Old 04-10-2014, 01:05 PM   #43
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by AZP Installs View Post
We have not done it yet but like an oil cooler we would put it in front of the radiator. The B&M Kit includes the mounting setup to mount it against the radiator.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
What size B&M would you suggest for the FRS?
I DD about 20-25k miles a year and am just getting into autox and may do a few track events, but probably only 1-2 a year.
Sent from my LT30at using Tapatalk
Old 04-10-2014, 01:30 PM   #44
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Here is a link to the ones we use on all our race car automatics and our customer cars over the years.
http://www.summitracing.com/parts/bmm-70255/overview/
Just put it in-line with the OEM cooler lines that feed into the radiator from the AT. Next time we have an AT car in the shop I'll snap some shots of where those lines are for you guys.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
AZP Installs is offline   Reply With Quote
Old 04-10-2014, 02:21 PM   #45
Drull
Drull's Avatar
Drives: Acura TSX Doxy
AZP Installs, may be you can write a few words how to change oil.
Ive removed the engine, now put it back, but the oil licked. And I should to fill in new oil
Thnx
Drull is offline   Reply With Quote
Old 04-10-2014, 07:10 PM   #46
AZP Installs
Thnx
Are you talking about the ATF or Engine Oil?
-Mike Paisan
Old 04-11-2014, 02:47 AM   #47
Drull
Drull's Avatar
ATF. I dont know how to fill in it
Old 08-02-2014, 08:54 AM   #48
ricebox
Drives: AE86 & GT86
-Mike Paisan
Any ideas on how to install this (like what lines to connect to this cooler)? Also, is this cooler for the engine oil or transmission fluid?
ricebox is offline   Reply With Quote
Old 04-16-2015, 09:41 PM   #49
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
I think going to the dealer for this service is the correct way to get this done - im at 35,6xx miles - Ill ask for transmission and diff fluid change service.
A transmission cooler is a smart idea if pushing big numbers or generating a lot of heat.
Would, lets say Scion, be able to full the correct amount if cooler was added?
Thanks
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 06-14-2015, 08:46 PM   #50
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Has anyone dropped the oil pan? I don't see a way of checking for and removing any debris without doing this. Did you need a new gasket to do this?
Old 06-14-2015, 09:52 PM   #51
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Definitely NOT 100k, honestly anywhere between 40000-50000 miles is a safe time:
"Fluid will be inspected every 30,000 miles or 30 months and will be replaced every 60,000 miles or 60 months and uses Toyota Specific World Standard fluid with capacities of 7.9 quarts"
Old 06-14-2015, 09:59 PM   #52
FRSBRZGT86FAN
Thanks
I was bored so I checked the service manual, if they do the process properly, which involves starting the engine putting the transmission in drive letting it reach temperature and checking the fluid levels again, then it should fill the cooler, this is assuming the cooler has no thermostat and free flows otherwise I'm not sure their fill technique will reach the correct temp to open the thermostat and allow ATF to flow to the cooler dropping the levels and making them add more......
According to the service manual "The ATF temperature must be between 42 and 47°C (108 and 117°F) to accurately check the fluid level.". I personally think that as long as the mechanic does a proper following of the service manual and does a good test drive and checks the fluid level again you should be fine.
Old 06-15-2015, 01:39 PM   #53
AG3NT_5CARFAC3
Drives: Toyota GT86
Thanks for the reply! I agree with you - I still have not reached 40K key, but im close. I went ahead and ordered Motul Gear 300 fluid for the diff fluid swap. I will be doing the fluid change and bilstein b14 coil install next monday - I think I heard somewhere Scion would want $250 for the trans fluid service - I will call Scion next Monday as well, unless somebody has info
And last thing, I am Phil LOL I made your key!
Old 06-15-2015, 01:47 PM   #54
FRSBRZGT86FAN
I know you're Phil Lol I follow you on insta too
Sent from my A0001 using Tapatalk
Old 06-15-2015, 02:47 PM   #55
AG3NT_5CARFAC3
Drives: Toyota GT86
dusty? lol
Old 06-15-2015, 03:12 PM   #56
FRSBRZGT86FAN
dusty? lol
Actually I'm still waiting on my key lol
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
