Old 09-18-2012, 06:44 AM   #43
-max-
Drives: Firestorm FRS
I used 3/4". Make sure that you coat them well with something waterproof. Hey will get wet.
-max- is offline   Reply With Quote
Old 09-19-2012, 09:22 PM   #44
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Installed the front components and setup the back coaxial speakers. Would have installed the rear speakers but someone dropped one of them..... Ended up using the stock bracket and cutting it in half so the 4" would fit in.
We finished hooking everything up late so just gave it a test without messing with amp settings. Everything worked fine but realized the amp was set to low pass. Plan on putting all the front panels back on and then waiting on the rear speakers to come in friday.
New setup sounds real clean but it will need a sub for that punch.
Now if anyone has any tips on setting up a 4 channel amp properly let me know.
SubaSteve is offline   Reply With Quote
Old 09-19-2012, 09:30 PM   #45
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Set the HU till you hear distortion, then back it off a bit. Make sure the amp levels are pretty low for this. Then turn the gains up on the amp till they distort, or it gets too damn loud, and back them off a bit.
Obviously set low and high pass according to what the speakers that you are running can handle. If running full bandwidth speakers or using a passive crossover, set the amp slightly lower than the crossover, in high pass mode of course.
That'll get you in the ballpark. Then just tweak around with it, set the high pass higher/lower, see if it changes more or less to your liking. Then you get to do it all over again when you get the sub! YAY!
michaelahess is offline   Reply With Quote
Old 10-11-2012, 06:04 PM   #46
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Ok so I'm back to update and get some more input. Everything works perfectly just its all in the high end range and I need some lows. So I picked up http://www.crutchfield.com/S-30n2AjA6bUq/p_091P25DB/Focal-Performance-Sub-P-25-DB.html. I need something to push this but I want to make sure I'm not wasting my time with crap. I was still thinking [ame="http://www.amazon.com/Audio-Jx500-Mono-Subwoofer-Amplifier/dp/B0081K3M5G/"]Amazon.com: Jl Audio Jx500/1d Mono Subwoofer Amplifier - 500 Watts RMS X 1 At 2 Ohms: Car Electronics[/ame] since I can get it for around 160 which is a STEAL. I'm open for suggestions on this one though . I still want to spend under 200 for this amp.
Crutchfield said I'd be overpowering that sub with that amp he suggested http://www.crutchfield.com/p_575P300...l#overview-tab stating that the sub would wire down to 2 ohms. If I read the manual properly I should be able to run 4 ohm to the sub so I don't know what he was talking about.
Old 10-12-2012, 10:20 PM   #47
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
According to the link the sub is dual 4 ohm, so you can either wire it to 2 or 8 ohms. You can always turn the amp gain down. I always like to have more power in reserve, rather than have to max out the amp to push the sub. It should be fine on the JL amp. The biggest thing is giving the sub clean power, which it will. I ran one on 3 ED 8" subs and they handled it fine.
kmbkk is offline   Reply With Quote
Old 10-12-2012, 10:30 PM   #48
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
I decided to go with the rockford since they are actually rated higher then 300w when tested before they get sent out. I picked it up for super cheap at amazon and these bad boys are rated at around 400 at 2ohms and 250 at 4 ohms when they leave the factory.
My audio build - Pic Heavy rmjjensen Electronics | Audio | NAV | Infotainment 41 10-10-2016 10:03 AM
Max's Audio build -max- Electronics | Audio | NAV | Infotainment 93 10-14-2013 08:44 PM
SubaSteve's CBS BRZ SubaSteve Member's Car Journals 54 06-26-2013 08:03 PM
Need some audio help jpit Electronics | Audio | NAV | Infotainment 7 03-15-2013 05:09 PM
Looking for an FRS/BRZ in the SE For Audio SpeakBeck Southeast 8 02-17-2013 12:57 PM
