Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 04-14-2022, 02:31 AM   #43
Originally Posted by racingfool View Post
That's what it's for.
Most drivers these days don't have a clue about threshold braking.
Sure, if the ABS is a motorsport ABS system. The factory ABS system is not that.
Old 04-14-2022, 02:35 AM   #44
This is what a deeply cycled rotor looks like, without overheated pad. Notice there is no streaked/melted pad on this rotor.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
NoHaveMSG (04-14-2022), Ohio Enthusiast (04-14-2022), soundman98 (04-14-2022)
Old 04-14-2022, 02:38 AM   #45
soundman98
ProCrastinationConsultant
soundman98's Avatar
You'd be surprised how many folks swear they don't use ABS, and then I see 1000psi braking system pressure.
More importantly, he's not fully disengaging traction control, so even if he's not activating ABS during braking zones, the car is still nudging the brakes to 'correct' vehicle movement, which is likely contributing to the heat checking issue.
New cars are anything but "push a button and it's off" anymore.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
CSG Mike (04-14-2022), WolfpackS2k (04-14-2022)
Old 04-14-2022, 02:40 AM   #46
soundman98
soundman98's Avatar
For the record-- those rotors are still considered good, or is that considered end of life?
Old 04-14-2022, 02:58 AM   #47
racingfool
racingfool's Avatar
Drives: Miata
I was kidding.
racingfool is offline   Reply With Quote
Old 04-14-2022, 03:12 AM   #48
Crazing is getting too close to the edge of the rotor. I wouldn't run them; the pics are from when I swapped them out.
Old 04-14-2022, 03:14 AM   #49
https://www.instagram.com/p/Bck5ea0lWkH/
Some badly overheated pad (pads were insufficient for use).
Old 04-14-2022, 11:26 AM   #50
Edkwok99
Drives: GR86
I didn’t experience brake fade and soft pedal.
I didn’t feel the ABS kicking in (no vibration brake pedal and no front tires slipping and grabbing)
Would you please educate me how Anti lock braking system (ABS) could contribute to this?
I do not trail brake and always brake at a straight line. The track days were all on dry surface. I do not slammed on the brake and dive bomb. My inputs are smooth.
Edkwok99 is offline   Reply With Quote
Old 04-14-2022, 12:37 PM   #51
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You still overheated the pad. We can see it in the difference in color on the rotor. Can also see in the rotor that the center of the pad was getting way hotter than the outer edges and there is uneven transfer. I don't see ABS engagement on it but CSG Mike is far far more experienced at that stuff then I am so
Old 04-14-2022, 12:48 PM   #52
WNDSRFR
Drives: FR-S,GTI
Can somebody explain to me what ABS actually is?
I thought it was an anti-lock brake system that pulses the brakes to prevent them from locking up?
I thought that the system is always on and is always engaged.
You mean you can turn it off? Why would you do that?
It wasn't that long ago that ABS did not exist.
Back in the day, if you slammed on the brakes, you would going merrily sliding out of control. Happened all the time.
It's one of the best safety features of our time.
So how do you turn it off? Pull a fuse?
The Following User Says Thank You to WNDSRFR For This Useful Post:
Edkwok99 (04-14-2022)
Old 04-14-2022, 01:45 PM   #53
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It pulses pressure and can reduce pressure. Combined with stability and TC it can also independently brake a wheel to correct slip angle. I am sure modern systems have more capability than that, that is just the rough overview.
You can disable by pulling the fuse, or through can communication like what geraldjust has done. I imagine techstream may be able to disable it as well.
Old 04-14-2022, 04:37 PM   #54
dsc_pat
Drives: Too fast
this is taking an unexpected proportion for something very simple
hawk dtc will do these kind of deposits, everyone who used them knows. everything is normal, what more do you need to read ?
you 100% engage abs sometimes, and it is ok
end of thread.
dsc_pat is offline   Reply With Quote
The Following User Says Thank You to dsc_pat For This Useful Post:
Q8D (04-14-2022)
Old 04-14-2022, 05:04 PM   #55
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
end of thread.
It’s a good indicator of either driver error or you are outpacing the pad.
Here is CSG spec pad. Even transfer layer, pretty even rotor contact.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
CSG Mike (04-15-2022), soundman98 (04-14-2022)
Old 04-14-2022, 06:25 PM   #56
Edkwok99
Drives: GR86
end of thread.
I need to know if I should replace the rotor immediately as stated in my original post.
Are you saying Antilock brake system did this to the rotor? If yes, I disagree totally. I think you are confused with ABS and TRAC/VSC.
Brake pads to swap between for DD and Track Days jim985 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-25-2020 09:12 PM
Brake compound for Track Days fer3d Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-31-2018 09:47 AM
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 04:59 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 02:39 AM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 07:42 PM
