#43 | |
![]() Clint Boisdeau and 949 racing have also confirmed the issue with our specific car; we haven't yet tried changing rear compounds, but will do so before our next test day. I'll keep everyone posted. *edit* Just to clarify, everything is off; Traction is held for ~3 seconds until both yellow lights are on. |
#44 |
pull
abs fuse retest |
#45 |
It makes snese to me that it's either:
A: Signalling EBD is actually active as it's sensing a difference in front/rear wheel speeds while brake is being applied. or B: As Element Tuning stated, only signalling that current conditions would require stability control to be in effect if it were actually active. I'd like to see some datalogging showing definitively what's happening and if it's actually affecting the car's behavior. |
#46 |
Drives: Hydra EMS Powered FRS Raven Black
Ok if you are turning everything off properly you're just asking the car to do something it cannot. You also mentioned less friction rear pads which I'm sure is part of the problem. I've tested with abs off with equal friction pads and the fronts lockup first so equal friction at the very least should b run front to rear.
#47 |
Drives: 2013 FRS Whiteout
Its NORMAL, like mentioned earlier its just EBD. Happens to me all the time coming into turn 2 @ Homestead speedway.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#48 |
Overthinking it
Drives: BRZ in CS
I got the same thing last weekend at an autocross.
#49 |
Senior Citizen
Drives: Scion FR-S
Try this:
http://www.ft86club.com/forums/showp...8&postcount=15 I just tried the procedure. Seemed to turn everything off. Have yet to try it on a course, though. Worth a shot! |
#50 |
Somewhat unrelated, but in testing last weekend and this weekend, we were able achieve proper trail braking/rotation under braking with our current setup.
It's totally FUBAR, but it works for now. 225 RS3 front, 215 Star Sec rear 1/32" toe-out front, 0 toe rear -1.35 camber front, -1.4 camber rear This setup also worked (we went a bit extreme for testing purposes) 225 RS3 front, 215 Star Sec rear 3/16" toe-out front, 3/32" toe-out rear -1.35 camber front, -1.4 camber rear |
#51 | |
Overthinking it
Drives: BRZ in CS
Wow...
#52 |
Drives: 2021 Supra / 2022 Tundra
I used to do this on the IS350...its a PITA and I hope that it's not necessary for every run. I barely can remember to hit one button to disable everything on the WRX...
TomR
#53 |
I would need a cheat sheet to remember that.
I have not seen this behavior either in autocross or on the street myself. It is interesting there is no mention of this anywhere in the manuals. |
#54 |
Overthinking it
Drives: BRZ in CS
I got it under full ABS braking in an autocross. Stock tires on a sandy course. It did not affect my driving. I'd be curious to see if this kicks in with stickier tires.
#55 |
Drives: 2024 GR86/ 2015 FRS
I wonder if I am having the same problem?
The last two times I raced at Meadowlands NJ I went hard on the brakes and the pedal was Very hard and the car wouldn't stop, it really made it hard to make that turn. I tried pulling the ABS fuse, I went into the same turn with the same speed and when I hit the brakes it just locked up both front tires Bad. So I put it back in and just dealt with it. The next day, I raced somewhere else with high speed braking and didn't have any problems. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#56 |
That sounds a lot more like ice mode than stability control. MR2 and Z06 would do exactly that.
TomR
| Light flashing under trail braking. | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-16-2012 04:10 PM |
| Toxic Detail and Performance, Indian Trail NC | Toxic | Announcements, Contests, Giveaways | 4 | 07-24-2012 05:13 PM |
| Turn signal amber LED's flashing quickly | michaelahess | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-13-2012 10:55 PM |
| anybody else see the flashing carrot??? | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 01-18-2012 09:25 AM |
| Help me track down my braking problem :( | #87 | Other Vehicles & General Automotive Discussions | 32 | 09-26-2011 12:49 PM |
