Old 12-20-2013, 10:32 AM   #43
shultz2
Drives: DGM brz
yea, you should have no problem with rubbing. i am on 18.9.5 et35 and 265/35s and i only rub on extreme hard corning. also my car sits rather low. you have something else going on there bud.
shultz2 is offline   Reply With Quote
The Following User Says Thank You to shultz2 For This Useful Post:
JonnyJames (12-22-2013)
Old 12-22-2013, 12:10 PM   #44
JonnyJames
Drives: 2013 Whiteout FR-S
Originally Posted by OICU812 View Post
Sure you're rubbing??? Have you identified points that prove so? That size with all details you've provided should be no where near rub not even close. You got something else going on. Jack it up turn wheels both ways and look around... Go from there..
Feels like the tires are pretty much touching the front springs, but I never felt the stock setup so as far as I know this could be normal? There's basically no clearance there.
All suspension I stock FYI
JonnyJames is offline   Reply With Quote
Old 12-22-2013, 02:52 PM   #45
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
the offset of +45 is the issue here, as it probably rubs on the struits/inner fender. Get some spacers (5mm should be enough) and the issue should be solved
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Old 12-22-2013, 03:51 PM   #46
JonnyJames
Gonna try this out. Thank you!!!
The Following User Says Thank You to JonnyJames For This Useful Post:
Killerbee (12-22-2013)
Old 12-22-2013, 07:26 PM   #47
Killerbee
Killerbee's Avatar
You're welcome. Make sure however that you check how spacers in front will affect handling. You may want to get some spacers in the same size for rear aswell, so both rear and front axle are again "in line" (dont know a better word for it in english, sorry).
Old 02-14-2014, 10:33 PM   #48
nethater
nethater's Avatar
Drives: Scion FR S
Now there are some decent pictures of the Enkei Wheels. Finally some one that can afford the wheels and a camera.
nethater is offline   Reply With Quote
The Following User Says Thank You to nethater For This Useful Post:
ngabdala (06-22-2014)
Old 04-03-2014, 02:16 AM   #49
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Thinking of pulling the trigger on these in black, with Hankook V12's.
Is a 245mm tire too wide for the 18x8.5? Does anyone have this setup? I want to avoid any kind of stretch, and it seems like the 235's stretch a little.
Also, with stock suspension, I've heard it's not a good idea to stagger the rear. Any opinions on this?
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 04-03-2014, 02:59 AM   #50
CSG David
CSG David's Avatar
Non-staggered the wheels. 245 on a 9.5 works as well, but that's the maximum stretch you should realistically go. Afterwards, it's just diminishing returns. 245 on a 8.5" is a nice setup as well.
The Following User Says Thank You to CSG David For This Useful Post:
PMok (04-04-2014)
Old 04-04-2014, 02:26 AM   #51
PMok
Codename: Stitch
PMok's Avatar
Pretty sure I shared these pics before but since this is the "official" wheel directory thread here they are again.
Enkei Raijin wheels, 18×8.5 +45 (symmetrical) + center caps from Enkei Kojin wheels
Federal 595 RS-R tires, 225/40ZR-18
Muteki black lug nuts
Eibach Pro-Kit lowering springs
(I am told the RS-Rs in 225 width are equivalent to around 245 of "normal" tires)
The Following 3 Users Say Thank You to PMok For This Useful Post:
bhbnuckle (03-11-2016), haimichaeltran (06-05-2016), TylerLinders48 (04-04-2014)
Old 04-12-2014, 12:57 AM   #52
Gps360
Drives: 2003 FR-S
Hi guys,
My Rijan wheels already ordered, now I am still waiting from the wheel shop to notify the arrival date (hopefully next week).
Before installing those wheels, do you guys know whether I can use the OEM nuts for the new wheels? I am still shopping the wheel nuts (cannot decide the color and brand at this moment).
Thanks.
Gps360 is offline   Reply With Quote
The Following User Says Thank You to Gps360 For This Useful Post:
AZOOZ_95 (05-27-2014)
Old 04-13-2014, 04:21 PM   #53
BP_FRS_26
Drives: 2014 Whiteout FR-S
Anyone know how the 19' Raijin's look on the frs/brz?
BP_FRS_26 is offline   Reply With Quote
Old 12-22-2014, 10:39 PM   #54
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Any rubbing going on with the eibach pro springs?
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 12-23-2014, 12:04 AM   #55
PMok
Codename: Stitch
PMok's Avatar
Nope no rubbing for me... but I think that will be somewhat dependent on what width tire you run, and how much negative camber you have.
Old 03-27-2015, 09:24 PM   #56
Jamesbrz
Drives: White BRZ
With this size wheel and say 245/35 tyres all round will there be any rubbing on the guards?will lower with coil overs to.
Jamesbrz is offline   Reply With Quote
Wheel Directory: Enkei RSF5 18x8.0 +45 ericmpena Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 85 06-18-2022 04:07 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 05:23 AM
Wheel Directory: Enkei NT03+M 18x8.0 +35 Tunz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 06-16-2016 11:31 PM
Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 Sciby Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-10-2014 12:53 AM
