Old 02-19-2013, 11:20 PM   #43
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
can anyone confirm if we can use the prius or tundra stalk? lol
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 02-20-2013, 12:18 AM   #44
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Sco2355 View Post
Once it all works put it back together and you should be good. Also, if someone with a BRZ or JDM/Euro GT86 can confirm, do y'all's fogs only come on with the headlights or can you turn them on whenever and that indicator still comes on?
If I forgot anything, please tell me so I can add it or clear it up!
to answer this for you since nobody else has, you can switch the fogs on only when you have low beams on
dori. is offline   Reply With Quote
Old 02-20-2013, 01:06 AM   #45
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
have you noticed that light is actually on both sides above the turn indicator? what would the other 1 do?
lbroskee is offline   Reply With Quote
Old 02-20-2013, 01:16 AM   #46
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Rear fog light?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 02-20-2013, 01:28 AM   #47
Retro86
Retro86's Avatar
Drives: Awesome
left and right fogs?? you can make them wink?? lol
Retro86 is offline   Reply With Quote
Old 02-20-2013, 02:02 AM   #48
zooki
Drives: waiting on a 2021...
Maybe it's for the right hand drive versions...LOL
zooki is offline   Reply With Quote
Old 02-20-2013, 07:27 AM   #49
Sco2355
Originally Posted by MemphisR View Post
Rear fog light?
I didn't look to see that there was another but if there is then it would be this. In the fuse box there is a front fog fuse along with rear fog fuse.
Sco2355 is offline   Reply With Quote
Old 02-20-2013, 08:35 AM   #50
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
If I understand what you're asking, there wasn't a place and the fuse box had no terminals going to it either. At the time I didn't have the means of doing it.
I wasn't really asking a question. Just making a statement, Adding information to the thread.
Probably wishful thinking that even the FRS might have some of the wiring for this option available. Even in the BRZ wiring diagrams it mentions an optional FOG harness but it appears to be the actual wiring and relay for the lights themselves.
Anyway I think the best method for wiring these up, instead of tapping the white wire at the location you have is to tap into the wire, if there, or adding a wire from pin 30 of the BCU to control the fog light relay. It would be a 'sinking' output or provide the ground to the relay.
FRSFirestorm is offline   Reply With Quote
Old 02-20-2013, 08:49 AM   #51
zooki
Well, I just ordered the Tundra/Corolla switch, so I'm now waiting for it to come in. I have a prewired harness with a relay coming, so I think what I'm going to do is tap into the side marker light for +12V power to the trigger side of the relay, and tie the ground side of the trigger into this pin 30 wire. That "should" let the switch turn on the fog lamps only when the parking or headlights are on. I think....
Old 02-20-2013, 10:43 AM   #52
FRSFirestorm
Red is Fastest
Should work.
Old 02-20-2013, 07:48 PM   #53
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
let us know if that stalk works for our frs. and link of purchase if u dont mind? lol
i tap my seperate switch on the ignition key, atleast i can still use the fogs anytime. like ebrake down DRL on + fogs on lol.
Old 02-20-2013, 08:51 PM   #54
zooki
Well, I'm going to try and trace where the wire goes from pin 30. Hopefully it goes into the engine compartment somewhere so I don't have to pull any wires through the firewall. But it'll be a couple of weeks until I can do this. I bought the switch from http://oemtoyotascionparts.com/
It was $105 shipped. I find it funny the Subaru switch is cheaper, but I didn't want the "auto" spot on the stalk..
Old 02-20-2013, 08:58 PM   #55
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
whats the part number? i see the ones for tundra $105 but thats without fog lamps. the $95 with fogs lamps. not sure, im confused lol
Old 02-20-2013, 09:30 PM   #56
zooki
This is the part number I ordered:
84140-02670
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
