Old 02-04-2013, 06:45 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Some pics.. I don't have step by step pics but the steps are basically as follows:
1. Lift the vehicle and safely support it (jack stands or a lift).
2. Remove the rear wheels
3. Remove the axle nut with an impact gun (or hand tools if no impact gun is available). You will need a 32mm socket for this job. Also if you are using hand tools you will need someone to stand on the brakes if the e-brake won't hold the axle from turning.
4. Ensure the the e-brake is released.
5. Remove rear brake caliper assemble (caliper, bracket and pads can all be removed together) and hang out of the way, as seen here:
6. Remove rotors (just pull on them).
7. Remove the speed sensor (10mm) on the top of the hub, the bolt is visible in this picture:
8. Remove the four bolts (14mm) bolts that hold the hub to the rear upright, three of the four are visible here:
9. Once all of them are removed you should be able to pull the hub assembly away from the car, push on the end of the axle to avoid the axle hanging up on the hub. 10. Once removed, use two of the bolts to secure the drum brake assembly to the car so that it doesn't hang:
11. Remove old lug studs using a press, or ball joint tool as shown above.
12. Install new studs using a press (if you have the right pieces, I couldn't use a press for the rears while I could for the fronts).
13. Reinstall is the opposite of the above. I used the same torque specs for the caliper bracket, hub bolts and speed sensor bolt that I used for the front. The axle nut is 136 ft/lbs.
14. Use a drift punch (or similar) to recrush the edge of the axle nut, or preferably, use a new axle nut and use the drift punch to crush the edge of the axle nut into the slot.
Pic of it finished, save for the brakes being re-installed:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-06-2013, 03:23 AM   #44
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
how are oe failing, just snapping? on track? or with impact?
Huehuecoyotl is offline   Reply With Quote
Old 04-13-2013, 12:47 AM   #45
bpracer
Drives: Asphalt FR-S
I remember some talk about snapping when torqued somewhere but can't find it. This thread is talking about spinning newly installed longer, cheap studs.
I installed them because I wanted 10mm spacers in the back. I'm using open lugnuts. I didn't want any track tech inspection to worry that there was not enough thread engagement, so longer ones went on the front as well.
I didn't like Ichiba's see thread below. ARP or Vorshlag are the way to go, ARP's are longer. I used Vorshlag open lugnuts as well, bulge nut with a reduced socket size. Not pretty, but effective.
http://www.ft86club.com/forums/showt...275#post622275
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 07-09-2013, 10:40 PM   #46
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I just had to replace one rear stud that i effed up with my impact last week. Went pretty good, and once i removed the rotor, i just wedged something in between the hub and the plate behind it and about 4 hits the old stud was out. There is plenty of room if you're just replacing stock studs, as i did, that you don't *Have* to remove the hub from the car.
However, if I would have had the large socket to remove the axle nut, I would have gone that way.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 10-14-2013, 01:21 PM   #47
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
How much longer over stock are the arp studs?
How big of a spacer can you run with the new wheel studs? I know people say 3-5mm max on the stock ones. I'm curious if something like a 15mm would be possible on the longer studs.
TylerLieberman is offline   Reply With Quote
Old 10-15-2013, 11:39 PM   #48
bpracer
The ARPs should be good for 15mm. I have Vorschlag studs that are not as long and they are good for 12mm spacer.
Asphalt FR-S
Ducati 848
Old 10-20-2013, 08:30 PM   #49
TylerLieberman
Drives: '24 GR86
I put 15mm worth of spacers on with short, closed end muteki lug nuts and the studs actually WENT THROUGH the tops of lugs lol.
I would say the ARP studs could take 25mm of spacer on it easy. I have Kics extended Neo Chro lugs on the way to replace the old ones.
Old 11-19-2013, 02:34 PM   #50
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Dave, what spacers did you end up getting and what was the front brake kit you were going to have with the stock wheels?
kurbkilla is offline   Reply With Quote
Old 12-04-2013, 12:17 AM   #51
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Wait, can you use 5mm spacers with the stock studs? For instance, the 5mm H&R Spacers are in the "DRS" series, and for DRS it says "This spacer is fitted between the wheel and hub, exhanging the existing wheel studs for longer ones. The wheels are then fitted to the hub/spacer with the existing wheel nuts." Is a 5mm spacer OK on our cars with the stock studs?
I did find this thread on the topic sorry: http://www.ft86club.com/forums/showthread.php?t=13427
Phaedrus29 is offline   Reply With Quote
Old 12-04-2013, 12:44 AM   #52
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Can you? Probably, it will barely hold.
However, you will stretch the end threads out after a few hard turns, and risk losing a wheel.
3mm stock studs, or longer studs, or bolt-on spacer.
-alex
Old 12-04-2013, 08:07 AM   #53
TylerLieberman
Drives: '24 GR86
I've been using 5mm spacers on the rear now for a couple months. Still no issues. I remember seeing somebody who had used 5mm spacers on the track before and it was just fine. It might vary a bit from wheel to wheel due to the backspacing thickness, but on rpf1s (which I have) it hasn't had any issues.
Old 12-16-2013, 03:09 PM   #54
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Just did this DIY to my front. Great write up. I am ordering 20mm slip on spacers as well.
Ryaquinn is offline   Reply With Quote
Old 12-21-2013, 01:29 PM   #55
THEmailman
Drives: Raven 6MT
Just did this myself. I had to replace one stud the dealer cross threaded (used another oem stud). Thank you for the write up, it was a super easy job and took maybe an hour start to finish. I did not have to worry about the dimple when taking the axle nut off either, it came off just by loosening the nut.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 02-10-2014, 10:22 AM   #56
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Please add to DIY directory
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
