#43 |
Drives: '23 BRZ
Update:
I installed SPC camber bolt in the lower hole on the left front on Sunday, and of course adjusted that and 14mm OEM crash bolt in upper hole for max negative camber. Also adjusted the right front at the camber plate to keep L/R approximately matched (moved it over 4 tickmarks). Just got the car back from local shop, the front-left problem corner is now at -3.14, YAY! Front-right which still has plenty of adjustment available at the camber plate is at -2.98 so I'll adjust that another tick or tick-and-a-half to match. Rears (no adjustability) are at -2.43/-2.58, not bad. So the SPC camber bolt in lower hole gained another -1 degree. I'm not quite at the hoped-for original target of -3.5 front camber, but this'll do for now. Looking forward to NJMP on Monday/Tuesday... |
| The Following 5 Users Say Thank You to ZDan For This Useful Post: | autoracer86 (06-22-2023), gcmak (06-26-2023), NoHaveMSG (06-21-2023), norcalpb (06-21-2023), Racecomp Engineering (06-21-2023) |
| ST XTA coilovers (rebound adjustable, with camber top mounts front) | Tor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 10-02-2017 10:49 PM |
| Front and Rear Camber kit /w Coilovers | slow n FuRiouS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-07-2016 07:59 PM |
| ST coilovers and front camber bolt question. | dito | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 07-01-2015 04:52 PM |
| FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates | Steeze_Its | Brakes, Suspension, Chassis | 7 | 06-27-2014 10:32 PM |
