Old 10-16-2012, 12:10 AM   #43
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Will cel's be on when tuning with ecutek?
JoeBoxer is offline   Reply With Quote
Old 10-16-2012, 12:11 AM   #44
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
You should be able to turn off CELs with ECUtek
ANTI_LAG is offline   Reply With Quote
The Following User Says Thank You to ANTI_LAG For This Useful Post:
JoeBoxer (10-16-2012)
Old 10-16-2012, 01:48 AM   #45
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Well, i can't wait till yall start with the V-band development!! Cuz most of us know, that the motor can take 500+whp right now, so i hope yall get to it soon... I have a plan on this setup if yall can integrate the V-band hehehehe but, good luck and keep the space available for a "Supra" sized turbo if you catch what im getting at lol
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 10-16-2012, 01:14 PM   #46
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by ANTI_LAG View Post
We can intercept the wire off the harness and have the proefi turn on a light for any indiction that we choose, for example with the cars we install the traction control on say the MK4 supra, you actually turn the trac on with the oem button, and the trac light will come on when its actually seeing wheel slip and correcting.
Well let's see if we can intercept a couple wires and turn the CEL and Traction control lights off in the future. They're just annoying to look at.
Old 10-16-2012, 05:05 PM   #47
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Now thats a different take on the turbo conversion for an 86 - very very nice
My only beef and a big one is the HOT AIR intake for the turbo charger, this adds a load of additional heat to the air charge meaning a lot more work for the intercooler and finally a higher exit temp from the intercooler. Get that sorted and you have a world beater right there!
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 10-16-2012, 06:13 PM   #48
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
We are running the simple Pro48 box at this time, it dosent support the oem crank pickups so we made our own trigger setup, we are controlling the port injectors, ignition coils DBW and boost controller with it. We also use oil pressure and fuel pressure sensors. If the fuel pressure drops a within a set limit it will correct the AF, if it drops past that it will turn the engine completely off as a safety precaution. It uses the oil pressure sensor the same way except once it hits a pressure drop we set, it just shuts the car off to save the engine, it dosent do anything past that. This is something you will never get with the stock ecu.It also has full time closed loop control via a wideband, and has the capability's of adding a flex fuel sensor which will allow you to pump 93 or ethanol any blend together at any mixture and it will automatically change AF/timing and boost based on this. The new Pro 112 box will be released soon and will work with the oem pickups and we will have a plug and play for this. That box will also have true traction control capability's which will monitor abs sensors and when it spins past the set limit will pull ignition timing to regain control of traction, this is how they control traction on pro drag cars. We will keep the community up to date with info as it comes out.
As for tuning, we are planning on releasing the kits with EcuTek.
Now I am confused. You are using the ProEFI for fuel and ignition control, but you are also tuning the car on ecutek? Sounds like a redundant extra cost.
Old 10-16-2012, 06:42 PM   #49
bakerr6
Drives: 2013 raven black fr-s
will there be options to run meth injection in the future? I'm not planning on running this setup, but it does look well built
bakerr6 is offline   Reply With Quote
Old 10-16-2012, 06:55 PM   #50
Evan@D3PE
Evan@D3PE's Avatar
Drives: 1969 Opel GT
This particular vehicle we did a custom ProEFI setup. For production they will more than likely use the ECUtek but ProEFI is also releasing another option. In the end it will probably be broken down separately so each custom has options.
Evan@D3PE is offline   Reply With Quote
Old 10-16-2012, 07:24 PM   #51
ANTI_LAG
ANTI_LAG's Avatar
That was never said, it was stated that we used ProEFI to tune the test vehicle but are planning on shipping with EcuTek.
Old 10-16-2012, 07:29 PM   #52
ANTI_LAG
ANTI_LAG's Avatar
IATs were great even during road testing, our intercooler is barely even breaking a sweat. Remember our core is longer than most competitors tank exit to tank exit lengths and ours is 3.5" thick.
Old 10-17-2012, 05:54 PM   #53
Tradewind
Yes I believe it would be relatively ok on the road, but what about in city stop start in hot conditions and then boot it hard, with not much airflow anywhere I dont really see where you are going to reject the heat to ...........
Give it continuous shots of high boost on and off at 40mph and I would like to see the IATs after a few mins of that
Old 10-17-2012, 06:41 PM   #54
Junior_Mint
Drives: 2011 challenger srt8/2013 scion frs
Originally Posted by Synack View Post
Damn my car looks good
Coupe the color of mayonnaise... Really Nice...
Junior_Mint is offline   Reply With Quote
Old 10-17-2012, 08:05 PM   #55
Synack
Boosted
Synack's Avatar
Drives: Sideways
45 mins of Houston traffic combined with the way I drive will get you all of that and worse.
Old 10-17-2012, 10:49 PM   #56
ANTI_LAG
ANTI_LAG's Avatar
The conditions you have listed will make IATs go up on any of the kits on the market, this is simply due to the fact of low speed airflow across the IC with high temps coming out of the turbo due to the compression heat build up from the turbo heat soaking the IC, the only way to eliminate this is with a air to water heat exchanger or running a really large turbo where temps out of the compressor cover would be lower. With that being said we have tested our design and it works the way we have intended it to do.
D3PE FRS/BRZ Catch Can System ANTI_LAG Forced Induction 114 12-15-2015 03:46 PM
~D3PE FRS/BRZ Catch Can System~ Evan@D3PE Engine, Exhaust, Bolt-Ons 26 06-12-2013 04:39 PM
~D3PE Stainless Braided Clutch Lines!~ Evan@D3PE Transmission and Driveline 23 04-30-2013 10:50 AM
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 06:48 PM
GRD turbo system jet86 Forced Induction 41 07-22-2012 11:18 PM
