#43 | |
Drives: 86 GTS
an aftermarker oil temp sensor (unless it runs off the OBDii port) will have its own sensor to read temp which i would wager is not as accurate as the factory sensor. (obviously depends on placement) |
#44 |
Drives: Firestorm FR-S 6MT
Added the relative and absolute throttle position codes to the first post.
2013 Scion Firestorm FR-S MT
#45 |
Added Fuel Pressure in the 1st post.
#46 |
Drives: 2013 Firestorm FR-S
I can't seem to get oil temp in F only in C. Am I missing something?
#47 |
What did you get? Empty respond or some weired number?
#48 |
It was a - 35 and my coolant was at 191
#49 |
Update: It's working on mine.
Just make sure you enter the right code, and also your fw ver is at least 4.05.
#50 |
Is the is FRS CANSF? I got my scan gauge updated last week so I'm on 4.05
#51 |
Yes, FR-S is CANSF. If you're getting oil temp in C correctly, that means the TXD, RXF, and RXD are correct. Just make sure the MTH is 0009 0005 FFD8 (for F).
#52 |
Can the xguage read the wide band sensor? On of the posted pics hints that it can
#53 |
Got the oil temp working, now just working on air fuel ratio
#54 |
Drives: Moped
NM
#55 |
Brillo, it's good to hear you got it working. I also got an email from Scangauge. They confirmed that my oil temp code is fully working, and they posted the code on their website.
I will add a full list of supported standard (mode 01) PID soon. Stay tuned. Update: Added the Supported PID list to the 1st post.
#56 |
Drives: 86
Tried a few codes on my upgraded scangauge and its working great.
Thanks for your effort!! |
| FT-86 low temp THERMOSTAT | ft86-UAE | Engine, Exhaust, Transmission | 52 | 08-30-2016 03:46 PM |
| A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 01:19 PM |
| Engine oil temp now available in Torque App | Yruyur | Engine, Exhaust, Transmission | 8 | 02-03-2013 10:52 PM |
| exterior temp. gauge off? | Rayme | CANADA | 8 | 01-23-2013 09:06 PM |
| Simple Oil Temp. Gauge | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-19-2013 08:25 PM |
