Old 02-24-2013, 11:18 AM   #43
msile
msile's Avatar
Drives: ISF
Originally Posted by Acree View Post
Is there a list of the current BBK options on the forums?
-Acree
I did not see one when I did my research. There is the original thread with putting in the STI calipers, then the others that I have seen: GC8, Brembo, Wilwood, AP Racing.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 08-29-2013, 03:45 PM   #44
swift996
swift996's Avatar
@msile
Any update on this? I think I over-taxed my WRX wilwood kit and was looking into other options to upgrade to next summer.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-29-2013, 09:26 PM   #45
msile
msile's Avatar
Drives: ISF
Originally Posted by swift996 View Post
@msile
None. I am still using the Wilwood. I will probably start tracking it soon. Is the Wilwood on your WRX? How are you taxing it?
Old 08-29-2013, 09:58 PM   #46
swift996
swift996's Avatar
No I fitted it to my BRZ (bolts right up) the rotors are only 21mm thick which is leading me to believe the issues I had at the track might be related to heat.
Old 09-20-2013, 08:06 AM   #47
chewbacca
Drives: Frs-t
Wilwood and AP info
I liked thed idea of posting specs so i thank you for your number on the weight of my Wilwood kit. This gave me confidence measuring the weight distribution. Might not be as much but is important for the corner balance perspective.
The information from the AP was found in a video in Youe Tube in an installation video. The weight provided for the AP was ~20.7lb for the mounted rotor and caliper only.
Wilwood was weighted at ~22lb with the caliper, mounted rotor and pads.
The are couple of differences with these beside the pads. Wilwoods rotor is larger in diameter.
The AP rotor is wider but smaller in diameter.
Heat dissipation can be better in having bigger vents... Or you have a larger diameter to allocate heat over larger area, and probably have a different stopping feel on a larger diameter over the smaller diameter.
I guess work on the heat and diameter can bring different approaches in deciding whats best for you.
Money is a big contributor then follows another math of the specs of each product and what, where youll be driving it and how you drive too makes a difference.
I wanted to post these AP and Wilwoods weight comparison because on another forum the review omited the weight. And theres competition on these two.
Knowing the specs clearly contrasts the elements that one need to know to make sure when one end up paying itll be for almost the same thing, minus the price.
Cheers
chewbacca is offline   Reply With Quote
Old 02-25-2014, 05:26 PM   #48
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
OMGGGGGG
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 02-26-2014, 01:35 PM   #49
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
that color combo with the wheels and brakes looks great
IG-Joey_Soul
Old 03-01-2014, 10:09 PM   #50
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
so last time I saw it at Sebring you were running the Enkei RPF1's; are they 17x8 or 17x9 and are they +35 or +45 offset?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-02-2014, 11:58 PM   #51
msile
msile's Avatar
Drives: ISF
RPF1 17 x 8 (45 Offset) Square Setup.
Old 03-03-2014, 07:54 AM   #52
smbstyle
smbstyle's Avatar
Oh wow, and no clearance issues or rubbing at all?! That's great!
Hey @FT-86 SpeedFactory might wanna list this on your site for the Wilwood kits, as it clears the +45 on the 17x8!
2013 SWP BRZ
Old 03-03-2014, 02:00 PM   #53
msile
msile's Avatar
Drives: ISF
None. Car has been lowered and no rubbing. Plenty of caliper clearance as well.
╬╬ WILWOOD Big Brake Kits ╬╬ Free Shipping - Expert Advice - Photos and more... FT-86 SpeedFactory Brakes, Suspension, Chassis 186 04-25-2016 01:28 AM
Stop Tech Big Brake kit installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 03-27-2013 07:52 PM
Wilwood Big Brake Kit for Scion FR-S / Subaru BRZ at Chase Bays Chase Bays Brakes, Suspension, Chassis 15 02-11-2013 02:58 PM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 09:12 PM
