of 215mm. A 225/40R17 would have 90mm of sidewall. Approximately 7mm of difference is not that much.
from
http://www.tirerack.com/tires/tirete....jsp?techid=46
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 01-07-2012, 01:56 AM   #51
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
from
P225/50R16 91S
Your right, thanks! aspect ratio and mm were incorrect. But what i was trying to ask...what are they trying to achieve by going to a smaller sidewall? From 215/45/17 to a staggered 215/40/17 - 225/40/17. The Difference in height may not seem like much, but it does have an effect in performance.
WingsofWar is offline   Reply With Quote
Old 01-07-2012, 02:15 AM   #52
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
Scion needs to get to work on their main site, Missing so much info. Detroit can't come soon enough...
00NissanNinja is offline   Reply With Quote
Old 01-07-2012, 02:27 AM   #53
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by Ribface View Post
Just noticed the Scion webpage has been updated.
http://www.scion.com/cars/FR-S/
Look like the FR-S is getting wider tires in the rear than the 86
From the spec page:
Not sure if it's an error, I find it odd they changed from 215/45R17 to 215/40R17
215/40 tires = 86mm sidewall
fistpoint is offline   Reply With Quote
Old 01-07-2012, 03:26 AM   #54
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
^215/45/17 w semi-track setup is hard on the bumps & dips, I wonder how nightmare it is to run 215/40/17...
Old 01-07-2012, 04:26 AM   #55
MRZ415
Drives: 2015 Subaru WRX
215/40-17 only good with a drop for hellaflush looks ... I am done with the style
heck .. even sortaflush is too much for me now ... with the BRZ its gonna be STOCK
I am currently on 225/45-17 with 1/4 inch wheel gap...
MRZ415 is offline   Reply With Quote
Old 01-07-2012, 06:11 AM   #56
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
I was thinking the same thing... until I saw this (last paragraph):
Possible 215/40-17 + 225/40-17 setup for Australia? Monday can't get here fast enough...
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
First Spy Pics of Scion FR-S / Toyota FT-86 Production Test Mule! (Updated 5/17) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 495 08-14-2020 08:15 PM
Scions FR-S page hartnsol Scion FR-S / Toyota 86 GT86 General Forum 1 12-05-2011 04:05 PM
Updated: Hi-res images of production Scion FR-S | Toyota FT-86 [Front and Rear] Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 257 11-29-2011 03:27 AM
Gazoo Racing Web Page MF_DEUCE Scion FR-S / Toyota 86 GT86 General Forum 0 10-17-2011 03:37 AM
Full Page Ad In Japanese Newspaper admiralhonshu Off-Topic Lounge [WARNING: NO POLITICS] 1 08-11-2010 01:17 PM
